kestion a la con definition du PHP?
kestion a la con definition du PHP? - Divers - Programmation
Marsh Posté le 07-07-2004 à 15:49:27
quelqu'un peut me dire ce que veulent dire les initiales PHP et la definition de ce script?
Marsh Posté le 07-07-2004 à 15:54:59
Personal Home Page
ou
 PHP stands for PHP: Hypertext Preprocessor. This confuses many people because the first word of the acronym is the acronym. This type of acronym is called a recursive acronym. The curious can visit Free On-Line Dictionary of Computing  for more information on recursive acronyms.
What is PHP?
PHP is a widely-used general-purpose scripting language that is especially suited for Web development and can be embedded into HTML. If you are new to PHP and want to get some idea of how it works, try the introductory tutorial. After that, check out the online manual, and the example archive sites and some of the other resources available in the links section.
http://ch.php.net/manual/en/faq.general.php
What if I were smiling and running into your arms? Would you see then what I see now?
Marsh Posté le 07-07-2004 à 16:07:11
thx :d
Marsh Posté le 07-07-2004 à 16:15:32
pour ce genre de question, google suffit. rapelle-t'en
Marsh Posté le 08-07-2004 à 02:55:51
D'après mon expérience, parceque j'ai vu les trois cygles apparaître successivement, entre Personnal Home Page et Hypertext Processor, il y a eu "Pre-processed Hypertext Page"
Marsh Posté le 09-07-2004 à 23:36:41
People Hate Perl
Créer son forum gratuit |  Mon beau blog phpBB caÿ le mal :o
Marsh Posté le 10-07-2004 à 15:32:38
Petit Homme Poilu
ou bien
Hypertext PreProcessor
Marsh Posté le 16-07-2004 à 20:38:13
Posteur de Harware Précoce :D
ok je sort ... ----> []
