pbm de portage
pbm de portage - C++ - Programmation
Marsh Posté le 24-02-2004 à 12:58:26
bonjour à tous j'ai un réel prob sous mandrake, un prog que je doit faire marcher sous mandrake 9
je l'ai compilé avec l'instruction   gcc -c monfichier.cpp (d'abord est ce la bonne instruction ou peut etre il y en a d'autres)
il m'a donné ça
  1. kgenerator.cpp:11:32: kparts/partmanager.h: No such file or directory
  2. kgenerator.cpp:12:26: kgenerator.moc: No such file or directory
  3. kgenerator.cpp:13:25: kmessagebox.h: No such file or directory
  4. In file included from /usr/include/c++/3.2.2/backward/iostream.h:31,
  5.                  from kgenerator.cpp:14:
  6. /usr/include/c++/3.2.2/backward/backward_warning.h:32:2: warning: #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <sstream> instead of the deprecated header <strstream.h>. To disable this warning use -Wno-deprecated.
  7. kgenerator.cpp:16:29: dom/html_inline.h: No such file or directory
  8. kgenerator.cpp:17:25: kiconloader.h: No such file or directory
  9. kgenerator.cpp:18:27: kio/netaccess.h: No such file or directory
  10. kgenerator.cpp:19:31: ../tools/MetaData.h: No such file or directory
  11. kgenerator.cpp:21: syntax error before `::' token
  12. kgenerator.cpp:25: ISO C++ forbids declaration of `saveURLInHistory' with no type
  13. kgenerator.cpp:28: ISO C++ forbids declaration of `popupQListBox' with no type
  14. kgenerator.cpp:28: parse error before `(' token
  15. kgenerator.cpp:29: syntax error before `->' token
  16. kgenerator.cpp:30: syntax error before `->' token
  17. kgenerator.cpp:33: ISO C++ forbids declaration of `file' with no type
  18. kgenerator.cpp:33: parse error before `(' token
  19. kgenerator.cpp:34: syntax error before `->' token
  20. kgenerator.cpp:35: syntax error before `->' token
  21. kgenerator.cpp:36: syntax error before `->' token
  22. kgenerator.cpp:39: ISO C++ forbids declaration of `help' with no type
  23. kgenerator.cpp:39: `helpMenu' was not declared in this scope
  24. kgenerator.cpp:43: ISO C++ forbids declaration of `menu' with no type
  25. kgenerator.cpp:43: `menuBar' was not declared in this scope
  26. kgenerator.cpp:46: syntax error before `->' token
  27. kgenerator.cpp:47: syntax error before `->' token
  28. kgenerator.cpp:50: ISO C++ forbids declaration of `popupPartMenu' with no type
  29. kgenerator.cpp:50: parse error before `(' token
  30. kgenerator.cpp:51: syntax error before `->' token
  31. kgenerator.cpp:52: syntax error before `->' token
  32. kgenerator.cpp:53: syntax error before `->' token
  33. kgenerator.cpp:54: syntax error before `->' token
  34. kgenerator.cpp:55: syntax error before `->' token
  35. kgenerator.cpp:56: syntax error before `->' token
  36. kgenerator.cpp:57: syntax error before `->' token
  37. kgenerator.cpp:58: syntax error before `->' token
  38. kgenerator.cpp:59: syntax error before `->' token
  39. kgenerator.cpp:60: syntax error before `->' token
  40. kgenerator.cpp:61: syntax error before `->' token
  41. kgenerator.cpp:62: syntax error before `->' token
  42. kgenerator.cpp:66: parse error before `=' token
  43. kgenerator.cpp:69: ISO C++ forbids declaration of `htmlpart' with no type
  44. kgenerator.cpp:69: parse error before `(' token
  45. kgenerator.cpp:70: syntax error before `->' token
  46. kgenerator.cpp:71: syntax error before `->' token
  47. kgenerator.cpp:72: syntax error before `->' token
  48. kgenerator.cpp:73: syntax error before `->' token
  49. kgenerator.cpp:74: syntax error before `->' token
  50. kgenerator.cpp:75: syntax error before `->' token
  51. kgenerator.cpp:76: syntax error before `->' token
  52. kgenerator.cpp:83: parse error before `&' token
  53. kgenerator.cpp:83: ISO C++ forbids declaration of `connect' with no type
  54. kgenerator.cpp: In function `int connect(...)':
  55. kgenerator.cpp:92: `QObject' undeclared (first use this function)
  56. kgenerator.cpp:92: (Each undeclared identifier is reported only once for each function it appears in.)
  57. kgenerator.cpp:92: parse error before `)' token
  58. kgenerator.cpp:92: base operand of `->' is not a pointer
  59. kgenerator.cpp:93: `KParts' undeclared (first use this function)
  60. kgenerator.cpp:93: parse error before `::' token
  61. kgenerator.cpp:93: ISO C++ forbids declaration of `connect' with no type
  62. kgenerator.cpp: In function `int connect(...)':
  63. kgenerator.cpp:93: redefinition of `int connect(...)'
