?¤¤ bistro des habitués ¤¤? [ FOR OVERCLOCKERS FOUS ] - Overclocking, Cooling & Modding
Marsh Posté le 24-02-2003 à 21:36:48
| pgeo a écrit : chui stable sousPi mais a prime g des erreurs c la stabilité ou la ram ? |
ca nous fait tous ca avec les 1700+ océs
Marsh Posté le 24-02-2003 à 21:37:43
| NasdaK a écrit : |
pas moi
la mienne est super a part ke j'ai l'ecran ki bug de partou au dessus de 195
chaleur du kt333 ?
Marsh Posté le 24-02-2003 à 21:39:10
| cpulloverclock a écrit : ca doit aller |
les jx ça roule impec
ya que les classiques erreurs HI a provoqué une erreur de temps en temps mais avec la 1.5 g toujours eu ça
Marsh Posté le 24-02-2003 à 21:39:19
| NasdaK a écrit : |
jamais eu ca avec le 1700+
par contre avec le barton oui
Marsh Posté le 24-02-2003 à 21:43:47
vouzy croyez aux mecs qui nous sortent 2400 a 1.75v stable avec un 1700+?
Marsh Posté le 24-02-2003 à 21:46:23
nForceFX Chipset for Dual Socket A:
A picture is worth a thousand words, right? In this case it very might well be. We came into possession of the below graphic this weekend. It shows a dual Socket A board sporting the "nForceFX chipset". The board layout is obviously an Asus board as the "BlueMagic PCI Slot" is present on the board. Dual channel DDR is present as would be expected but the board is unique in several respects compared to boards we see today.
A nForceFX southbridge is shown as well, remember this gives you a HyperTransport connection. The addition of the AMD 8131 chip makes perfect sense as well as it is a PCI-X tunnel that is HyperTransport friendly. The 8131 would give the user the ability to use both 32-bit/33MHz PCI cards at the same time while utilizing a 64-bit/66MHz card, among other things. PATA, SATA, and SATA RAID controllers are all present as well.
This has the makings of a fine DIY server board for sure. Not to mention a fine workstation board...or possibly a really nice desktop box as it will most likely support AGP8X. ATX12V friendly too.
Marsh Posté le 24-02-2003 à 21:47:14
bon bin mon new bloc est bon pour le service plus perf etc
je ne donnerais pas de chiffres sinon vous allez vous attaquer a mon reccord
Marsh Posté le 24-02-2003 à 21:48:02
| pgeo a écrit : bon bin mon new bloc est bon pour le service plus perf etc |
essaye de battre ca
eau a 17° en full a 2611MHz
Marsh Posté le 24-02-2003 à 21:48:21
chek partit today
sinon cpull t'as pense a m'envoyer la corsair
Marsh Posté le 24-02-2003 à 21:49:06
| pierrotlemaboule a écrit : chek partit today |
elle est partie vendredie
Marsh Posté le 24-02-2003 à 21:49:22
| NasdaK a écrit : vouzy croyez aux mecs qui nous sortent 2400 a 1.75v stable avec un 1700+? |
non me faut plus 1.8 et pas 100% stable c sur
mais une serie meilleure que mon proc pk pas
Marsh Posté le 24-02-2003 à 21:50:10
ReplyMarsh Posté le 24-02-2003 à 21:51:36
ReplyMarsh Posté le 24-02-2003 à 21:52:17
| cpulloverclock a écrit : apres c a la poste de transformer l'essai |
Marsh Posté le 24-02-2003 à 21:53:16
| cpulloverclock a écrit : |
Marsh Posté le 24-02-2003 à 21:53:53
| cpulloverclock a écrit : essaye de battre ca |
en full plus haut avec cette temps d'eau !!
