erreur vb
erreur vb - VB/VBA/VBS - Programmation
Marsh Posté le 23-03-2005 à 12:00:33
bonjour,
j'ai besoin d'aide sur ce script
message erreur
erreur : type icompatible 'regexists'
code 800A000D
im WSHShell
Set WSHShell = wscript.CreateObject("wscript.Shell" )
WSHShell.Run "net stop wuauserv"
Wscript.Sleep 10000
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\wuauserv\start", 2, "REG_DWORD"
Wscript.Sleep 5000
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\NoAutoUpdate", 0, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\AUOptions", 4, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\ScheduledInstallDay", 0, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU\ScheduledInstallTime", 8, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\UseWUServer", 1, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\NoAutoRebootWithLoggedOnUsers", 1, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\AU\RescheduleWaitTime", 1, "REG_DWORD"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\WUServer", "http://olive", "REG_SZ"
WSHShell.RegWrite "HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\WindowsUpdate\WUStatusServer", "http://olive", "REG_SZ"
If RegExists ("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\windowsupdate\auto update\LastWaitTimeout" ) Then
WSHShell.RegDelete "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\windowsupdate\auto update\LastWaitTimeout"
else
MsgBox "La clé n'existe pas."
End If
If RegExists ("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\windowsupdate\auto update\DetectionStartTime" ) Then
WSHShell.RegDelete "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\windowsupdate\auto update\DetectionStartTime"
else
End If
WSHShell.Run "net start wuauserv"
Wscript.Sleep 10000
strComputer = "."
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2" )
Set colRunningServices = objWMIService.ExecQuery ("Select * from Win32_Service" )
For Each objService in colRunningServices
 if objService.DisplayName = "Automatic Updates" then
     if objService.State = "Stopped" then
       wscript.echo "Automatic Updates a été configuré. Vous devez redémarrer l'ordinateur pour pour que les paramètres soient effectifs."
     else
       wscript.echo "Automatic Updates a été configuré."
     end if
 end if
Next
wscript.Quit(0)
ste29