  64. kgenerator.cpp:83: `int connect(...)' previously defined here
  65. kgenerator.cpp:93: redefinition of `int connect(...)'
  66. kgenerator.cpp:83: `int connect(...)' previously defined here
  67. kgenerator.cpp:102: parse error before `)' token
  68. kgenerator.cpp:102: base operand of `->' is not a pointer
  69. kgenerator.cpp:103: parse error before `::' token
  70. kgenerator.cpp:103: ISO C++ forbids declaration of `connect' with no type
  71. kgenerator.cpp: In function `int connect(...)':
  72. kgenerator.cpp:103: redefinition of `int connect(...)'
  73. kgenerator.cpp:93: `int connect(...)' previously defined here
  74. kgenerator.cpp:103: redefinition of `int connect(...)'
  75. kgenerator.cpp:93: `int connect(...)' previously defined here
  76. kgenerator.cpp:103: redefinition of `int connect(...)'
  77. kgenerator.cpp:83: `int connect(...)' previously defined here
  78. kgenerator.cpp:113: parse error before `&' token
  79. kgenerator.cpp:113: ISO C++ forbids declaration of `connect' with no type
  80. kgenerator.cpp: In function `int connect(...)':
  81. kgenerator.cpp:113: redefinition of `int connect(...)'
  82. kgenerator.cpp:103: `int connect(...)' previously defined here
  83. kgenerator.cpp:113: redefinition of `int connect(...)'
  84. kgenerator.cpp:103: `int connect(...)' previously defined here
  85. kgenerator.cpp:113: redefinition of `int connect(...)'
  86. kgenerator.cpp:93: `int connect(...)' previously defined here
  87. kgenerator.cpp:113: redefinition of `int connect(...)'
  88. kgenerator.cpp:83: `int connect(...)' previously defined here
  89. kgenerator.cpp:120: base operand of `->' is not a pointer
  90. kgenerator.cpp:121: parse error before `&' token
  91. kgenerator.cpp:121: ISO C++ forbids declaration of `connect' with no type
  92. kgenerator.cpp: In function `int connect(...)':
  93. kgenerator.cpp:121: redefinition of `int connect(...)'
  94. kgenerator.cpp:113: `int connect(...)' previously defined here
  95. kgenerator.cpp:121: redefinition of `int connect(...)'
  96. kgenerator.cpp:113: `int connect(...)' previously defined here
  97. kgenerator.cpp:121: redefinition of `int connect(...)'
  98. kgenerator.cpp:103: `int connect(...)' previously defined here
  99. kgenerator.cpp:121: redefinition of `int connect(...)'
  100. kgenerator.cpp:93: `int connect(...)' previously defined here
  101. kgenerator.cpp:121: redefinition of `int connect(...)'
  102. kgenerator.cpp:83: `int connect(...)' previously defined here
  103. kgenerator.cpp:129: `completed' undeclared (first use this function)
  104. kgenerator.cpp:129: `SIGNAL' undeclared (first use this function)
  105. kgenerator.cpp:130: invalid use of `this' in non-member function
  106. kgenerator.cpp:131: `slotCompletelyLoaded' undeclared (first use this function)
  107. kgenerator.cpp:131: `SLOT' undeclared (first use this function)
  108. kgenerator.cpp:131: ISO C++ forbids declaration of `connect' with no type
  109. kgenerator.cpp:131: `int connect' redeclared as different kind of symbol
  110. kgenerator.cpp:121: previous declaration of `int connect(...)'
  111. kgenerator.cpp:131: initializer list being treated as compound expression
  112. kgenerator.cpp:134: ISO C++ forbids declaration of `urlDestination' with no type
  113. kgenerator.cpp:134: parse error before `(' token
  114. kgenerator.cpp:137: ISO C++ forbids declaration of `labelForbiddenLink' with no type
  115. kgenerator.cpp:137: parse error before `(' token
  116. kgenerator.cpp:138: syntax error before `->' token
  117. kgenerator.cpp:139: syntax error before `->' token
  118. kgenerator.cpp:141: ISO C++ forbids declaration of `forbiddenLinkList' with no type
  119. kgenerator.cpp:141: parse error before `(' token
  120. kgenerator.cpp:142: syntax error before `->' token
  121. kgenerator.cpp:143: syntax error before `->' token
  122. kgenerator.cpp:145: `QListBoxItem' undeclared (first use this function)
  123. kgenerator.cpp:145: parse error before `,' token
  124. kgenerator.cpp:145: ISO C++ forbids declaration of `connect' with no type
  125. kgenerator.cpp: In function `int connect(...)':
  126. kgenerator.cpp:145: `int connect(...)' redeclared as different kind of symbol
  127. kgenerator.cpp:131: previous declaration of `int connect'
  128. kgenerator.cpp:131: previous non-function declaration `int connect'
  129. kgenerator.cpp:145: conflicts with function declaration `int connect(...)'
