problemes de creation de sockets ! - C++ - Programmation
Marsh Posté le 20-08-2004 à 00:57:27
non c if(sock !=NULL)
pardon c une erreur d'ecriture(cette erreur n'y est pas sur mon programme donc c pas la cause du probleme !)
Marsh Posté le 20-08-2004 à 01:01:35
toutes façons delete se débrouille très bien avec des pointeurs nuls
Marsh Posté le 20-08-2004 à 11:08:14
tiens, on a du mal avec les sockets?
j'ai pas retrouvé le site de socket mais vla son code:
jettes y un oeil.
client.cpp
// Client.cpp
// Extremely simple, stream client example.
// Works in conjunction with Server.cpp.
// The program attempts to connect to the server and port
// specified on the command line. The Server program prints
// the needed information when it is started. Once connected,
// the program sends data to the server, waits for a response
// and then exits.
// Compile and link with wsock32.lib
// Pass the server name and port number on the command line.
// Example: Client MyMachineName 2000
#include <stdio.h>
#include <winsock2.h>
#pragma comment(lib, "ws2_32.lib" )
// Function prototype
void StreamClient(char *szServer, short nPort);
// Helper macro for displaying errors
#define PRINTERROR(s)	\
 	fprintf(stderr,"\n%: %d\n", s, WSAGetLastError())
void main(int argc, char **argv)
 WORD wVersionRequested = MAKEWORD(1,1);
 WSADATA wsaData;
 int nRet;
 short nPort;
 // Check for the host and port arguments
 if (argc != 3)
 	fprintf(stderr,"\nSyntax: client ServerName PortNumber\n" );
 	return;
 nPort = atoi(argv[2]);
 // Initialize WinSock and check the version
 nRet = WSAStartup(wVersionRequested, &wsaData);
 if (wsaData.wVersion != wVersionRequested)
 	fprintf(stderr,"\n Wrong version\n" );
 	return;
 // Go do the stuff a stream client does
 StreamClient(argv[1], nPort);
 // Release WinSock
 WSACleanup();
 printf("\nStream Client connecting to server: %s on port: %d",
   	szServer, nPort);
 // Find the server
    LPHOSTENT lpHostEntry;
 lpHostEntry = gethostbyname(szServer);
    if (lpHostEntry == NULL)
        PRINTERROR("gethostbyname()" );
        return;
 // Create a TCP/IP stream socket
 SOCKET	theSocket;
 theSocket = socket(AF_INET,    // Address family
        SOCK_STREAM,  	// Socket type
        IPPROTO_TCP);  // Protocol
 if (theSocket == INVALID_SOCKET)
 	PRINTERROR("socket()" );
 	return;
 // Fill in the address structure
 SOCKADDR_IN saServer;
 saServer.sin_family = AF_INET;
 saServer.sin_addr = *((LPIN_ADDR)*lpHostEntry->h_addr_list);
         	// ^ Server's address
 saServer.sin_port = htons(nPort);	// Port number from command line
 // connect to the server
 int nRet;
 nRet = connect(theSocket,    // Socket
       (LPSOCKADDR)&saServer,	// Server address
       sizeof(struct sockaddr));// Length of server address structure
 if (nRet == SOCKET_ERROR)
 	closesocket(theSocket);
 	return;
while(true)
 // Send data to the server
 char szBuf[256];
 strcpy(szBuf, "From the Client" );
 nRet = send(theSocket,    // Connected socket
   	szBuf,    	// Data buffer
   	strlen(szBuf),  	// Length of data
   	0);      // Flags
 	PRINTERROR("send()" );
 	return;
 // Wait for a reply
 nRet = recv(theSocket,    // Connected socket
   	szBuf,    	// Receive buffer
   	sizeof(szBuf),  	// Size of receive buffer
   	0);      // Flags
 	PRINTERROR("recv()" );
 	return;
 // Display the received data
 printf("\nData received: %s", szBuf);
 return;
// Server.cpp
// Extremely simple, stream server example.
// Works in conjunction with Client.cpp.
// The program sets itself up as a server using the TCP
// protoocl. It waits for data from a client, displays
// the incoming data, sends a message back to the client
// and then exits.
// Pass the port number that the server should bind() to
// on the command line. Any port number not already in use
// can be specified.
