Epox 4G4A+ => Aux chiottes !
Epox 4G4A+ => Aux chiottes ! - Overclocking, Cooling & Modding
Marsh Posté le 15-06-2002 à 03:00:35
Salut, je voudrais savoir si il y a encore quelqu'un pour me donner un petit coup de main a cette heure si sur un probleme qui me pourrit la vie la, marchi.
Comme c'est long a expliquer, j'attends de voir si quelqu'un est suceptible de me filer un coup de main.
Message édité par Doc TB le 15-06-2002 à 12:00:01
Doc_TB @ Canardpc.com
Marsh Posté le 15-06-2002 à 03:01:30
allez vas y
...In A Few Moment On Fashion TV!
Marsh Posté le 15-06-2002 à 03:04:02
je vous met le mail que je vais envoyé au constructeur.
My name is Samuel DEMEULEMEESTER, I'm the webmaster of
http://www.x86-secret.com and I need your help quickly
about lots of memory issues on an ---------. We had
this motherboard for a review since two weeks. This
motherboard was NOT sent by ------ and come from a PUBLIC
retailer store. We can't complete our tests because we
had LOTS of stability issues regarding the memory. Here
is an explanation of the problems.
1) When we use only ONE stick of memory in the FIRST bank
(first slot), all works fine and the performance are very
good with NO stability issue
2) When we use TWO sticks of memory, we ran into big (very
big) troubles. The systeme is COMPLETLY unstable, even
without any overclocking, DDR200 settings in the BIOS and
less agressive timing (2.5-7-3-3) !
Of course, we had tryed with lots of differents memory
modules and combinaisons (Kingmax DDR333 / Kingmax DDR400 /
Samsung DDR333 / Micron DDR266 / Micron DDR333) and with
lots of software configuration (windows 98/2000/XP). We also
had tryed to change the PSU (Enermax 365W), the video card
(GF4 Ti4600) and all the others PCIs cards (3Com 905C-TX,
Sb Live! 5.1 / Adaptec 29160), but the issues remains.
About the BIOS, we had tryed with the bios dated (11/04/2002)
which can be found in your website, with the version dated
21/04/2002 (originally shipped with) and with the latest
performance BIOS dated from 10/05/2002.
We have no more ideas about how to solve these issues.
We have reviewed a --------- with the same chipset without
those kind of problems.
Je prefere pas mettre le modele de la carte mere pour le moment.
Marsh Posté le 15-06-2002 à 03:05:44
Je vais devenir fou avec cette carte sans deconner... :gun:
Si ca continue, je fous un monstrueux coup de masse dessus et je publie le tout apres...
Message édité par Doc TB le 15-06-2002 à 03:06:29
Marsh Posté le 15-06-2002 à 03:07:41
si g bien compris
tu as mis une barrette sur le premier slot
et tout fonctionne nickel
tu en mets une 2em
et la ca commence a deveni instable
tu as essaye tt pleins de barrettes haut de gamme et c tjrs pareil
Marsh Posté le 15-06-2002 à 03:07:58
tu as essaye avec une barrette sur le slot 2?
Marsh Posté le 15-06-2002 à 03:09:06
ouai, ca marche
Marsh Posté le 15-06-2002 à 03:10:14
et quand tu mets 2 barrettes
meme sans overclokcing ca marche pas?
Marsh Posté le 15-06-2002 à 03:11:28
non, DDR200 en 2.5-7-3-3 ca plante au bout d'un moment. DDR266 en 2.5-7-3-3, ca plante au bout de quelques minutes. Changement de timing ou DDR333, ca plante direct au boot
Marsh Posté le 15-06-2002 à 03:12:26
et c'est FSB 100 ca encore, parceque FSB 133, j'en parle meme pas
Marsh Posté le 15-06-2002 à 03:13:45
c quoi cette daube de carte mere
pourtant l'incompatibilite n'existe plus ...
c de la marque pas de la no name
tu as essaye pleins de barrette
pas d'O/C
la cm est casse?
c une cm beta ?
