Bon, ben j'ai trouvé la réponse à ma question (enfin presque) :
* Error: Fatal error: Only variables can be passed by reference in /usr/local/apache2/htdocs/squirrelmail/functions/imap_messages.php on line 480
After upgrading from PHP4 to PHP5.1, my Squirrelmail now sends this message when I check mail, when I click on INBOX, or when I click on "sent." Everything else continues to work.
This seems to be triggered by PHP 5.1, since this error never came up when using squirrelmail with PHP 5.0.x.
Correction: The problem also occurs with PHP 5.0.5 (not with 5.0.4) !!
Marsh Posté le 14-09-2005 à 16:52:57
J'utilise php 5.0.5 et squirrelmail 1.4.5 et depuis que je suis passé de php 5.0.4 à php 5.0.5 j'obtiens ce message d'erreur :
Fatal error: Only variables can be passed by reference in \functions\imap_messages.php on line 480
La fonction en question est la suivante :
comment corriger l'erreur ? Merci
