/* Type names are 'TypeSize_Endien'. * name Type Size(bits) Endien * --------------- --------------- --------------- ------- * char8 char 8 none * bool8 bool 8 none * int32_little int 32 big * type32_little type32 32 big * format32_little format32 32 big * etc. * In the *SECTION*, the endieness is determined by the format.byte */
// begining of the PCF file ///////////////////////////////////////////////////
// table of contents char8[4] version = { 'p', 'c', 'f', 1 }; int32_little nTables; struct table_t { // sections type32_little type; // type of this section format32_little format; // format of this section int32_little size; // size of this section int32_little offset; // offset of this section from the begining of the file } tables[nTables];
/*** SECTION ***/ // bitmaps section (tables[i].type = PCF_BITMAPS) format32_little format; // format.id = PCF_DEFAULT_FORMAT int32 nBitmaps; // == nMetrics uint32 bitmapOffsets[nBitmaps]; uint32 bitmapSizes[GLYPHPADOPTIONS]; byte8 bitmaps[bitmapSizes[format.glyph]]; /* if (format.bit != THIS_MACHINE.bit) * BitOrderInvert(bitmaps, sizeof(bitmaps)); * if ((format.bit == format.byte) != * (THIS_MACHINE.bit == THIS_MACHINE.byte)) { * switch (1 << (THIS_MACHINE.bit == THIS_MACHINE.byte ? * format.scan : THIS_MACHINE.scan)) { * case 1: break; * case 2: TwoByteSwap(bitmaps, sizeof(bitmaps)); break; * case 4: FourByteSwap(bitmaps, sizeof(bitmaps)); break; * } * } */ /* each line of the bitmaps is aligned by 1<<format.glyph bytes. */
/*** SECTION ***/ // ink metrics secion (tables[i].type = PCF_INK_METRICS) /* this section may be omitted */ /* same as PCF_METRICS */
/*** SECTION ***/ // encodings section (tables[i].type = PCF_BDF_ENCODINGS) format32_little format; // format.id = PCF_DEFAULT_FORMAT int16 firstCol; int16 lastCol; int16 firstRow; int16 lastRow; int16 defaultCh; // default char or NO_SUCH_CHAR (= -1) int16 encodings[n]; /* |0 firstCol lastCol 255 * row\column |v v v v * -----------+--------------------- * 0->| * firstRow->|A B C D E F G H * |I J K L M N O P * |Q R S T U V W X * lastRow->|Y Z a b c d e f * 255->| * * The charcode MAKE_CHARCODE(firstCol, firstRow)'s metrics is metrics[B]. * And, encodings = { B,C,D,E,F,G, J,K,L,M,N,O, R,S,T,U,V,W, Z,a,b,c,d,e, }; * If Z == 0xffff, then the charcode MAKE_CHARCODE(firstCol, lastRow) does not * exist. */
/*** SECTION ***/ // swidths section (tables[i].type = PCF_SWIDTHS) /* this section may be omitted */ format32_little format; // format.id = PCF_DEFAULT_FORMAT int32 nSwidths; // == nMetrics int32 swidths[nSwidths];
/*** SECTION ***/ // glyph names section (tables[i].type = PCF_GLYPH_NAMES) /* this section may be omitted */ format32_little format; // format.id = PCF_DEFAULT_FORMAT int32 nGlyphNames; // == nMetrics int32 glyphNameOffsets[nGlyphNames]; // offset from &glyph_names[0] int32 glyphNamesSize; char8 glyphNames[glyphNamesSize]; // pointed by glyphNameOffsets[]
/*** SECTION ***/ // BDF style accelerators section (tables[i].type = PCF_BDF_ACCELERATORS) /* if PCF_ACCELERATORS section exists, this section is omitted. */ /* same as PCF_ACCELERATORS */
// end of the PCF file ////////////////////////////////////////////////////////
Marsh Posté le 06-01-2005 à 11:17:20
A titre documentaire, vu que j'ai pas mal galéré pour le trouver.
Le format des fichiers de police PCF.