  130. kgenerator.cpp:149: ISO C++ forbids declaration of `labelForbiddenLinkName' with no type
  131. kgenerator.cpp:149: parse error before `(' token
  132. kgenerator.cpp:150: syntax error before `->' token
  133. kgenerator.cpp:151: syntax error before `->' token
  134. kgenerator.cpp:153: ISO C++ forbids declaration of `forbiddenLinkNameList' with no type
  135. kgenerator.cpp:153: parse error before `(' token
  136. kgenerator.cpp:154: syntax error before `->' token
  137. kgenerator.cpp:155: syntax error before `->' token
  138. kgenerator.cpp:157: parse error before `,' token
  139. kgenerator.cpp:157: ISO C++ forbids declaration of `connect' with no type
  140. kgenerator.cpp: In function `int connect(...)':
  141. kgenerator.cpp:157: `int connect(...)' redeclared as different kind of symbol
  142. kgenerator.cpp:131: previous declaration of `int connect'
  143. kgenerator.cpp:131: previous non-function declaration `int connect'
  144. kgenerator.cpp:157: conflicts with function declaration `int connect(...)'
  145. kgenerator.cpp:162: ISO C++ forbids declaration of `labelExpectedLinkName' with no type
  146. kgenerator.cpp:162: parse error before `(' token
  147. kgenerator.cpp:163: syntax error before `->' token
  148. kgenerator.cpp:164: syntax error before `->' token
  149. kgenerator.cpp:166: ISO C++ forbids declaration of `expectedLinkNameList' with no type
  150. kgenerator.cpp:166: parse error before `(' token
  151. kgenerator.cpp:167: syntax error before `->' token
  152. kgenerator.cpp:168: syntax error before `->' token
  153. kgenerator.cpp:170: parse error before `,' token
  154. kgenerator.cpp:170: ISO C++ forbids declaration of `connect' with no type
  155. kgenerator.cpp: In function `int connect(...)':
  156. kgenerator.cpp:170: `int connect(...)' redeclared as different kind of symbol
  157. kgenerator.cpp:131: previous declaration of `int connect'
  158. kgenerator.cpp:131: previous non-function declaration `int connect'
  159. kgenerator.cpp:170: conflicts with function declaration `int connect(...)'
  160. kgenerator.cpp:175: ISO C++ forbids declaration of `dialogueProjet' with no type
  161. kgenerator.cpp:175: parse error before `(' token
  162. kgenerator.cpp:178: ISO C++ forbids declaration of `manualDialogView' with no type
  163. kgenerator.cpp:178: parse error before `(' token
  164. kgenerator.cpp:181: ISO C++ forbids declaration of `listGoals' with no type
  165. kgenerator.cpp:181: parse error before `(' token
  166. kgenerator.cpp:182: ISO C++ forbids declaration of `projectName' with no type
  167. kgenerator.cpp:182: parse error before `(' token
  168. kgenerator.cpp:183: ISO C++ forbids declaration of `rootUrl' with no type
  169. kgenerator.cpp:183: parse error before `(' token
  170. kgenerator.cpp:184: ISO C++ forbids declaration of `exitAutorized' with no type
  171. kgenerator.cpp:185: ISO C++ forbids declaration of `targetOnMaxDepth' with no type
  172. kgenerator.cpp:186: ISO C++ forbids declaration of `depth' with no type
  173. kgenerator.cpp:187: ISO C++ forbids declaration of `authorExample' with no type
  174. kgenerator.cpp:187: parse error before `(' token
  175. kgenerator.cpp:188: ISO C++ forbids declaration of `authorUrlExample' with no type
  176. kgenerator.cpp:188: parse error before `(' token
  177. kgenerator.cpp:189: ISO C++ forbids declaration of `titleExample' with no type
  178. kgenerator.cpp:189: parse error before `(' token
  179. kgenerator.cpp:190: ISO C++ forbids declaration of `titleUrlExample' with no type
  180. kgenerator.cpp:190: parse error before `(' token
  181. kgenerator.cpp:191: ISO C++ forbids declaration of `urlBookExample' with no type
  182. kgenerator.cpp:191: parse error before `(' token
  183. kgenerator.cpp:192: ISO C++ forbids declaration of `authorDistance' with no type
  184. kgenerator.cpp:193: ISO C++ forbids declaration of `titleDistance' with no type
  185. kgenerator.cpp:195: ISO C++ forbids declaration of `toolBar' with no type
  186. kgenerator.cpp: In function `int toolBar()':
  187. kgenerator.cpp:195: parse error before `->' token
  188. kgenerator.cpp:203: ISO C++ forbids declaration of `toolBar' with no type
  189. kgenerator.cpp: In function `int toolBar()':
  190. kgenerator.cpp:203: redefinition of `int toolBar()'
  191. kgenerator.cpp:195: `int toolBar()' previously defined here
