C# et les window
C# et les window - C#/.NET managed - Programmation
Marsh Posté le 26-05-2005 à 15:15:56
je veux executer ce prog
public class Calculatrice
    [Widget] Gtk.Entry entry1;
    [Widget] Gtk.Entry entry2;
    [Widget] Gtk.Label label2;
    public static void Main()
        new Calculatrice();
    public Calculatrice ()
        Application.Init();
        Glade.XML gxml = new Glade.XML ("calc.glade", "window1", null);
        gxml.Autoconnect(this);
  Console.Out.WriteLine("hello1" );
        Application.Run();
    public void Calculer(object sender, EventArgs args)
        double val1 = Double.Parse(entry1.Text);
        double val2 = Double.Parse(entry2.Text);
        label2.Text = ""+(val1 + val2);
 private void OnWindowDeleteEvent (object sender, DeleteEventArgs a)
        Application.Quit ();
        a.RetVal = true;
mais le problème c est que la fenetre aparait 2sec et disparait apres pourkoi??