// -*- c++ -*-
// PCF File Format from /xc/lib/font/bitmap/pcfread.c,pcfwrite.c
// miscellaneous definition ///////////////////////////////////////////////////
* char8 char 8 none
* bool8 bool 8 none
* etc.
enum type32 {
PCF_PROPERTIES = (1 << 0),
PCF_ACCELERATORS = (1 << 1),
PCF_METRICS = (1 << 2),
PCF_BITMAPS = (1 << 3),
PCF_INK_METRICS = (1 << 4),
PCF_BDF_ENCODINGS = (1 << 5),
PCF_SWIDTHS = (1 << 6),
PCF_GLYPH_NAMES = (1 << 7),
PCF_BDF_ACCELERATORS = (1 << 8),
struct format32 {
uint32 format:24; // format << 8
uint32 dummy:2; // = 0 padding << 6
uint32 scan:2; // bitmap scan unit is (1 << scan) bytes << 4
uint32 bit:1; // 0:LSBbit first, 1:MSBit first << 3
uint32 byte:1; // 0:LSByte first, 1:MSByte first << 2
uint32 glyph:2; // glyph pad is (1 << glyph) bytes << 0
// format32.format is one of the followings
#define PCF_DEFAULT_FORMAT 0
#define PCF_INKBOUNDS 2
#define PCF_ACCEL_W_INKBOUNDS 1
#define PCF_COMPRESSED_METRICS 1
struct metric_t
int16 leftSideBearing;
int16 rightSideBearing;
int16 characterWidth;
int16 ascent;
int16 descent;
int16 attributes;
struct compressedMetric_t
uint8 leftSideBearing; // - 0x80 == metric_t.leftSideBearing
uint8 rightSideBearing; // - 0x80 == metric_t.rightSideBearing
uint8 characterWidth; // - 0x80 == metric_t.characterWidth
uint8 ascent; // - 0x80 == metric_t.ascent
uint8 descent; // - 0x80 == metric_t.descent
#define GLYPHPADOPTIONS 4 // 1, 2, 4, or 8
#define MAKE_CHARCODE(row,col) (row * 256 + col)
} tables[nTables];
/*** SECTION ***/
// properties section (tables[i].type = PCF_PROPERTIES)
int32 nProps;
struct {
int32 name; // offset from &string[0]
bool8 isStringProp; // is this property is string ?
int32 value; // isStringProp ? offset from &string[0]
} props[nProps];
byte8 dummy[3 - ((sizeof(props) + 3) % 4)]; // padding
int32 stringSize;
char8 string[stringSize]; // pointed by property_t.{name,value}
/*** SECTION ***/
// old accelerators section (tables[i].type = PCF_ACCELERATORS)
/* if PCF_BDF_ACCELERATORS section exists, this section is omitted. */
// // or PCF_ACCEL_W_INKBOUNDS
bool8 noOverlap;
bool8 constantMetrics;
bool8 terminalFont;
bool8 constantWidth;
bool8 inkInside;
bool8 inkMetrics;
bool8 drawDirection;
bool8 dummy; // padding
int32 fontAscent;
int32 fontDescent;
int32 maxOverlap;
metric_t minBounds;
metric_t maxBounds;
#if format.id == PCF_ACCEL_W_INKBOUNDS
metric_t ink_minBounds;
metric_t ink_maxBounds;
#endif
/*** SECTION ***/
// metrics section (tables[i].type = PCF_METRICS)
// // or PCF_COMPRESSEDMETRICS
#if format.id == PCF_DEFAULT_FORMAT
int32 nMetrics;
metric_t metrics[nMetrics];
#else
int16 nMetrics;
compressedMetric_t cmetrics[nMetrics];
#end
/*** SECTION ***/
* case 1: break;
/*** SECTION ***/
/*** SECTION ***/
int16 firstCol;
int16 lastCol;
int16 firstRow;
int16 lastRow;
int16 encodings[n];
* 0->|
* |I J K L M N O P
* |Q R S T U V W X
* 255->|
* exist. */
/*** SECTION ***/
/*** SECTION ***/
/*** SECTION ***/
http://www.tsg.ne.jp/GANA/S/pcf2bdf/ pour ceux qui parlent japonais.
Ratures - Cuisine