  192. kgenerator.cpp:203: redefinition of `int toolBar()'
  193. kgenerator.cpp:195: `int toolBar()' previously defined here
  194. kgenerator.cpp:203: parse error before `->' token
  195. kgenerator.cpp:214: ISO C++ forbids declaration of `toolBar' with no type
  196. kgenerator.cpp: In function `int toolBar()':
  197. kgenerator.cpp:214: redefinition of `int toolBar()'
  198. kgenerator.cpp:203: `int toolBar()' previously defined here
  199. kgenerator.cpp:214: redefinition of `int toolBar()'
  200. kgenerator.cpp:203: `int toolBar()' previously defined here
  201. kgenerator.cpp:214: redefinition of `int toolBar()'
  202. kgenerator.cpp:195: `int toolBar()' previously defined here
  203. kgenerator.cpp:214: parse error before `->' token
  204. kgenerator.cpp:224: ISO C++ forbids declaration of `toolBar' with no type
  205. kgenerator.cpp: In function `int toolBar()':
  206. kgenerator.cpp:224: redefinition of `int toolBar()'
  207. kgenerator.cpp:214: `int toolBar()' previously defined here
  208. kgenerator.cpp:224: redefinition of `int toolBar()'
  209. kgenerator.cpp:214: `int toolBar()' previously defined here
  210. kgenerator.cpp:224: redefinition of `int toolBar()'
  211. kgenerator.cpp:203: `int toolBar()' previously defined here
  212. kgenerator.cpp:224: redefinition of `int toolBar()'
  213. kgenerator.cpp:195: `int toolBar()' previously defined here
  214. kgenerator.cpp:224: parse error before `->' token
  215. kgenerator.cpp:236: ISO C++ forbids declaration of `toolBar' with no type
  216. kgenerator.cpp: In function `int toolBar()':
  217. kgenerator.cpp:236: redefinition of `int toolBar()'
  218. kgenerator.cpp:224: `int toolBar()' previously defined here
  219. kgenerator.cpp:236: redefinition of `int toolBar()'
  220. kgenerator.cpp:224: `int toolBar()' previously defined here
  221. kgenerator.cpp:236: redefinition of `int toolBar()'
  222. kgenerator.cpp:214: `int toolBar()' previously defined here
  223. kgenerator.cpp:236: redefinition of `int toolBar()'
  224. kgenerator.cpp:203: `int toolBar()' previously defined here
  225. kgenerator.cpp:236: redefinition of `int toolBar()'
  226. kgenerator.cpp:195: `int toolBar()' previously defined here
  227. kgenerator.cpp:236: parse error before `->' token
  228. kgenerator.cpp:242: ISO C++ forbids declaration of `urlLabel' with no type
  229. kgenerator.cpp:242: parse error before `(' token
  230. kgenerator.cpp:243: ISO C++ forbids declaration of `toolBar' with no type
  231. kgenerator.cpp: In function `int toolBar()':
  232. kgenerator.cpp:243: redefinition of `int toolBar()'
  233. kgenerator.cpp:236: `int toolBar()' previously defined here
  234. kgenerator.cpp:243: redefinition of `int toolBar()'
  235. kgenerator.cpp:236: `int toolBar()' previously defined here
  236. kgenerator.cpp:243: redefinition of `int toolBar()'
  237. kgenerator.cpp:224: `int toolBar()' previously defined here
  238. kgenerator.cpp:243: redefinition of `int toolBar()'
  239. kgenerator.cpp:214: `int toolBar()' previously defined here
  240. kgenerator.cpp:243: redefinition of `int toolBar()'
  241. kgenerator.cpp:203: `int toolBar()' previously defined here
  242. kgenerator.cpp:243: redefinition of `int toolBar()'
  243. kgenerator.cpp:195: `int toolBar()' previously defined here
  244. kgenerator.cpp:243: parse error before `->' token
  245. kgenerator.cpp:246: ISO C++ forbids declaration of `statusBar' with no type
  246. kgenerator.cpp: In function `int statusBar()':
  247. kgenerator.cpp:246: parse error before `->' token
  248. kgenerator.cpp:247: ISO C++ forbids declaration of `statusBar' with no type
  249. kgenerator.cpp: In function `int statusBar()':
  250. kgenerator.cpp:247: redefinition of `int statusBar()'
  251. kgenerator.cpp:246: `int statusBar()' previously defined here
  252. kgenerator.cpp:247: redefinition of `int statusBar()'
  253. kgenerator.cpp:246: `int statusBar()' previously defined here
  254. kgenerator.cpp:247: parse error before `->' token
  255. kgenerator.cpp:250: ISO C++ forbids declaration of `showMaximized' with no type
  256. kgenerator.cpp:252: parse error before `}' token
  257. kgenerator.cpp:257: syntax error before `::' token
  258. kgenerator.cpp:261: syntax error before `::' token
  259. kgenerator.cpp:263: syntax error before `->' token
  260. kgenerator.cpp:264: syntax error before `->' token
