session php.ini
session php.ini - PHP - Programmation
Marsh Posté le 09-02-2003 à 12:22:34
je voulez savoir ou placer le fichier php.ini pour une session php,
merci d' avance.
Marsh Posté le 09-02-2003 à 12:25:43
merci d' avance.
Rien pigé, ton PHP.ini a un emplacement fixe, faut juste modifier les parametres concernant les sessions
Marsh Posté le 09-02-2003 à 12:32:14
je doit le modifier où??
Marsh Posté le 09-02-2003 à 12:35:06
Un conseil ne poses jamais une question comme ça ou des moules rodent dans le coin.
Sinon :
[Session]
; Handler used to store/retrieve data.
session.save_handler = files
; Argument passed to save_handler.  In the case of files, this is the path
; where data files are stored. Note: Windows users have to change this
; variable in order to use PHP's session functions.
session.save_path = /tmp
; Whether to use cookies.
session.use_cookies = 1
; Name of the session (used as cookie name).
session.name = PHPSESSID
; Initialize session on request startup.
session.auto_start = 0
; Lifetime in seconds of cookie or, if 0, until browser is restarted.
session.cookie_lifetime = 0
; The path for which the cookie is valid.
session.cookie_path = /
; The domain for which the cookie is valid.
session.cookie_domain =
; Handler used to serialize data.  php is the standard serializer of PHP.
session.serialize_handler = php
; Percentual probability that the 'garbage collection' process is started
; on every session initialization.
session.gc_probability = 1
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
session.gc_maxlifetime = 1440
; Check HTTP Referer to invalidate externally stored URLs containing ids.
session.referer_check =
; How many bytes to read from the file.
session.entropy_length = 0
; Specified here to create the session id.
session.entropy_file =
;session.entropy_length = 16
;session.entropy_file = /dev/urandom
; Set to {nocache,private,public} to determine HTTP caching aspects.
session.cache_limiter = nocache
; Document expires after n minutes.
session.cache_expire = 180
; use transient sid support if enabled by compiling with --enable-trans-sid.
session.use_trans_sid = 1
url_rewriter.tags = "a=href,area=href,frame=src,input=src,form=fakeentry"
Y a tout ce qu'il faut, le nom est assez explicite
Marsh Posté le 09-02-2003 à 12:41:28
ma question c' etait , dans mon fichier a quel endroit doit on placer les parametres?
Marsh Posté le 09-02-2003 à 12:43:24
Tu as tous les parametres ici  :heink:
Et pour utiliser les sessions :
session_init()
session_start()
Si tu veux plus d'infos : php.net il sert à ça
Marsh Posté le 09-02-2003 à 12:47:45
bon ok merci de l' aide.