Marsh Posté le 15-06-2002 à 03:18:59
A qui le dit tu ! si tu savais le constructeur....
pas d'O/C
Kingmax DDR333
Kingmax DDR400
Samsung DDR333
Micron DDR266
Micron DDR333
12 barrettes en tout
Ouai,
la cm est casse?
c une cm beta ?
C'est la deuxieme qd meme :(
Elle vient d'une boutique, pas du tout beta.
Marsh Posté le 15-06-2002 à 03:20:18
elle supporte pas ce genre de ram peut etre...
l'histoire d barrettes double faces peut etre?
elle accepte combien au maxi?
Marsh Posté le 15-06-2002 à 03:20:19
Bien sur tout les sites US qui l'ont testé ont testé avec UNE barrete... Sauf un (un site DE)... qui a eu aussi plein de problemes.... :mad:
Marsh Posté le 15-06-2002 à 03:20:29
a tt les coups c pour du p4
Marsh Posté le 15-06-2002 à 03:20:47
2 Go, testé avec simple et double face, c pareil...
Marsh Posté le 15-06-2002 à 03:20:53
c un probleme general et les autres voulaient pas se mouiller bref...
Marsh Posté le 15-06-2002 à 03:21:55
Vu la reputation du constructeur, c la honte...
Marsh Posté le 15-06-2002 à 03:24:55
asus ou abit
Marsh Posté le 15-06-2002 à 03:25:18
tu peux loader ton icq ?
Marsh Posté le 15-06-2002 à 03:28:55
mais 5min parce que je dois dodo
Marsh Posté le 15-06-2002 à 07:34:54
The Mad, cela serait sympa de donner le modéle de cette CM, surtout si elle est deja dispo à la vente en France afin que personne ne l'achete tant que ce pb n'est pas réglé.
Message édité par igor le 15-06-2002 à 08:59:12
Marsh Posté le 15-06-2002 à 11:52:12
Exact, au final, j'en ai rien a foutre de ce qu'ils peuvent bien penser. la carte en question est donc une :
=>  EPOX 4G4A+  <=
Apres quelques infos, je lache le nom parceque je suis maintenant persuadé que ce n'est pas un probleme qui est propre a ma carte, mais qui est général. Cette carte est mal concue. Completement bugguée.
Shame sur les sites genre tweaktown qui ont pas captés ca !!!
Au final voici un test allemands d'HardwareLuxx qui a eu le meme probleme :
http://www.hardwareluxx.de/cgi-bin [...] 000016&p=9
Un topic sur [H]ard|OCP :
http://www.hardforums.com/showthre [...] did=409649
Quelques phrases choisies :
- t all day...could be an immature chipset, some timing issue with the better mem controller
- I have one of these two and I can confirm it doesn't overclock for anything. I can't even run my 1.8A at 2.4. And just so you know, I got a golden 1.8A Malay 3/27/02 will do 2.9 on my friends 4BDA2+ I am at this moment pretty pissed
- Really? Your's too, eh? Thanks for getting back with your input on that...I spent a LOT of time with this 4G4A+, and it drove me nutz. I went on a two-day bender just to get it outta my head
- ARGH!!! Well, after 2 days of tinkering around with the 4G4A+, I am about to pull my hair out! Yes, when I first installed it, it was great! Now that I am doing more things with it (or lack thereof), it is really starting to annoy me...
- Right now it's running at 2.4/1.6v/DDR375, which allows me to run 3DM2K1 infinitely (or so it seems), but that limitation appears to be a RAM issue
- Tomorrow I will go and exchange the board.
Bref, Epox => Aux chiottes !! :gun: :mad:
Marsh Posté le 15-06-2002 à 12:04:03
J'ai vu dans un autre topics des gens avec cette mobos. Quelqu'un pourrait temoigner avec DEUX modules de DDR ?
Marsh Posté le 15-06-2002 à 12:07:20
et sinon en o/c par rapport a la dfi c'est comment??
it is difficult to get a man to understand something when his salary depends on his not understanding it   -   La lecture est un stratagème qui dispense de réfléchir   -   Et les Shadocks pompaient, pompaient...