  261. kgenerator.cpp:265: ISO C++ forbids declaration of `saveURLInHistory' with no type
  262. kgenerator.cpp:265: redefinition of `int saveURLInHistory'
  263. kgenerator.cpp:25: `int saveURLInHistory' previously defined here
  264. kgenerator.cpp:266: parse error before `}' token
  265. kgenerator.cpp:268: syntax error before `::' token
  266. kgenerator.cpp:270: ISO C++ forbids declaration of `urlDestination' with no type
  267. kgenerator.cpp:270: redefinition of `int urlDestination'
  268. kgenerator.cpp:134: `int urlDestination' previously defined here
  269. kgenerator.cpp:270: parse error before `(' token
  270. kgenerator.cpp:271: ISO C++ forbids declaration of `statusBar' with no type
  271. kgenerator.cpp: In function `int statusBar()':
  272. kgenerator.cpp:271: redefinition of `int statusBar()'
  273. kgenerator.cpp:247: `int statusBar()' previously defined here
  274. kgenerator.cpp:271: redefinition of `int statusBar()'
  275. kgenerator.cpp:247: `int statusBar()' previously defined here
  276. kgenerator.cpp:271: redefinition of `int statusBar()'
  277. kgenerator.cpp:246: `int statusBar()' previously defined here
  278. kgenerator.cpp:271: parse error before `->' token
  279. kgenerator.cpp:274: syntax error before `::' token
  280. kgenerator.cpp:296: `khtmlpart' undeclared (first use this function)
  281. kgenerator.cpp:297: parse error before `&' token
  282. kgenerator.cpp:297: ISO C++ forbids declaration of `connect' with no type
  283. kgenerator.cpp: In function `int connect(...)':
  284. kgenerator.cpp:297: `int connect(...)' redeclared as different kind of symbol
  285. kgenerator.cpp:131: previous declaration of `int connect'
  286. kgenerator.cpp:131: previous non-function declaration `int connect'
  287. kgenerator.cpp:297: conflicts with function declaration `int connect(...)'
  288. kgenerator.cpp:306: parse error before `&' token
  289. kgenerator.cpp:306: ISO C++ forbids declaration of `connect' with no type
  290. kgenerator.cpp: In function `int connect(...)':
  291. kgenerator.cpp:306: `int connect(...)' redeclared as different kind of symbol
  292. kgenerator.cpp:131: previous declaration of `int connect'
  293. kgenerator.cpp:131: previous non-function declaration `int connect'
  294. kgenerator.cpp:306: conflicts with function declaration `int connect(...)'
  295. kgenerator.cpp:312: syntax error before `::' token
  296. kgenerator.cpp:332: parse error before `&' token
  297. kgenerator.cpp:332: ISO C++ forbids declaration of `disconnect' with no type
  298. kgenerator.cpp: In function `int disconnect(...)':
  299. kgenerator.cpp:340: parse error before `&' token
  300. kgenerator.cpp:340: ISO C++ forbids declaration of `disconnect' with no type
  301. kgenerator.cpp: In function `int disconnect(...)':
  302. kgenerator.cpp:340: redefinition of `int disconnect(...)'
  303. kgenerator.cpp:332: `int disconnect(...)' previously defined here
  304. kgenerator.cpp:340: redefinition of `int disconnect(...)'
  305. kgenerator.cpp:332: `int disconnect(...)' previously defined here
  306. kgenerator.cpp:346: syntax error before `::' token
  307. kgenerator.cpp:352: syntax error before `::' token
  308. kgenerator.cpp:355: syntax error before `->' token
  309. kgenerator.cpp:356: ISO C++ forbids declaration of `saveURLInHistory' with no type
  310. kgenerator.cpp:356: redefinition of `int saveURLInHistory'
  311. kgenerator.cpp:265: `int saveURLInHistory' previously defined here
  312. kgenerator.cpp:358: parse error before `}' token
  313. kgenerator.cpp:361: syntax error before `::' token
  314. kgenerator.cpp:372: syntax error before `::' token
  315. kgenerator.cpp:383: syntax error before `::' token
  316. kgenerator.cpp:395: syntax error before `::' token
  317. kgenerator.cpp:416: ISO C++ forbids declaration of `rootUrl' with no type
  318. kgenerator.cpp:416: type mismatch with previous external decl
  319. kgenerator.cpp:183: previous external decl of `int rootUrl'
  320. kgenerator.cpp:416: base operand of `->' is not a pointer
  321. kgenerator.cpp:417: ISO C++ forbids declaration of `depth' with no type
  322. kgenerator.cpp:417: redefinition of `int depth'
  323. kgenerator.cpp:186: `int depth' previously defined here
  324. kgenerator.cpp:417: base operand of `->' is not a pointer
  325. kgenerator.cpp:418: ISO C++ forbids declaration of `exitAutorized' with no type
