Probleme pour installer un livre d'or
Probleme pour installer un livre d'or - PHP - Programmation
Marsh Posté le 08-07-2009 à 09:44:58
Bonjours, je suis en train de crée un site internet et je l'herberge avec le ftp de 10giga de free.
Le probleme et que j'ai toujours des problemes comme:
Warning: main(./include/config_default.inc.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 183
Warning: main() [function.include]: Failed opening './include/config_default.inc.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 183
Warning: main(./include/constants.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 185
Warning: main() [function.include]: Failed opening './include/constants.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 185
Warning: main(./include/functions.inc.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 186
Warning: main() [function.include]: Failed opening './include/functions.inc.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 186
Warning: main(./admin/include/functions.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 187
Warning: main() [function.include]: Failed opening './admin/include/functions.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 187
Warning: main(./admin/include/functions_upgrade.php) [function.main]: failed to open stream: No such file or directory in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 188
Warning: main() [function.include]: Failed opening './admin/include/functions_upgrade.php' for inclusion (include_path='/mnt/147/sda/4/4/anomalie13/include:.:/usr/php4/lib/php') in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 188
Fatal error: Call to undefined function: get_languages() in /mnt/147/sda/4/4/anomalie13/script/piwigo-2.0.2/install.php on line 198
D'ou vien ce probleme? J'ai des procleme pour installer nimporte quel script php. Quelle est la chose que je fait mal?
Marsh Posté le 08-07-2009 à 10:29:21
soit tu as mal configurer ton application(chemin par exemple)
soit il te manque des fichiers.
et tu sur que dans tes include tu passe le bon chemin?
Marsh Posté le 08-07-2009 à 10:41:01
Le script a été téléchargé donc il est bon.
Les fichiers sont tous la mais peu etre qu'il faut que je cree des dossiers.
Esqu'il faut que je cree: ./admin/include/ ou il se creéra tout seul?
Marsh Posté le 08-07-2009 à 11:00:43
ben les fichiers ils sont a quel niveau?
ils sont au même niveau que le fichier que tu appele?
si c'est le cas regarde si tu as une pas configuration de ton script,
sinon oui tu dois ranger tous tes fichiers dans chaque dossier comme il faut, ou changer le chemin de tes includes!!
bizarre ton script si tu dois ranger ou modifier tous les chemins!!!
Marsh Posté le 08-07-2009 à 11:45:23
Je suis novice en php. Comment fait t'on pour savoir le nom de tout les dossiers et pour savoir quel fichier va dans tel dossier?
Quand je telecharge un script tout les fichiers sont dans le meme dossier.
Marsh Posté le 08-07-2009 à 13:03:17
tu peut pas savoir dans quel dossier va t'elle fichier, c'est impossible a savoir sauf si tu as 2 ou 3 fichiers ou si c'est toi qui a crée le script
mais je pense avoir compris ton probleme, le script que tu as telechargé n'est pas zippé par hasard?
Message édité par infoman64 le 08-07-2009 à 13:03:54
Marsh Posté le 08-07-2009 à 14:40:28
Oui il est zippé.
Marsh Posté le 08-07-2009 à 14:54:21
je pense que tu as du utilisé winzip( il te met a plat tous les fichiers)
utilise winrar , et tu fais extraire vers un dossier,
tu verra tes fichiers seront rangés dans les dossiers correctement.
Marsh Posté le 08-07-2009 à 15:22:03
Ha ca m'apprendra a laisser une chance a winzip pour une fois! Je réinstal winrar desuite.
Merci je vais tester ca!
Marsh Posté le 08-07-2009 à 16:24:35
Tu dois avoir une option dans WinZip pour décompresser en respectant l'arborescence.
http://www.aideinfo.com/  Whois adresses IP/domaines le plus évolué !!  FAQ Free Mobile
Marsh Posté le 09-07-2009 à 00:30:16
Je suis le créateur de Piwigo (une alerte Google m'a amené sur ce forum qui a accompagné les premiers pas du projet il y a 7 ans).
Un livre d'or ? Piwigo n'est pas un livre d'or mais un galerie photo. Enfin, ce n'est pas le problème.
Est-ce que tu as essayé la NetInstall qu'on a sortie en 2.0 ? Il n'y a qu'un script PHP à transférer sur ton site et ensuite il s'occupe de télécharger le zip Piwigo, de le dézipper, mettre les bons droits et lance la procédure d'installation.
Bon sinon je confirme les suppositions de aideinfo, c'est très probablement ton "désarchiveur" qui a aplatit l'arborescence de répertoires inclut dans le zip.
