Python AttributeError
Python AttributeError - Python - Programmation
Marsh Posté le 11-06-2014 à 16:21:31
Bonjour alors voilà j'ai sur mon code à la compilation un attributeError et je n'ai aucune idée d'où cela peut provenir...
Alors voilà mon code de base :
##Chemin avec les library
#!/usr/local/samba/lib/python2.7/site-packages/samba/netcmd
import sys
# Find right direction when running from source tree
sys.path.insert(1, "/usr/local/samba/lib/python2.7/site-packages/samba/netcmd" )
# make sure the script dies immediately when hitting control-C,
# rather than raising KeyboardInterrupt. As we do all database
# operations using transactions, this is safe.
import signal
signal.signal(signal.SIGINT, signal.SIG_DFL)
from samba.netcmd.main import cmd_sambatool
cmd = cmd_sambatool()
subcommand = None
args = ()
from samba.netcmd.user import cmd_user
cmd2 = cmd_user()
subcommand = None
args = ()
from samba.netcmd.user import cmd_user_create
cmd3 = cmd_user_create()
subcommand = None
args = ()
class FirstUse():
    def __init__(self, cmd3):
        self.cmd3 = cmd3
cmd3.run("zyy", "Tutu2!" )
L’erreur que j'ai est la suivante :
Traceback (most recent call last):
  File "/root/workspaceTest/testPython/src/FirstUse.py", line 49, in <module>
  File "/usr/local/samba/lib/python2.7/site-packages/samba/netcmd/user.py", line 160, in run
    lp = sambaopts.get_loadparm()
AttributeError: 'NoneType' object has no attribute 'get_loadparm'
Voilà aussi si jamais ca peut aider la spécification de la fonction run que j'utilise :
user.cmd_user_add.run(self, username, password=None, credopts=None, sambaopts=None, versionopts=None, H=None, must_change_at_next_login=False, random_password=False, use_username_as_cn=False, userou=None, surname=None, given_name=None, initials=None, profile_path=None, script_path=None, home_drive=None, home_directory=None, job_title=None, department=None, company=None, description=None, mail_address=None, internet_address=None, telephone_number=None, physical_delivery_office=None)
Voilà donc j'attends votre aide au plus vite…
Marsh Posté le 11-06-2014 à 20:54:47
Bah comme le message dit, il veut un sambaopts valide [:spamafote]
Mais en lisant le code, appeler les cmd_ directement n'a aucun sens, ce sont des implémentations des sous-commandes de l'outil shell samba-tool, si tu veux jouer avec programmatiquement faut taper directement dans samba.samdb.SamDB (et amis, genre samba.auth)
Message édité par masklinn le 11-06-2014 à 20:55:28
I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing?
Marsh Posté le 12-06-2014 à 15:22:52
Alors du coup j'ai fais comme ça et tout marche comme il faut :
import sys
sys.path.insert(0, "/usr/local/samba/lib/python2.7/site-packages" )
import signal
#Importation de la bonne classe
cmd = cmd_sambatool() #on declare cmd un objet de la classe
subcommand = "user" #On utilise la commande user de la classe cmd_sambatool
args = ("add","zaaa","Zaaa!?4","--surname=zaa","--initials=zzaa" ) #args prend la valeur de l'action a executer et on lui fournit les informations/Options necessaires !!
#Ici declaration d'une nouvelle action a utiliser
args2 = ("delete", "zii" )
if len(sys.argv) > 1:
subcommand = sys.argv[1]
if len(sys.argv) > 2:
args = sys.argv[2:]
args2 = sys.argv[2:]
try:
retval = cmd._run("samba-tool", subcommand, *args) #_run execute la bonne commande
except SystemExit, e:
retval = e.code
except Exception, e:
cmd.show_command_error(e)
retval = 1
try:
retval = cmd._run("samba-tool", subcommand, *args2)
retval = e.code
retval = 1
sys.exit(retval)
Par la suite je dois récupérer les mots de passe avec Hash sur un LDAP et j'aimerais juste savoir si avec cette méthode je vais pouvoir passer le Hash a Samba4?