  326. kgenerator.cpp:418: redefinition of `int exitAutorized'
  327. kgenerator.cpp:184: `int exitAutorized' previously defined here
  328. kgenerator.cpp:418: base operand of `->' is not a pointer
  329. kgenerator.cpp:419: ISO C++ forbids declaration of `targetOnMaxDepth' with no type
  330. kgenerator.cpp:419: redefinition of `int targetOnMaxDepth'
  331. kgenerator.cpp:185: `int targetOnMaxDepth' previously defined here
  332. kgenerator.cpp:419: base operand of `->' is not a pointer
  333. kgenerator.cpp:420: ISO C++ forbids declaration of `listGoals' with no type
  334. kgenerator.cpp:420: type mismatch with previous external decl
  335. kgenerator.cpp:181: previous external decl of `int listGoals'
  336. kgenerator.cpp:420: base operand of `->' is not a pointer
  337. kgenerator.cpp:421: ISO C++ forbids declaration of `authorDistance' with no type
  338. kgenerator.cpp:421: redefinition of `int authorDistance'
  339. kgenerator.cpp:192: `int authorDistance' previously defined here
  340. kgenerator.cpp:421: base operand of `->' is not a pointer
  341. kgenerator.cpp:422: ISO C++ forbids declaration of `titleDistance' with no type
  342. kgenerator.cpp:422: redefinition of `int titleDistance'
  343. kgenerator.cpp:193: `int titleDistance' previously defined here
  344. kgenerator.cpp:422: base operand of `->' is not a pointer
  345. kgenerator.cpp:423: syntax error before `<<' token
  346. kgenerator.cpp:424: ISO C++ forbids declaration of `saveProjet' with no type
  347. kgenerator.cpp:425: parse error before `}' token
  348. kgenerator.cpp:431: syntax error before `::' token
  349. kgenerator.cpp:433: ISO C++ forbids declaration of `rootUrl' with no type
  350. kgenerator.cpp:433: redefinition of `int*rootUrl'
  351. kgenerator.cpp:416: `int*rootUrl' previously defined here
  352. kgenerator.cpp:433: `QString' undeclared (first use this function)
  353. kgenerator.cpp:433: parse error before `::' token
  354. kgenerator.cpp:434: ISO C++ forbids declaration of `authorExample' with no type
  355. kgenerator.cpp:434: type mismatch with previous external decl
  356. kgenerator.cpp:187: previous external decl of `int authorExample'
  357. kgenerator.cpp:434: parse error before `::' token
  358. kgenerator.cpp:435: ISO C++ forbids declaration of `titleExample' with no type
  359. kgenerator.cpp:435: type mismatch with previous external decl
  360. kgenerator.cpp:189: previous external decl of `int titleExample'
  361. kgenerator.cpp:435: parse error before `::' token
  362. kgenerator.cpp:436: ISO C++ forbids declaration of `urlBookExample' with no type
  363. kgenerator.cpp:436: type mismatch with previous external decl
  364. kgenerator.cpp:191: previous external decl of `int urlBookExample'
  365. kgenerator.cpp:436: parse error before `::' token
  366. kgenerator.cpp:437: ISO C++ forbids declaration of `depth' with no type
  367. kgenerator.cpp:437: redefinition of `int depth'
  368. kgenerator.cpp:417: `int depth' previously defined here
  369. kgenerator.cpp:438: ISO C++ forbids declaration of `authorDistance' with no type
  370. kgenerator.cpp:438: redefinition of `int authorDistance'
  371. kgenerator.cpp:421: `int authorDistance' previously defined here
  372. kgenerator.cpp:439: ISO C++ forbids declaration of `titleDistance' with no type
  373. kgenerator.cpp:439: redefinition of `int titleDistance'
  374. kgenerator.cpp:422: `int titleDistance' previously defined here
  375. kgenerator.cpp:440: ISO C++ forbids declaration of `exitAutorized' with no type
  376. kgenerator.cpp:440: redefinition of `int exitAutorized'
  377. kgenerator.cpp:418: `int exitAutorized' previously defined here
  378. kgenerator.cpp:441: ISO C++ forbids declaration of `targetOnMaxDepth' with no type
  379. kgenerator.cpp:441: redefinition of `int targetOnMaxDepth'
  380. kgenerator.cpp:419: `int targetOnMaxDepth' previously defined here
  381. kgenerator.cpp:442: syntax error before `->' token
  382. kgenerator.cpp:443: syntax error before `->' token
  383. kgenerator.cpp:444: syntax error before `->' token
  384. kgenerator.cpp:445: syntax error before `->' token
  385. kgenerator.cpp:447: syntax error before `*' token
  386. kgenerator.cpp:450: syntax error before `*' token
  387. kgenerator.cpp:456: ISO C++ forbids declaration of `khtmlpartAfter' with no type
  388. kgenerator.cpp:456: parse error before `*' token
