RegExp
RegExp - Algo - Programmation
Marsh Posté le 25-03-2004 à 12:21:21
youp,
j'ai une ligne :
<div class="appliesto" id="appliesto" name="appliesto"><h3>The information in this article applies to:</h3><ul><li>Microsoft Outlook Express 6.0 SP1, when used with:<ul>  the operating system: Microsoft Windows XP SP1</ul><ul>  the operating system: Microsoft Windows Millennium Edition</ul><ul>  the operating system: Microsoft Windows 2000 SP2</ul><ul>  the operating system: Microsoft Windows 98 Second Edition</ul><ul>  the operating system: Microsoft Windows NT 4.0 SP6a</ul></li><li>Microsoft Outlook Express 6.0, when used with:<ul>  the operating system: Microsoft Windows XP</ul></li><li>Microsoft Outlook Express 5.5 for Windows 98 Second Edition</li><li>Microsoft Outlook Express 5.5 for Windows Millennium Edition</li><li>Microsoft Outlook Express 5.5 for Windows 2000</li><li>Microsoft Outlook Express 5.5 for Windows NT 4.0</li></ul></div>
dont je voudrais extraire les paires <li></li>
le problème, c'est qu'il me donne chaque fois toute la ligne comprise entre le premier <li> et le dernier </li>
mon code en VB:
  1. Private Sub Command1_Click()
  2. Dim i As Integer
  3. Dim moiur As String
  4.     moiur = "<div class=""appliesto"" id=""appliesto"" name=""appliesto""><h3>The information in this article applies to:</h3><ul><li>Microsoft Outlook Express 6.0 SP1, when used with:<ul>  the operating system: Microsoft Windows XP SP1</ul><ul>  the operating system: Microsoft Windows Millennium Edition</ul><ul>  the operating system: Microsoft Windows 2000 SP2</ul><ul>  the operating system: Microsoft Windows 98 Second Edition</ul><ul>  the operating system: Microsoft Windows NT 4.0 SP6a</ul></li><li>Microsoft Outlook Express 6.0, when used with:<ul>  the operating system: Microsoft Windows XP</ul></li><li>Microsoft Outlook Express 5.5 for Windows 98 Second Edition</li><li>Microsoft Outlook Express 5.5 for Windows Millennium Edition</li><li>Microsoft Outlook Express 5.5 for Windows 2000</li><li>Microsoft Outlook Express 5.5 for Windows NT 4.0</li></ul></div>"
  5.     Set ObjRegex = New RegExp
  6.     ObjRegex.Global = True
  7.     ObjRegex.IgnoreCase = True
  8.     ObjRegex.Pattern = "(<li>.*</li> )"
  9.     Set ColMatches = ObjRegex.Execute(moiur)
  10.     If ColMatches.Count > 0 Then
  11.         For i = 0 To ColMatches.Count - 1
  12.             DoEvents
  13.             txtResultat.Text = txtResultat.Text & vbCrLf & ColMatches(i).Value
  14.         Next
  15.     End If
  16. End Sub
je me dis que ca doit être le pattern qui est pas bon, mais je ne sais pas comment arranger ca :(
une idée ?
oui oui
Marsh Posté le 25-03-2004 à 12:40:57
peut-être (<li>.*?</li> )
Marsh Posté le 25-03-2004 à 12:42:55
oui ca marche, merci :)
tu sais m'expliquer pourquoi ?
oui oui
Marsh Posté le 25-03-2004 à 12:45:20
en fait dans la page, j'ai y a pleins de <div> et j'emploie une regexp pour isoler la div que je veux pour ensuite extraire les <li></li>
y aurait pas moyen de tout faire en une fois : trouver la bonne <div> puis extraire les <li><li> ?
oui oui
Marsh Posté le 25-03-2004 à 12:46:20
le signe * est gourmand, c'est à dire qu'il va essayer de prendre le maximum de caractères. Mettre un ? après permet de le mettre au régime et cela va donc récupérer le minimum de caractères. (? tout seul a un sens différent sinon)
Marsh Posté le 25-03-2004 à 12:54:12
yop merci :)
oui oui
Marsh Posté le 25-03-2004 à 12:54:22
Pour ton autre question, je vois pas :/
