question O/C e8400 et DFi x48 :vcore et compagnie - CPU - Overclocking, Cooling & Modding
Marsh Posté le 16-06-2009 à 22:13:18
UP!
j'ai besoin d'aide!
DFI LANParty UT X48-T2R
G Skill F2-8000CL5-2GBPQ
E8200
vista64 ultimate
J'arrive à rien... (pourtant j'ai monté mon opty 165 à 2.7 stable sans forcer, il est en route depuis plus de 2 ans...)
j'ai regardé sur le net et j'ai trouvé ce truc:
Des conseils pleazes, Le 10e clear cmos m'a mis la rage!
CPU Feature
Thermal Management Control: Disabled
PPM(EIST) Mode: Disabled
Limit CPUID MaxVal: Disabled
CIE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
Shutdown after AC Loss: Disabled
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Disabled(cant enable it.. doesn't this just add .5 multipliers to those CPU's that use it?
CPU Clock Ratio:8x
Target CPU Clock:3200MHZ
CPU Clock:400MHZ
Boot Up Clock:AUTO
DRAM Speed:400/1066
Target DRAM Speed:DDR2 1066
PCIE Clock: 100mhz
PCIE Slot Config: 1X 1X
CPU Spread Spectrum:[color="Navy"] Disabled
PCIE Spread Spectrum:[color="Navy"] Disabled
SATA Spread Spectrum:[color="Navy"] Disabled
Voltage Settings
CPU ViD Control:1.28750V
CPU VID Special Add:AUTO
DRAM Voltage Control:2.000V
SB Core/CPU PLL Voltage:1.510V
NB Core Voltage:1.367V
CPU VTT Voltage:1.100V
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 113
x CPU GTL 0/2 REF Volt: 100
x North Bridge GTL REF Volt: 100
DRAM Timing
Enhance Data transmitting: AUTO
Enhance Addressing: AUTO
T2 Dispatch: Disabled
Clock Setting Fine Delay
Ch1 Clock Crossing Setting: AUTO
DIMM 1 Clock fine delay: Current
DIMM 2 Clock fine delay: Current
Ch 1 Command fine delay: Current
Ch 1 Control fine delay: Current
Ch2 Clock Crossing Setting: AUTO
DIMM 3 Clock fine delay: Current
DIMM 4 Clock fine delay: Current
Ch 2 Command fine delay: Current
Ch 2 Control fine delay: Current
Ch1Ch2 CommonClock Setting: Auto
Ch1 RDCAS GNT-Chip Delay: Auto
Ch1 WRCAS GNT-Chip Delay: Auto
Ch1 Command to CS Delay: Auto
Ch2 RDCAS GNT-Chip Delay: Auto
Ch2 WRCAS GNT-Chip Delay: Auto
Ch2 Command to CS Delay: Auto
CAS Latency Time (tCL):5
RAS# to CAS# Delay (tRCD):5
RAS# Precharge (tRP):5
Precharge Delay (tRAS):15
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance LVL (Read Delay) (tRD): AUTO
Read delay phase adjust: Enter
Ch1 Read delay phase (4~0)
Channel 1 Phase 0 Pull-In: Auto
Channel 1 Phase 1 Pull-In: Auto
Channel 1 Phase 2 Pull-In: Auto
Channel 1 Phase 3 Pull-In: Auto
Channel 1 Phase 4 Pull-In: Auto
Ch2 Read delay phase (4~0)
Channel 2 Phase 0 Pull-In: Auto
Channel 2 Phase 1 Pull-In: Auto
Channel 2 Phase 2 Pull-In: Auto
Channel 2 Phase 3 Pull-In: Auto
Channel 2 Phase 4 Pull-In: Auto
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): AUTO
Ranks Write to Write (tWRWR): AUTO
Ranks Read to Read (tRDRD): AUTO
Ranks Write to Read (tWRRD): AUTO
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
Marsh Posté le 16-06-2009 à 22:17:33
C2D e8x00 tu peux monter jusqu'à maxi 1.35V pour du H24, parès c'est pas trs bon pour le proco, moi je suis @ 1.264V pour 3.8Ghz avec mon e8500...
Marsh Posté le 16-06-2009 à 22:45:01
c'est pas 1.3625 le max vcore conseiller?
et 1.45 le grand max 24 heure?
Marsh Posté le 16-06-2009 à 22:55:11
j'ai l'impression que c les réglages des timmings tarabiscotté qui pêche sur cette CM...
Foutre tout en auto. ça peut pas le faire!
MCH ODT Latency: AUTO  ???
Write to PRE Delay (tWR): AUTO  --> 12
Rank Write to Read (tWTR): AUTO  --> 12
ACT to ACT Delay (tRRD): AUTO --> 4
Read to Write Delay (tRDWR): AUTO --> 8
Ranks Write to Write (tWRWR): AUTO  ???
Ranks Read to Read (tRDRD): AUTO  ???
