I found the code that gives me my current coordinate location on map and to display,
<script type="text/javascript" src="http://maps.google.com/maps/api/js?sensor=true"></script>; <script type="text/javascript"> function getCoordPosition(){ if(navigator.geolocation){ navigator.geolocation.getCurrentPosition(function(position){ var latitude = position.coords.latitude; var longitude = position.coords.longitude; var altitude = position.coords.altitude; document.getElementById('geolocation').innerHTML = 'latitude : ' + latitude + '<br />' + 'longitude : ' + longitude + '<br />' + 'altitude : ' + altitude + '<br />'; }); } } function showGoogleMap(){ if (navigator.geolocation) { navigator.geolocation.getCurrentPosition(showPosition); // also monitor position as it changes navigator.geolocation.watchPosition(showPosition); } else { console.log("no geolocation support" ); }
function showPosition(position) { var lat = position.coords.latitude; var lng = position.coords.longitude; var options = { zoom: 13, center: new google.maps.LatLng(lat, lng), mapTypeId: google.maps.MapTypeId.ROADMAP }; var map = new google.maps.Map(document.getElementById("contentMap" ), options); var marker = new google.maps.Marker({ position: new google.maps.LatLng(lat, lng) }); marker.setMap(map); } } </script> </head> <body> <div id="coords"> <h1>Les coordonnées</h1> <button onClick="getCoordPosition();">Obtenir les coordonnées</button> <div id="geolocation"></div> <p> <a href="javascript:window.close();">Retour à l'article</a> </p> </div> <div id="map"> <h1>Exemple avec Google Map</h1> <button id="see_position" onClick="showGoogleMap();">Position sur Google Map</button> <div id="contentMap" style="height: 280px"></div> <p> <a href="javascript:window.close();">Retour à l'article</a> </p> </div> </body>
I wanted to change the two variables that (var latitude = position.coords.latitude; var longitude = position.coords.longitude I "ve tried var latitude = <? php echo $ lat;?> var longitude = <? php echo $ longit;?> but it does not work, how?
Marsh Posté le 21-04-2012 à 12:20:35
I have a problem in mysql data recovery
I'm following php code: connecting to the database and recovers the two variables longitude and latitude,
<?php
$sql="Select * from localiser";
$sql_result=mysql_query($sql,$connection1) or exit("Sql Error".mysql_error());
$sql_num=mysql_num_rows($sql_result);
$longit=$sql_row["Longitude"];
$latit=$sql_row["Latitude"];
} else {
marker.setMap(map);
</script>
</head>
<body>
<div id="coords">
<p>
</p>
</div>
<div id="map">
<p>
</p>
</div>
</body>
