i7 920 sur DFI JR X58 T3H6 [OC] - CPU - Overclocking, Cooling & Modding
Marsh Posté le 04-03-2009 à 11:42:02
commence par regler toi meme le vcore, les options en auto c est mal...!!!
Marsh Posté le 04-03-2009 à 11:50:14
Les réglages bios que tu as lu était uniquement utilisé pour tester le Max BCLK
Les réglages utilisés pour la monter en Fréq est la suivante :
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
*** Logical Processor Setting****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Channel Interleave Setting: AUTO
Rank Interleave Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: 1N
CAS Latency Time (tCL): 8
RAS# to CAS# Delay (tRCD): 8
RAS# Precharge (tRP): 8
Precharge Delay (tRAS): 21
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID : 1.35 V
Vcore AUTO PSI : Disabled
OCP : 140A
DRAM Bus Voltage: 1.65v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add:
CPU VTT Voltage: 1.3v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.25v
IOH Analog Voltage: 1.25v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
x DIMM 1/2 ADDR/CMD Bus VREF: -00.0%
x DIMM 3/4 ADDR/CMD Bus VREF: -00.0%
x DIMM 5/6 ADDR/CMD Bus VREF: -00.0%
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Disabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 20x
BCLK/UCLK/QPI Controller Settings
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: 4.8GT/s
CPU Base Clock (BCLK): 190 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: 8x
UnCore Frequency: 16x
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Marsh Posté le 04-03-2009 à 17:34:25
Config complète :
Boitier QmicraV2
Core i7 920 2.66 GHz @ 3.80 GHz -- 1.35 V
NH-U12P SE1366  ( 2x ventilateur NF-P12 120mm en push pull )
DFI JR X58 T3H6 ( Micro-ATX )
OCZ DDR3 Platinum 3x2 Go PC3-10666 -- 1.55V @ 570MHz 1.65V ( Non optimisé pour le moment valeur max des test 8-8-8-24-1T @1.65v 1866MHz )
Alim : M12-500W
ATI Asus HD4850 + GFXChila ( 2x80mm)
Ventilateur boitier :
Papst 4412F/2GL  120mm ( en push sur le côté du Ventirad CPU en apport d'air )
NF-S12-1200    120mm ( extracteur d'air )
Autre ventilateur 120mm marque non connu a led bleu ( extracteur d'air remplacer bientôt par un autre sans led )
Séance photo de la bête :
Face Avant :
Coté Droit :
Coté Gauche :
Dos de la bête :
Vue du dessus :
Espace Ventirad très juste comme vous pouvez le voir:
P.S : Désolée pour la qualitée j'ai pas d' APN
Au passage voici le .abs profile pour ceux que ça interesse dessus y a la version stable @3.8 GHz
http://rapidshare.com/files/205391535/test.ABS.html
Nouveau petit test au passage :
Petit test avec le turbo activé donc demande moins de Bclk pour monter plus haut mais demande plus de tension :
Réglage utilisé :
Genie BIOS Setting
CPU Feature
CxE Function: Enabled
DRAM Timing
Voltage Setting
CPU VID : 1.45 V
OCP : 140A
CPU VTT Voltage: 1.35v
PPM Function: Enabled
Turbo Mode Function: Enabled
CPU Base Clock (BCLK): 191 Mhz
PCIE Clock: 110 Mhz
DRAM Frequency: 8x
http://valid.canardpc.com/show_oc.php?id=520522
Marsh Posté le 26-03-2010 à 14:11:23
Avez vous modifier le radiateur du chipset ?
Car chez moi a 3.8Ghz ca chauffe grave et ca plante....
Marsh Posté le 04-03-2009 à 11:31:31
Je viens vers vous dans l'espoir de pouvoir monter mon petit i7 920 à 4.0 GHz stable donc voici où j'en suis à l'heure actuel.
J'ai réussi effectivement a stabiliser à 3.79 GHz pour le moment pour 190 Bclk avec un Vcore de 1.35 V ( bios ) par contre ce qui me laisse perplexe est le Vdroop de malade qui se fait ou alors y a un option que j'ai pas bien transcris sachant que le Droop Scale Calibration n'existe pas dans mon bios.
Et voici les températures des CPU :
Tension appliqué ( CPU-Z + SmartGuardian )
Au passage j'ai vu ce petit .pdf avec quelque options commenté http://img.lanparty.tw/Upload/CatalogElement/JRX58T3H6965OC.pdf
Mais ce qui me parait étrange c'est que visiblement il dise :
IOH Analog Voltage = QPI BUS WORKING VOLTAGE donc à quoi ça correspond exactement ?
Et pour finir j'ai déjà effectuer un test de Max BCLK qui a donné ceci : ( screen max avant plantage )
Réglage utilisé uniquement pour le Max BCLK !
Genie BIOS Setting
CPU Feature
DRAM Timing
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 27
Voltage Setting
CPU VID Control: AUTO
CPU VID Special Add: Auto
ICH 1.5 Voltage: 1.7v
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: +11.0%
x DIMM 3/4 ADDR/CMD Bus VREF: +11.0%
x DIMM 5/6 ADDR/CMD Bus VREF: +11.0%
CPU Non-Turbo Clock Ratio: 12x
PCIE Clock: 103 Mhz
DRAM Frequency: 6x
UnCore Frequency: 12x
Ce qui me permet d'affirmer maintenant que j'ai bien quelque chose qui me bride pour passer le cap du 197bclk x 20 mais je ne sais absolument pas où intervenir ce coup-ci pour dépasser ce cap qui plante automatiquement suivi du BSOD suivant :
[color=red]"Clock Interrupt was not received on a secondary processor..."[/color]
Message édité par cobrax91310 le 04-03-2009 à 11:46:22
