creer un textbox numeric
creer un textbox numeric - VB/VBA/VBS - Programmation
Marsh Posté le 14-03-2005 à 19:11:56
voila je voudrais creer un nouveau control un textbox qui soit :
couleur info
text centré
aucun texte par defaut
police etc...
ceci j'ai reussi à le faire
mais je voudrait qu'il n'accepte que des chiffre ou une virgule.
voici mon code dite moi ou ca coince vb.net ne me donne aucune erreur mais accepte tout les caracteres.
Public Class numeric
    Inherits System.Windows.Forms.TextBox
    Private numeric As Boolean
#Region " Windows Form Designer generated code "
    Public Sub New()
        MyBase.New()
        'This call is required by the Windows Form Designer.
        InitializeComponent()
        'Add any initialization after the InitializeComponent() call
    End Sub
    'UserControl1 overrides dispose to clean up the component list.
    Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
        If disposing Then
            If Not (components Is Nothing) Then
                components.Dispose()
            End If
        End If
        MyBase.Dispose(disposing)
    End Sub
    'Required by the Windows Form Designer
    Private components As System.ComponentModel.IContainer
    'NOTE: The following procedure is required by the Windows Form Designer
    'It can be modified using the Windows Form Designer.
    'Do not modify it using the code editor.
    Friend WithEvents Textnumeric As System.Windows.Forms.TextBox
    <System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
        Me.Textnumeric = New System.Windows.Forms.TextBox
        'Textnumeric
        Me.Textnumeric.Location = New System.Drawing.Point(17, 17)
        Me.Textnumeric.Name = "Textnumeric"
        Me.Textnumeric.TabIndex = 0
        Me.Textnumeric.Text = ""
    End Sub
    Public Property num() As Boolean
        Get
            num = numeric
        End Get
        Set(ByVal Value As Boolean)
            numeric = Value
            If Value = True Then
                Me.BackColor = System.Drawing.SystemColors.Info
                Me.Text = ""
                Me.TextAlign = HorizontalAlignment.Center
                Me.Refresh()
            End If
        End Set
    End Property
#End Region
    Private Sub Textnumeric_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles Textnumeric.KeyPress
        If Asc(e.KeyChar) = 46 Then
            If InStr(1, Textnumeric.Text, "," ) > 0 Then
                e.Handled = True
                Exit Sub
            End If
            Textnumeric.SelectedText = ","
        End If
        ' SI la touche appuyée est autre que : un chiffre, une touche contrôle, une "," ou un "-"
        ' ALORS la touche est sans effet.
        If Not (Char.IsDigit(e.KeyChar) Or Char.IsControl(e.KeyChar) _
                Or e.KeyChar = "," Or e.KeyChar = "-" ) Then
                e.Handled = True
                Exit Sub
            End If
            e.Handled = True
            Exit Sub
        End If
    End Sub
End Class
Marsh Posté le 15-03-2005 à 16:21:56