  389. kgenerator.cpp:462: syntax error before `::' token
  390. kgenerator.cpp:468: syntax error before `.' token
  391. kgenerator.cpp:471: syntax error before `.' token
  392. kgenerator.cpp:477: syntax error before `.' token
  393. kgenerator.cpp:480: request for member `count' in `*listGoals', which is of non-aggregate type `int'
  394. kgenerator.cpp:482: parse error before `for'
  395. kgenerator.cpp:482: parse error before `;' token
  396. kgenerator.cpp:482: syntax error before `++' token
  397. kgenerator.cpp:486: ISO C++ forbids declaration of `count' with no type
  398. kgenerator.cpp:486: redefinition of `int count'
  399. kgenerator.cpp:480: `int count' previously defined here
  400. kgenerator.cpp:486: base operand of `->' is not a pointer
  401. kgenerator.cpp:487: parse error before `for'
  402. kgenerator.cpp:487: parse error before `;' token
  403. kgenerator.cpp:487: syntax error before `++' token
  404. kgenerator.cpp:491: ISO C++ forbids declaration of `count' with no type
  405. kgenerator.cpp:491: redefinition of `int count'
  406. kgenerator.cpp:486: `int count' previously defined here
  407. kgenerator.cpp:491: base operand of `->' is not a pointer
  408. kgenerator.cpp:492: parse error before `for'
  409. kgenerator.cpp:492: parse error before `;' token
  410. kgenerator.cpp:492: syntax error before `++' token
  411. kgenerator.cpp:496: ISO C++ forbids declaration of `count' with no type
  412. kgenerator.cpp:496: redefinition of `int count'
  413. kgenerator.cpp:491: `int count' previously defined here
  414. kgenerator.cpp:496: base operand of `->' is not a pointer
  415. kgenerator.cpp:497: parse error before `for'
  416. kgenerator.cpp:497: parse error before `;' token
  417. kgenerator.cpp:497: syntax error before `++' token
  418. kgenerator.cpp:512: syntax error before `.' token
  419. kgenerator.cpp:513: syntax error before `.' token
  420. kgenerator.cpp:514: syntax error before `.' token
  421. kgenerator.cpp:517: syntax error before `.' token
  422. kgenerator.cpp:518: syntax error before `.' token
  423. kgenerator.cpp:519: syntax error before `.' token
  424. kgenerator.cpp:522: syntax error before `.' token
  425. kgenerator.cpp:527: parse error before `=' token
  426. kgenerator.cpp:528: syntax error before `+=' token
  427. kgenerator.cpp:529: syntax error before `.' token
  428. kgenerator.cpp:530: syntax error before `.' token
  429. kgenerator.cpp:534: syntax error before `::' token
  430. kgenerator.cpp:539: syntax error before `::' token
  431. kgenerator.cpp:546: syntax error before `::' token
  432. kgenerator.cpp:553: syntax error before `::' token
  433. kgenerator.cpp:555: syntax error before `->' token
  434. kgenerator.cpp:558: syntax error before `::' token
  435. kgenerator.cpp:560: syntax error before `->' token
  436. kgenerator.cpp:563: syntax error before `::' token
  437. kgenerator.cpp:565: syntax error before `->' token
  438. kgenerator.cpp:568: syntax error before `::' token
  439. kgenerator.cpp:582: ISO C++ forbids declaration of `toolBar' with no type
  440. kgenerator.cpp: In function `int toolBar()':
  441. kgenerator.cpp:582: redefinition of `int toolBar()'
  442. kgenerator.cpp:243: `int toolBar()' previously defined here
  443. kgenerator.cpp:582: redefinition of `int toolBar()'
  444. kgenerator.cpp:243: `int toolBar()' previously defined here
  445. kgenerator.cpp:582: redefinition of `int toolBar()'
  446. kgenerator.cpp:236: `int toolBar()' previously defined here
  447. kgenerator.cpp:582: redefinition of `int toolBar()'
  448. kgenerator.cpp:224: `int toolBar()' previously defined here
  449. kgenerator.cpp:582: redefinition of `int toolBar()'
  450. kgenerator.cpp:214: `int toolBar()' previously defined here
  451. kgenerator.cpp:582: redefinition of `int toolBar()'
  452. kgenerator.cpp:203: `int toolBar()' previously defined here
  453. kgenerator.cpp:582: redefinition of `int toolBar()'
  454. kgenerator.cpp:195: `int toolBar()' previously defined here
  455. kgenerator.cpp:582: parse error before `->' token
  456. kgenerator.cpp:583: ISO C++ forbids declaration of `toolBar' with no type
  457. kgenerator.cpp: In function `int toolBar()':
  458. kgenerator.cpp:583: redefinition of `int toolBar()'
  459. kgenerator.cpp:582: `int toolBar()' previously defined here
  460. kgenerator.cpp:583: redefinition of `int toolBar()'