// Example: Server 2000
#include <stdio.h>
void StreamServer(short nPort);
 WSADATA wsaData;
 int nRet;
 short nPort;
 // Check for port argument
 if (argc != 2)
 	fprintf(stderr,"\nSyntax: server PortNumber\n" );
 	return;
 nPort = atoi(argv[1]);
 // Initialize WinSock and check version
 	return;
 // Do the stuff a stream server does
 StreamServer(nPort);
 // Release WinSock
 WSACleanup();
 // Create a TCP/IP stream socket to "listen" with
 SOCKET	listenSocket;
 listenSocket = socket(AF_INET,  	// Address family
 if (listenSocket == INVALID_SOCKET)
 	return;
 saServer.sin_addr.s_addr = INADDR_ANY;	// Let WinSock supply address
 saServer.sin_port = htons(nPort);  // Use port from command line
 // bind the name to the socket
 int nRet;
 nRet = bind(listenSocket,    // Socket
   	(LPSOCKADDR)&saServer,  // Our address
   	sizeof(struct sockaddr));	// Size of address structure
 	PRINTERROR("bind()" );
 	closesocket(listenSocket);
 	return;
 // This isn't normally done or required, but in this
 // example we're printing out where the server is waiting
 // so that you can connect the example client.
 int nLen;
 nLen = sizeof(SOCKADDR);
 char szBuf[256];
 nRet = gethostname(szBuf, sizeof(szBuf));
 	PRINTERROR("gethostname()" );
 	return;
 // Show the server name and port number
 printf("\nServer named %s waiting on port %d\n",
   szBuf, nPort);
 // Set the socket to listen
 printf("\nlisten()" );
 nRet = listen(listenSocket,    	// Bound socket
      SOMAXCONN);    	// Number of connection request queue
 	PRINTERROR("listen()" );
 	return;
 // Wait for an incoming request
 SOCKET	remoteSocket;
 printf("\nBlocking at accept()" );
 remoteSocket = accept(listenSocket,  	// Listening socket
        NULL,    	// Optional client address
        NULL);
 if (remoteSocket == INVALID_SOCKET)
 	PRINTERROR("accept()" );
 	return;
 while(true){
 // We're connected to a client
 // New socket descriptor returned already
 // has clients address
 // Receive data from the client
 memset(szBuf, 0, sizeof(szBuf));
 nRet = recv(remoteSocket,    	// Connected client
   	sizeof(szBuf),    	// Lenght of buffer
   	0);        // Flags
 if (nRet == INVALID_SOCKET)
 	closesocket(remoteSocket);
 	return;
 // Display received data
 // Send data back to the client
 strcpy(szBuf, "From the Server" );
 nRet = send(remoteSocket,    // Connected socket
   	strlen(szBuf),    // Lenght of data
   	0);      	// Flags
 // Close BOTH sockets before exiting
 return;
Marsh Posté le 20-08-2004 à 11:12:09
merci pour ton code mais je dois bosser en C++ en utilisant les MFC et pas le langage C
Marsh Posté le 21-08-2004 à 16:14:01
ok mon probleme est resolu juste en mettant le code suivant dans classe application :
| Code :
par contre j'ai un autre probleme. en effet quand j'ouvre deux fenetres de mon application pour tester si il ya connection entre les deux en utilisant le 127.0.0.1 il ya erreur de connection et g le message suivant : debug assertion failed.....file sockcore.cpp ...et il me demande de reessayer ou abondonner !!!
mais quand je test mon application sur un reseau local tous marche bien !!
merçi
Marsh Posté le 23-08-2004 à 16:25:14
ben tu regardes le fichier sockcore.cpp, et tu cherches l'endroit où l'assertion échoue
Marsh Posté le 23-08-2004 à 17:49:07
le probleme est dans la fonction :
| Code :
et c'est au niveau de(le debug met une fleche) :
 ASSERT(pSocket != NULL);
Marsh Posté le 20-08-2004 à 00:33:18
salut tous le monde !!
je suis entrain de faire une appli qui doit marcher en reseau. j'utilise MFC et je dervie une classe de CAsnychSocket puis j'utilise un objet de cette classe derive ds une boite de dialogue pour etablir des connections client/serveur. le probleme c ke j'arrive pas a creer mes sockets, ni pour le client ni pour le serveur
voici le code pour le serveur :
pour le client :
et a chaque tentaive : erreur de creation en tant que ...
sur un autre forum g vu qu'il faut mettre le code suivant ds la classe qui gere mon appli : CXyzApp
[cpp]
BOOL CXyzApp::InitInstance()
if (!AfxSocketInit())
AfxMessageBox(IDP_SOCKETS_INIT_FAILED);
return FALSE;
g essaye mais g le message suivant :
error C2065: 'IDP_SOCKETS_INIT_FAILED' : undeclared identifier
merci pour votre aide les gars...
