Distance entre deux objets - VB/VBA/VBS - Programmation
MarshPosté le 24-02-2014 à 14:53:48
bonjour tout le monde!
je voulais créer une macro en vbs sous catia! dont elle mesure la distance entre un point appartenant à une piece et un plan appartenant à une autre piece! j'ai developpé ce bout de code!
Sub CATMain()
Dim productDocument1 As Document Set productDocument1 = CATIA.ActiveDocument
Dim documents1 As Documents Set documents1 = CATIA.Documents
Dim partDocument1 As Document Set partDocument1 = documents1.Item("piece1.CATPart" )
Dim part1 As Part Set part1 = partDocument1.Part
Dim hybridBodies1 As HybridBodies Set hybridBodies1 = part1.HybridBodies '**** Dim hybridBody1 As HybridBody Set hybridBody1 = hybridBodies1.Item("Construction " )
Dim hybridShapes1 As HybridShapes Set hybridShapes1 = hybridBody1.HybridShapes
Dim hybridShapePointCenter1 As HybridShape Set hybridShapePointCenter1 = hybridShapes1.Item("Point.1" )
Dim partDocument2 As Document Set partDocument2 = documents1.Item("piece2.CATPart" )
Dim part2 As Part Set part2 = partDocument2.Part
Dim originelements2 As OriginElements Set originelements2 = part2.OriginElements
Dim reference1 As Reference Set reference1 = originelements2.PlaneXY msgbox(reference1.Name)
part2.Update '******
Dim TheSPAWorkbench As SPAWorkbench Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench" )
Dim Measurable1 As Measurable Set Measurable1 = TheSPAWorkbench.GetMeasurable(hybridShapePointCenter1)
Dim Measurable2 As Measurable Set Measurable2 = TheSPAWorkbench.GetMeasurable(reference1)
Dim distance As Variant distance = Measurable2.GetMinimumDistance(hybridShapePointCenter1)
MsgBox "distance du 1er pt " & distance & " "
End Sub
mais ce dernier donne des fausses données! en fait il mesure la distance entre le point1 de la 1ere piece et le plan xy de la meme piece!!! merci bien
Marsh Posté le 24-02-2014 à 14:53:48
Sub CATMain()
Dim part1 As Part
Dim part2 As Part
part2.Update
End Sub
merci bien
