geil ou ocz ou corsair ddr memory
geil ou ocz ou corsair ddr memory - Overclocking, Cooling & Modding
Marsh Posté le 01-11-2002 à 12:06:30
je viazs virer ma corsair pc3200 cas2 rev1.1 pour 2*256mo soit ocz soit geil soit corsair en pc3500
alors j'ai le choix entre:
GeIL PC3500 433MHz DDR ULTRA Platinum Series GL3500PU
GeIL PC3500 433MHz DDR SDRAM, Manufacture Direct Hand Picked 4.5ns GeIL GL2000 Chips with Tin Coated Platinum Copper Heat Spreader and Clear Neon Green Acrylic Case. 6 Layer PCB, 184pin, 32x8 Low Denisty, Unbuffered, CAS 2 6-3-3 1T @ DDR433, CAS 2 6-3-3 1T @ DDR400 PC3200, 2.6V-3.0V. Lifetime Warranty. Available in up to 512MB Module
GeIL PC3500 433MHz DDR Platinum Series GL3500P
GeIL PC3500 433MHz DDR SDRAM, Manufacture Direct Hand Picked 4.5ns GeIL GL2000 Chips with Tin Coated Platinum Copper Heat Spreader and Clear Neon Green Acrylic Case. 6 Layer PCB, 184pin, 32x8 Low Denisty, Unbuffered, CAS 2.5 6-3-3 2T @ DDR433, CAS 2 6-3-3 1T @ DDR400 PC3200, 2.6V-3.0V. Lifetime Warranty. Available in up to 512MB Module
OCZ DDR PC-3500 Enhanced Latency Series
OCZ Enhanced Latency PC-3500 memory using state of the art ULN technology is capable of achieving outrageous speeds of up to 434 MHz at CL2*. Add our copper heat spreader to maximize cooling and extend your rams life while increasing performance. This memory easily surpasses even the newly adopted PC-2700 standard. OCZ Enhanced Latency PC-3500 is the best performing DDR memory on the market. Period.
* Based on single module load at 2.5 volts +/- 5% DIMM Voltage. Some newer chipsets/motherboards may allow other timings (Some KT400 based boards allow up to CL2 484 1T timings at 434Mhz some 845e boards allow up to CL2 372 434Mhz.).Due to chipset and motherboard diferences on a non JEDEC standard product Make sure to check our motherboard qualification page for the exact information for your motherboard. OCZ EL DDR modules are rated to handle up to 2.8 volts with heatspreader installed.
OCZ DDR PC-3500 Performance Series
OCZ PC-3500 (DDR 433) memory is truly ahead of its time by using state of the art ULN technology to achieve outrageous speeds exceeding 433 MHz at CL2.5. Add our copper heat spreader to maximize cooling and extend your rams life while increasing performance. This memory surpasses even the newly adopted PC-2700 standard. OCZ PC-3500 is the best performing DDR memory on the market.
pour les corsair j'ai pas trouve les specs detaille :(
Marsh Posté le 01-11-2002 à 12:08:34
j'ai eu de tres bon echos sur les geil
et des avis mitigés sur ocz
en general corsair c bieng
-= In Kik00 101 I trust :o =-
Marsh Posté le 01-11-2002 à 12:13:34
j'ai pas trouve les specs detaille de la corsair
sinon elle sont totue a base de chips winbond
mais je crois que la geil ce sont des 4.5ns et du 4ns poru les autres
Marsh Posté le 01-11-2002 à 12:14:52
nop corsair c 5ns
Marsh Posté le 01-11-2002 à 12:16:15
le 4.5ns c que de la poudre aux yeux
et pour le 4ns tu as plutot voulu dire 5ns
Message édité par cpulloverclock le 01-11-2002 à 12:16:34
Marsh Posté le 01-11-2002 à 12:17:07
Marsh Posté le 01-11-2002 à 12:18:19
crotalb a écrit a écrit :
http://www.nokytech.net/news.php?id_news=1833
je trouve pas mal encore... :D
ca serait mieux de voir sur du AMD en synchro car c + bourrin
Marsh Posté le 01-11-2002 à 12:18:22
de toute facon les 3 barretes prennent autant
apres c le prix ki change
perso je prendrais de la geil
po cher et bien
Marsh Posté le 01-11-2002 à 12:18:39
c moins bien geré oui  :sarcastic:
Marsh Posté le 01-11-2002 à 12:18:59
pkoi on tape du 275 en desynchro sur du amd  :sarcastic:
Marsh Posté le 01-11-2002 à 12:19:22
meme un emushkin Pc2400 pete 225 en desynchro sur du P4
Marsh Posté le 01-11-2002 à 12:19:23
vois les perfs a 2frs  [:tkilla]
Marsh Posté le 01-11-2002 à 12:20:06
faudrait tester avec un athlon a + de 3 GHz
ca remonterait deja la BP
Marsh Posté le 01-11-2002 à 12:20:36
:D
Marsh Posté le 01-11-2002 à 14:09:37
oui desole les autre sont en 5ns et non en 4ns
sinon ocz ou geil?
ocz sont moins chere que la geil
Marsh Posté le 01-11-2002 à 14:22:47
la j'ai de la geil encore moins bien que celle cité post 1 et je la monte a 230  2/2/2/5......a 2.9V.....
donc elle tue
le pb c que je peu pas la tester a 433 paske mon proco d=ne monte pas
[HFR] AKHnoT [:akhnotpierrot] Membre de la team [HFR] BattleTeam
