Serialize& Unserialize
Serialize& Unserialize - PHP - Programmation
Marsh Posté le 11-12-2003 à 21:23:56
Salut, j'ai un petit probleme avec ces fcns: impossible de unserializé un tablo avec de trop longues chaines de caractére:(
qq a une astuce ?
merci d'avance
Marsh Posté le 11-12-2003 à 21:25:37
urlencode()
from here and there -- \o__________________________________ -- la révolution de la terre, en silence
Marsh Posté le 11-12-2003 à 21:26:57
J'vois pas trop le rapport;)
Marsh Posté le 11-12-2003 à 21:29:08
et urldecode() [:veryfree]
Marsh Posté le 12-12-2003 à 17:55:36
Hum je te parle de tableaux;)
Marsh Posté le 12-12-2003 à 17:56:41
tu as des exemples de cas qui ne marche pas?
Marsh Posté le 13-12-2003 à 13:00:26
  1. a:2:{i:0;s:1038:"The career mode will have players racing through all different kinds of races including the new crossover duel race. Ice races, rallicross, hill climbs and basic rally races are all back again and all the race types will be presented in branching patterns so that as the player progresses you will have to become proficient at all kinds of races. You'll reach branches in the race progress tree so that after doing a couple of ice races you'll be able to choose from a rally, hill climb or crossover next and even anticipate what type of race you'll want to do after that. This setup means you'll be able to develop your racing abilities across all the race types at a comfortable pace before moving on to tougher races later on in your career. This way you're not thrown off when you're suddenly thrown into an ice race 10 hours into your career. The number of events you'll have to race also increases as you choose higher difficulties so there will be more branching opportunities on the championship setting than the amateur setting. ";i:1;s:724:"Marseille , marseille on t'encule...<br>
  2. Marseille , marseille on t'encule...<br>
  3. Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...Marseille , marseille on t'encule...";}
Marsh Posté le 13-12-2003 à 13:18:41
bwalé .. j'recommence ..... (des fois que t'aurais un nouveau cerveau [:veryfree])
je ne te garantie pas que ce soit ca ..... mais disons qu'il y a 90% de chances  [:risboc]
urlencode() va encoder les chaines contenues dans ton tableau et eviter qu'une quote ou un carcatère a la con coupe ta chaine lors de la transmission du tableau....
  1. $table=urlencode(serialize($table));
  2. <input type="hidden" name="table" value="<?php echo $table; ?>" id="table">
et pour recuperer tes données :
  1. $table=unserialize(urldecode($_POST['table']));
(je deteste la mentalité de supporters footeux :/ )
Marsh Posté le 13-12-2003 à 13:21:20
yep j'ai deja essayé sans resultat
ps: j'ai mis ca comme çamdr:p
Marsh Posté le 13-12-2003 à 13:28:39
desolé d'insister mais tu es sur que tu as procédé dans le bon ordre lors de ton essai ?
dans l'exemple que tu a mis ... tu peux dire ou se coupe la chaine ?
peux tu mettre la ligne de  code avec laquelle tu transmets ton tableau ..
Marsh Posté le 13-12-2003 à 18:08:59
t'as pas choisi la meilleur chanson du parc :/
montre nous le code qui ne marche pas, ça vient pê de ta syntaxe :whistle: (enfin juste quelques lignes ;) )
Marsh Posté le 13-12-2003 à 19:36:16
"t'as pas choisi la meilleur chanson du parc "
Je suis bordelais;), j'ai mis ca pour faire un clein d'oeil a un pote, enfin c'est pas trés ineteressant, simogeo, je vais reessayer avec ta methode:)
