Jtable et Jcheckbox, probleme de couleur - Java - Programmation
Marsh Posté le 16-12-2003 à 12:49:34
finalement j'ai réussi à faire ce que je voulais mais je trouve que c'est cradoc, si quelqu'un avait une suggestion voici le code
import javax.swing.*;
import java.awt.*;
import java.sql.*;
import java.util.*;
import java.awt.event.*;
import javax.swing.table.*;
import javax.swing.event.TableModelEvent;
import javax.swing.event.*;
public class JIFScrollTable extends JScrollPane {
 private
 public JIFtable (Vector title) {
 	String[] h = {"Envoi O/N","Fichier","Descriptif","Date MAJ","Sensibilité"};
 	abstractModel am = new abstractModel(h);
 	//JIFTableModel TM  = new JIFTableModel();
class JIFtableRenderer extends DefaultTableCellRenderer {
  public Component getTableCellRendererComponent(JTable table, Object value,boolean isSelected, boolean hasFocus,int row, int column) {
    if (value instanceof Boolean) {
      JCheckBox checkBox = new JCheckBox();
      checkBox.setSelected(((Boolean)value).booleanValue());
      checkBox.setHorizontalAlignment(JLabel.CENTER);
      checkBox.setBackground(Color.red);
      return checkBox;
    } else {
     String str = (value == null) ? "" : value.toString();
     setForeground((row%2 == 0)?Color.red:Color.green);
        setBackground((row%2 == 0)?Color.green:Color.red);
   	return super.getTableCellRendererComponent(table,str,isSelected,hasFocus,row,column);
class abstractModel extends AbstractTableModel {
    private String[] headers = null;
    private Vector values;
     public abstractModel(String[] headers)
     this.headers = headers;
        this.values = new Vector();
    public abstractModel(String[] headers,Vector values)
        this.values = values;
     public abstractModel()
    public void addRow(Vector newRow)
        values.add(newRow);
        fireTableRowsInserted(values.size()-1, values.size()-1);
    public void setValueAt (Object o,int r,int c) {
     ((Vector)values.elementAt(r)).setElementAt(o,c);
    public void deleteRow(Vector row)
        int index = values.indexOf(row);
        values.remove(row);
        fireTableRowsDeleted(index, index);
    public boolean isCellEditable(int row, int col) {return col==0;}
    public int getRowCount() { return values.size(); }
    public int getColumnCount() { return headers.length; }
    public String getColumnName(int c) { return headers[c]; }
    public Object getValueAt(int row, int col) {
        return ((Vector)values.elementAt(row)).elementAt(col);
     /*public Class getColumnClass(int c) {
     	if (getValueAt(0, c) instanceof Boolean ) {
         try {return Class.forName("java.lang.Boolean" );} catch (Exception e) {return null;}
     	} else {
       return getValueAt(0, c).getClass();
Marsh Posté le 16-12-2003 à 14:55:38
t'es sur qu'il s'agis d'une instance de Boolean?
| public Component getTableCellRendererComponent(JTable table, Object value,boolean isSelected, boolean hasFocus,int row, int column) {  |
je pense plutot a un JCheckBox vu que c'est lui que tu ajoute a ta cellule ( si j a bien compris)
dans ce cas precis il faudrait plutot faire
Marsh Posté le 16-12-2003 à 15:26:53
Je ne pense pas que ça marche, vu que la case à l'apparence d'un checkbox (DefaultCellEditor) mais la valeur est true ou false
Marsh Posté le 16-12-2003 à 15:50:29
la valeur ca doit etre le resultat de checkbox.toString() mais c'est bien une instance de checkbox verifie avec instanceof
Marsh Posté le 16-12-2003 à 09:42:35
j'ai créé un JTable. Dans une dès colonnes, j'ai inséré un JCheckBox. Je n'ai aucun souci pour sélectionner les cases etc, par contre, je n'arrive pas à lui affecter une couleur.
J'ai utiliser setBackground mais la couleur apparait uniquement lorsque je clique sur le cb
J'ai définie la méthode getTableCellRendererComponent du DefaultRenderer du table, j'arrive à modifier les autres colonnes mais pas celle contenant le cb
Merci de votre aide