Marsh Posté le 15-06-2002 à 12:10:17
Lol, deja que c'est pas stable a 100 Mhz, je te parle meme pas de l'oc. Avec une seule barrete, ca tiens pas a 2.4 Ghz sur mon 1.6A de test alors que ca rulez sur la DFI, comme sur quasiement toute les autres cartes d'ailleurs. Avec deux barrettes.... ben j'en parle meme pas...
Marsh Posté le 15-06-2002 à 12:10:57
ok :/
Marsh Posté le 15-06-2002 à 12:31:38
cf ma config : 1.6A@2.4 sur cette epox, 1.7V,ventirad intel, 55°C max (en compression divX ou seti)
RAM : 2x256 Mo DDR2700 Samsung rev D double face
réglages : VDDR = 2.7V si je me souviens bien, et RAM à 187 MHz cas 2.5 (c la ram qui limite), ratio 4:5.
Aucun problème de stabilité !!!!
par contre j'ai eu 2-3 fois un pb de boot a froid, enfin en fait je c pas trop si c la CM qui merdait ou l'écran qui s'allumait pas ... à mon avis si c un pb de CM ce sera résolu avec un bios :)
Mon bios est celui du 24 avril je crois ;)
Marsh Posté le 15-06-2002 à 12:32:45
au passage : mon 1.6A tien aussi à 2.56 GHz (160 de FSB) sans planter, mais il chauffe plus (car voltage dans les 1.8V) : 60°C max avec le ventirad intel ...
donc je préfère le laisser @2.4 ;)
Marsh Posté le 15-06-2002 à 12:37:01
:sarcastic:  dire que je voulais acheter cette cm
Marsh Posté le 15-06-2002 à 12:38:50
du bon caca epox
n'est ce pas jon
Marsh Posté le 15-06-2002 à 12:39:14
vi ca commence à craindre severe là :/
Metro-PoleRéseau A Suivre...: Annuseries|LeVillage|pErDUSA
Marsh Posté le 15-06-2002 à 12:40:29
fallait me croire quand je disais que ct caca au lieu de me traiter d'heretic
Message édité par *PIKACHU* le 15-06-2002 à 12:40:48
Marsh Posté le 15-06-2002 à 12:41:02
b'en ma 8k3a+ a pas de pb mais apparement certains en ont :/
Marsh Posté le 15-06-2002 à 12:41:09
du bon caca epox
n'est ce pas jon
gt tres content de ma 8kta-2
Marsh Posté le 15-06-2002 à 12:54:10
ca marche chez moi (cf au dessus)
donc on ne peut pas dire que c la conception de la CM qui est mauvaise, sinon ca merderait chez tout le monde !
au passage, j'ai eu une feuille volante dans la boite de la CM, disant que si on met 2 barrettes double face, faut les mettre dans des emplacements précis : DIMM1 et DIMM2.
citation :
"Supplemental
Dute to packaging issues we were unable to update the user's manual durin printing. Therefore we have included this insert notifying you.
Warning:
Once 2 pcs of double-side memory modules are used, please install them in DIMM1 and DIMM2 to prevent any unstability issue happened!"
Marsh Posté le 15-06-2002 à 12:55:45
Dis nou ou tu la jetes....
Garc. Jo
Marsh Posté le 15-06-2002 à 12:56:37
mais tout le monde utilise les slot les plus proches du cpu, a savoir dimm1 et 2!!!!
Marsh Posté le 15-06-2002 à 14:37:47
de toute facon, foutre 3 slots de ram sur une carte avec un chipset qui gére que 4 banques, c pas vraiment top...
Rhhaaaaaaa, chuis repassé a la DFI NB76 (sur mon propre systeme !!) et no soucis @ 2.53 Ghz - 2x256 Mo DDR420 CAS 2.5-2-3 ! D'la balle. je reapprends la stabilité la
Marsh Posté le 15-06-2002 à 14:40:11
t a 210 en desynchro