  461. kgenerator.cpp:582: `int toolBar()' previously defined here
  462. kgenerator.cpp:583: redefinition of `int toolBar()'
  463. kgenerator.cpp:243: `int toolBar()' previously defined here
  464. kgenerator.cpp:583: redefinition of `int toolBar()'
  465. kgenerator.cpp:236: `int toolBar()' previously defined here
  466. kgenerator.cpp:583: redefinition of `int toolBar()'
  467. kgenerator.cpp:224: `int toolBar()' previously defined here
  468. kgenerator.cpp:583: redefinition of `int toolBar()'
  469. kgenerator.cpp:214: `int toolBar()' previously defined here
  470. kgenerator.cpp:583: redefinition of `int toolBar()'
  471. kgenerator.cpp:203: `int toolBar()' previously defined here
  472. kgenerator.cpp:583: redefinition of `int toolBar()'
  473. kgenerator.cpp:195: `int toolBar()' previously defined here
  474. kgenerator.cpp:583: parse error before `->' token
  475. kgenerator.cpp:587: syntax error before `::' token
  476. kgenerator.cpp:593: ISO C++ forbids declaration of `authorUrlExample' with no type
  477. kgenerator.cpp:593: type mismatch with previous external decl
  478. kgenerator.cpp:188: previous external decl of `int authorUrlExample'
  479. kgenerator.cpp:593: `part' undeclared (first use this function)
  480. kgenerator.cpp:594: ISO C++ forbids declaration of `authorExampleStart' with no type
  481. kgenerator.cpp:595: parse error before `}' token
  482. kgenerator.cpp:599: syntax error before `::' token
  483. kgenerator.cpp:604: ISO C++ forbids declaration of `titleUrlExample' with no type
  484. kgenerator.cpp:604: type mismatch with previous external decl
  485. kgenerator.cpp:190: previous external decl of `int titleUrlExample'
  486. kgenerator.cpp:605: ISO C++ forbids declaration of `titleExampleStart' with no type
  487. kgenerator.cpp:606: parse error before `}' token
  488. kgenerator.cpp:610: syntax error before `::' token
  489. kgenerator.cpp:621: syntax error before `::' token
  490. kgenerator.cpp:627: syntax error before `=' token
  491. kgenerator.cpp:628: parse error before `=' token
  492. kgenerator.cpp:629: syntax error before `<<' token
  493. kgenerator.cpp:630: syntax error before `<<' token
  494. kgenerator.cpp:634: syntax error before `.' token
  495. kgenerator.cpp:635: syntax error before `.' token
  496. kgenerator.cpp:636: syntax error before `.' token
  497. kgenerator.cpp:637: syntax error before `.' token
  498. kgenerator.cpp:638: syntax error before `.' token
  499. kgenerator.cpp:639: syntax error before `.' token
  500. kgenerator.cpp:640: syntax error before `.' token
  501. kgenerator.cpp:643: parse error before `=' token
  502. kgenerator.cpp:644: syntax error before `<<' token
  503. kgenerator.cpp:645: syntax error before `.' token
  504. kgenerator.cpp:651: syntax error before `::' token
  505. kgenerator.cpp:653: `liste' undeclared (first use this function)
  506. kgenerator.cpp:654: syntax error before `->' token
  507. kgenerator.cpp:657: syntax error before `::' token
  508. kgenerator.cpp:659: syntax error before `->' token
  509. kgenerator.cpp:662: syntax error before `::' token
  510. kgenerator.cpp:666: syntax error before `::' token
  511. kgenerator.cpp:668: `qstring' undeclared (first use this function)
  512. kgenerator.cpp:669: parse error before `while'
  513. kgenerator.cpp:673: syntax error before `++' token
  514. kgenerator.cpp:675: syntax error before `<<' token
doit-je corriger erreur pas erreur, ou y-a-t-il une autre solution plus rapide
Marsh Posté le 24-02-2004 à 13:00:30
Tu as passé moc sur tes .h d'abord ?
brisez les rêves des gens, il en restera toujours quelque chose...  -- laissez moi troller sur discu !
Marsh Posté le 24-02-2004 à 13:03:14
Kristoph a écrit :
Deja, il faut utiliser un compilateur c++ et non pas un compilateur C : remplace gcc par g++
 [:rotflmao]
[:the real moins moins]
Marsh Posté le 24-02-2004 à 13:04:32
Grillé, mais bon, c'est une bonne habitude à prendre pour l'edition des liens de toute façon ;)
Marsh Posté le 24-02-2004 à 13:17:04
pour le gcc++, ça me donne la même chose et pour
le moc je ne sais pas comment le faire tu peut m'orienter s'il te plait
Marsh Posté le 24-02-2004 à 15:43:41
moc c'est le préprocesseur de QT. chaque programme développé sous KDE/QT doit être passé à moc avant compilation.
http://doc.trolltech.com/2.3/moc.html
J'ai un string dans l'array (Paris Hilton)