Marsh Posté le 24-02-2003 à 21:54:26
ReplyMarsh Posté le 24-02-2003 à 21:54:30
| pgeo a écrit : |
parce que 2400 a 1.75v pour un 17+ c'est très bien (si ROCK STABLE biensur)
Marsh Posté le 24-02-2003 à 21:55:57
| learn a écrit : |
plus que tres bien ca me parait impossible
Marsh Posté le 24-02-2003 à 21:59:11
| NasdaK a écrit : |
je fais mieux avec mon 27+ c'est un 27+ oui , mais il date de novembre avec ls news serie qu' il y a c' est possible
Marsh Posté le 24-02-2003 à 21:59:36
jamais vu une semaine de fabric aussi recente
Marsh Posté le 24-02-2003 à 22:00:11
| cpulloverclock a écrit : jamais vu une semaine de fabric aussi recente |
y a 0307
Marsh Posté le 24-02-2003 à 22:00:21
| NasdaK a écrit : |
c largement faisable
je boot a + de 2400 a 1.75v avec mon 1700+
Marsh Posté le 24-02-2003 à 22:00:47
ReplyMarsh Posté le 24-02-2003 à 22:11:17
| cpulloverclock a écrit : c largement faisable |
booter aussi je le fait mais rock stable ya un waggon
Marsh Posté le 24-02-2003 à 22:12:01
| learn a écrit : |
moi c'est rock stable
mais a 2.2v
Marsh Posté le 24-02-2003 à 22:13:01
je lai poste sur mon topic
je le post la aussi
tet que vous lavez deja vu
des finlandais
CPU: AMD Athlon XP 2100+ AUIHB0301
MB: EPOX 8RDA+ Rev. 1.1 (A3 northbridge)
MEM: 2 x 256MB GEIL PC3500 ULTRA Platinum (CL2-2-2-3)
POWER: Antec TrueBlue 480W
COOLING:
CPU: LN2 (-196°C)
NB: Water (-5°C), O4Pro Magnum NB
SB: Water (-5°C), O4Pro Magnum NB
VOLTAGES:
VCORE: 2.15V
VDD: 2.20V
VMEM: 2.90V
Marsh Posté le 24-02-2003 à 22:14:53
| cpulloverclock a écrit : lol |
http://www.excaliberpc.com/product [...] f4916f9bbc
Marsh Posté le 24-02-2003 à 23:06:42
bah voui désolé, mais c'est mon cas
il s'est pris une LAN ds les dents et un encodage de divx en 2pass ce W/E il bronche pas le proco
mais il accepte pas un vcore >1.75v
c'est tres bizzar, à part ça il roxx pas mal
edit d'ailleurs je lui ai mis quelques heures de prime95 ds la tronche, et j'ai pas eut d'erreurs
Marsh Posté le 24-02-2003 à 23:17:59
| maui a écrit : |
vi
oem y en a c'est 30 jour ![[:ddr555] [:ddr555]](https://forum-images.hardware.fr/images/perso/ddr555.gif)
Marsh Posté le 24-02-2003 à 23:19:36
| maui a écrit : |
yen a c 0
4U
Marsh Posté le 24-02-2003 à 23:26:54
| maui a écrit : voila mon P4 |
me suis tjs demande, en bas apres les step c est quoi ? Une sorte d empreinte pour l authentification ?
Marsh Posté le 24-02-2003 à 23:28:49
| Lexmark a écrit : me suis tjs demande, en bas apres les step c est quoi ? Une sorte d empreinte pour l authentification ? |
oui c leur marque je suppose, les XP et T brid en avaient aussi direct sur le core
Marsh Posté le 24-02-2003 à 23:31:49
| maui a écrit : |
ya encore ça sur les XP 0.13µ ![]()
Marsh Posté le 24-02-2003 à 23:33:36
http://www.clubic.com/n/n8010.html
Marsh Posté le 24-02-2003 à 23:34:17
| maui a écrit : |
oui j avais vu aussi sur les xp, merci
edit : mdr le p2p de Microsoft !
Reprise du premier post (génération automatique) :
Laissez vos ptits messages doux
collector