Ranks Write to Read (tWRRD): AUTO  ???
Read CAS# Precharge (tRTP): AUTO ---> 3
ALL PRE to Refresh: AUTO --> 5
des indices par là...
http://www.images.clunk.org.uk/rev [...] hz-8gb.png
Marsh Posté le 16-06-2009 à 23:23:43
je suis stable à 2.4 !!!!
edit: Bon je baisse les bras pour aujourd'hui....
à 400, c bon. freq Ram 800. à 500... non. (ratio 400/800) et ce même avec le x 6 !
Question: Peut on faire un CM sans enlever la pile? parce que à ce train là, je vais flinguer le truc en plastoc, c obligé!
Y a pas un possésseur de DFI dans la salle?
Je commence à comprendre pourquoi tout le monde achète du Gigabite....
Marsh Posté le 17-06-2009 à 08:33:13
c'est ta ram qui doit coincé je pense?
je suis sur DFI P35 T2RS E8400@4GHz.
Vcore 1.26v
CPU VTT 1.20v
Ram 2.0v
Tous les autres réglages par défaut!
ma ram est synchro 1:1 (c'est de la pc8000 G skill)
Marsh Posté le 17-06-2009 à 13:14:14
la loi de Murphy....
Je pense que mon raptor est dead... même en clear cmos, les fichiers de dém. ne se trouvent plus... la réinstalle échoue... La réparation ne fonctionne pas.
je commence mon opération socket 775 sur les chapeaux de roue!!!
edit:
aprés vérifs il s'agirait en fait d'un soucis de "masse défectueuse" et donc d'un courant résiduel dans le boitier... il est logique que plus rien ne fonctionnait comme il faut...
j'ai tout redémonté et je réinstalle vista...
re édit:
La panne provenait de toute vraisemblance, d'un lecteur DVD d'occas. qui était défectueux....
Ce qui provoquait cette fuite de courant et ne me permettait pas de réinstaller.
Le coupable écarté, tout rentre dans l'ordre... (je touche du bois)
je vais donc de ce pas, tester les réglages dans le bios...
Marsh Posté le 24-06-2009 à 12:52:25
Je viens d'installer des barettes G-skill Pi séries en PC 8800....
Elles tournent nickel à 400 mhz....
Que faire avant le coup de marteau sur la Carte mère?
La présence de 7 jumpers pourrait elle quelques choses à voir avec un réglage dans le bios?
Du style une position "overclocking" ? (on peut changer la valeur du voltage des ports PS/2 et usb... alors quoi d'autre?)
J'avoue être un peu découragé là...
Marsh Posté le 24-06-2009 à 20:32:23
Comment c'est possible?
quelqu'un saurait me dire ce qu'est les ; JP12, JP14 ou 15 ?
et pourquoi sur la carte mère UT X48 T2R on doit bouger des jumpers physique pour changer la frq du FSB?
Marsh Posté le 25-06-2009 à 19:34:08
Les 3 jumpers dont tu parles je pense, c'est pour passer ton fsb sur des fréquence de bases (166-266-333-400) de manière hardware.
Laisse les tous sur la gauche et tu sera en mode auto.
J'ai une LT X48 (la même sans l'imposant systeme de refroidissement) et c'est vrai que j'ai eu bcp de mal au début.
Pour les timings j'ai tout laisser sur auto, hormis ceux annoncés pour ma Ram (4-4-4-12).
Je te ferais une description complète de mon bios ce week end, mais pour l'instant, je n'ai pas ma bécane à coté.
Télécharge ca: http://img.lanparty.tw/Upload/Cata [...] 8_BIOS.pdf
http://img.lanparty.tw/Upload/Cata [...] X48_OC.pdf
c'est les descriptions des bios des LT-UT X48, ca pourra surement t'aider.
Bon courage, et t'inquiète pas c'est une tres bonne carte.
Marsh Posté le 25-06-2009 à 21:14:15
| remixbx a écrit :  Bon courage, et t'inquiète pas c'est une tres bonne carte. |
Merci.
Marsh Posté le 27-07-2008 à 19:29:36
salut
en gros
e8400 avec big typhoon
dfi lt x48 t2r
2x1 go gskill pc2 8500 (prennent 600mhz
reglage par default : il prend 3.6 ghz vstock (1.18-1.22) ---->9x400
il prend 3.8ghz vstock pas stable en bench ---->9x422
il prend 4.0ghz vcore a 1.24375 (c est la valeur la plus haute tentee avant ce post ) pas stable en bench a part spi en 10.9s)---->9x445
la question parce que :
1: etant habituer a l oc sous amd
2:je lis un pêu de tout sur le vcore
: jusqua combien de vcore on peut monter sans pour autant fusiller son proco en aircooling? je vois souvent limite 1.30 mais certain les monte a 1.54 ??
:y a pas un how to sur les fonctions du bios de cette cm quelque part?(encore plus complet que ma precedente ultra-d
