Gros pb plus rien ne marche
Gros pb plus rien ne marche - HTML/CSS - Programmation
Marsh Posté le 06-11-2008 à 17:55:47
Bonjour à tous:
Voila mon pb: j'ai essayé d'installer les code données par ixit dans mon fichier index.php et rien ne c'est passé
alors j'ai tout supprimé et voilà ce qui ce passe: www.music-events-show.fr
Comme qui dirait ca déconne un peu
Voila mon fichier idex.php
Spoiler :
<?php
* @version  $Id: index.php 10381 2008-06-01 03:35:53Z pasamio $
* @package  Joomla
* @copyright Copyright (C) 2005 - 2008 Open Source Matters. All rights reserved.
* @license  GNU/GPL, see LICENSE.php
* Joomla! is free software. This version may have been modified pursuant
* to the GNU General Public License, and as distributed it includes or
* is derivative of works licensed under the GNU General Public License or
* other free or open source software licenses.
* See COPYRIGHT.php for copyright notices and details.
 * CREATE THE APPLICATION
 * NOTE :
$mainframe =& JFactory::getApplication('site');
 * INITIALISE THE APPLICATION
 * NOTE :
// set the language
$mainframe->initialise();
JPluginHelper::importPlugin('system');
// trigger the onAfterInitialise events
JDEBUG ? $_PROFILER->mark('afterInitialise') : null;
$mainframe->triggerEvent('onAfterInitialise');
 * ROUTE THE APPLICATION
 * NOTE :
$mainframe->route();
// authorization
$Itemid = JRequest::getInt( 'Itemid');
$mainframe->authorize($Itemid);
// trigger the onAfterRoute events
JDEBUG ? $_PROFILER->mark('afterRoute') : null;
$mainframe->triggerEvent('onAfterRoute');
 * DISPATCH THE APPLICATION
 * NOTE :
$option = JRequest::getCmd('option');
$mainframe->dispatch($option);
// trigger the onAfterDispatch events
JDEBUG ? $_PROFILER->mark('afterDispatch') : null;
$mainframe->triggerEvent('onAfterDispatch');
 * RENDER  THE APPLICATION
 * NOTE :
$mainframe->render();
// trigger the onAfterRender events
JDEBUG ? $_PROFILER->mark('afterRender') : null;
$mainframe->triggerEvent('onAfterRender');
 * RETURN THE RESPONSE
echo JResponse::toString($mainframe->getCfg('gzip'));
// Set flag that this is a parent file
define( '_JEXEC', 1 );
define('JPATH_BASE', dirname(__FILE__) );
define( 'DS', DIRECTORY_SEPARATOR );
require_once ( JPATH_BASE .DS.'includes'.DS.'defines.php' );
require_once ( JPATH_BASE .DS.'includes'.DS.'framework.php' );
JDEBUG ? $_PROFILER->mark( 'afterLoad' ) : null;
PLEASE HELP!!!!!!!!!!!!
Merci à tous de votre patience
ps: Question annexe....ou mettre les code donnée par ixit ou google analityc
Marsh Posté le 06-11-2008 à 17:58:16
c'est quoi ce code par ixit ?
c afa it appel a pas mal d'objets non standard, tu devrais avoir une librairies a inclure pour utiliser ça
edit ; en fait non, c'st pour un site joomla, c'est ce que tu as ?
Message édité par flo850 le 06-11-2008 à 17:59:09
Marsh Posté le 06-11-2008 à 18:04:15
c'est un code ixit pour piloter le site voir qui le visite...
et oui c'est un site joomla avec un template acheté
