[Topic Unique] Scythe Musashi VGA Cooler
Scythe Musashi VGA Cooler [Topic Unique] - Air Cooling - Overclocking, Cooling & Modding
Marsh Posté le 01-09-2008 à 16:31:13
TOPIC - SCYTHE MUSASHI VGA COOLER
http://www.scythe.co.jp/images/kama/musashi/musashi-inst02.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-inst01.jpg
Voila un ventirad trés intéressant , livré avec deux ventilos scythe de 100mm de diamètre et 12mm d'épaisseur , de quoi se monter un SLI/crossfire sans chauffe et bruit ...
il est aussi question d'un potar sur bracket PCI pour regler les ventilos indépendamment  :love:
trés bon potentiel , pour n'importe quelle carte sur le marché , sauf bien sur les GTX280 et 260 :(
Compatible :
Radeon 9***
Radeon X***
Radeon X1300
Radeon X1600
Radeon X1650
Radeon X1800
Radeon X1900
Radeon X1950
Radeon HD2600
Radeon HD2900 XT
Radeon HD3650
Radeon HD3850
Radeon HD3870
Radeon HD4850
Radeon HD4870 Series
Radeon HD4830
Radeon HD4890
Radeon HD5850
Radeon HD5870
GeForce FX5900
GeForce 6600
GeForce 6800
GeForce 7300
GeForce 7600
GeForce 7800
GeForce 7900
GeForce 8500
GeForce 8600
GeForce 8800GT ( g92 )
GeForce 8800GTS ( g92 )
GeForce 9600
GeForce 9800GTX
GeForce 9800GT
GeForce 9800GTX+
GTS250
entraxes :
http://www.comptoir-hardware.com/images/stories/_cg/entraxes_vga.png
les news :
Scythe Musashi VGA Cooler Spotted in Japanese Stores
Japanese PC cooling specialist, Scythe released the "Musashi" SCVMS-1000 VGA cooler spotted at a Japanese store. This double-fan aluminum cooler suits all popular card designs although the GeForce GTX 200 series isn't advertised.
The cooler consists of an aluminum fin arrays of unequal sizes through which pass four nickel-plated copper heatpipes, two in opposite direction of the other two. The GPU contact block from which those pipes project out itself isn't in the center. On one the other side of the fin arrays are two 100 mm, 12 mm thick PWN controlled fans which have individual speed controls provided by two knobs on an expansion bracket. These regulate the speeds of the fans between 800 and 2500 rpm (combined noise level 12.5 dB to 29.22 dB depending on the fans' rpm).
les tests :
Francais :
- http://www.caseandcooling.fr/refro [...] he-musashi
- http://www.total-tuning.net/module [...] ge&pid=246
- http://www.cowcotland.com/articles [...] sashi.html
Anglais :
- http://www.dreamwarecomputers.com/ [...] /index.htm
comparatif Ventirads GPU chez PuissancePC ( merci DivX :) ) :
- http://www.comptoir-hardware.com/a [...] s-gpu.html
Video sur lesnumeriques : http://www.lesnumeriques.com/news_id-4543.html
Message édité par Derdak le 12-09-2010 à 22:21:47
UT99 singleplayer : Project Zephon
Marsh Posté le 01-09-2008 à 16:44:26
Preum's  encore un beau rad !! lui le GFX chilla ! :D
Topic Vente
Marsh Posté le 01-09-2008 à 17:02:20
Derdak a écrit :
livré avec deux ventilo scythe de 120mm et 12cm d'epaisseur
:ouch:
"C'est pas après avoir chier dans son froc qu'il faut serrer les fesses". F. Nietzsche. 7 octobre 1870.
Marsh Posté le 01-09-2008 à 17:18:05
The pression statique de malade :ouch:
Message édité par Profil supprimé le 01-09-2008 à 17:20:24
Marsh Posté le 01-09-2008 à 17:19:23
oops , petite erreur :whistle: .... rectifiée :)
.. par contre , certains sites mentionnent les ventilos comme etant des 120mm , et d'autres des 100mm :/ qui croire ?
Marsh Posté le 01-09-2008 à 17:20:31
Ca semble être les mêmes que les ventilos scythe pour le refroidissement des disques durs ITA KAZE (100 x 100 x 12mm) donc des KAZE JYU SLIM
Message édité par Profil supprimé le 01-09-2008 à 17:22:46
Marsh Posté le 01-09-2008 à 17:21:38
ah ok , merci du renseignement ;)
Marsh Posté le 01-09-2008 à 17:23:41
Et puis tu bidouille pour mettre 2x120 au pire :whistle:
Topic Vente
Marsh Posté le 01-09-2008 à 17:24:25
un nouveau concurrent du s1?  :p
hâte de voir se qu'il vaut comparé à lui.
Marsh Posté le 01-09-2008 à 17:25:27
il est surtout moins epais ... ( avec ventilos )
Message édité par bluedragon38 le 01-09-2008 à 17:25:36
Topic Vente
Marsh Posté le 01-09-2008 à 17:27:42
la ou il faut voir , au niveau des perfs , c'est comment le placement des caloducs va agir pour le refroidissement ... ils ne traversent pas le radiateur comme sur le S1 ou le GFXchilla ...
on aura peut-etre droit a une version avec 4 caloducs plus tard :)
Message édité par Derdak le 01-09-2008 à 17:29:03
Marsh Posté le 01-09-2008 à 17:35:23
Je vois sur la boite c'est pas marqué "hd4xxx family" ...
Ils sont idiots ou quoi de sortir des radiateurs non compatibles avec les CGs récentes ??
Topic Vente
Marsh Posté le 01-09-2008 à 17:58:02
la majorité des rads deja compatibles HD3xxx sont compatibles HD4xxx ( parfois quelques modifs sont a effectuer mais en general, y'a pas trop de probleme ) .. je pense qu'il n'y aura aucun probleme pour le mettre sur les nouvelles ati ;)
Marsh Posté le 02-09-2008 à 10:48:14
Marsh Posté le 02-09-2008 à 10:49:19
Il est bien compatible avec les HD4850 et 4870
http://www.scythe.co.jp/cooler/images/musashi-400.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-inst4850s.jpg
http://www.scythe.co.jp/images/kama/musashi/musashi-300fu.jpg
Message édité par Profil supprimé le 02-09-2008 à 10:50:37
Marsh Posté le 02-09-2008 à 18:08:06
Cool ! Avec toute la panoplie pour les VRM et tout ! :love: je crois que je vais craquer sur celui ci quand il sortiras !
Ca date der sortie ... c'est quand ? :whistle:
Message édité par bluedragon38 le 02-09-2008 à 18:08:18
Topic Vente
Marsh Posté le 02-09-2008 à 18:59:37
je crois que je vais craquer aussi :love:
il semble etre le meilleur conpromis comparé au T-rad et S1 :)
pas de date annoncée malheureusement :/ enfin pour l'instant , esperons plus d'infos dans les jours a venir ..
merci Sharp pour l'info de compatibilité avec les 4xxx ;)
Marsh Posté le 03-09-2008 à 00:09:55
oui mais pas bcp de caloducs :/
Marsh Posté le 03-09-2008 à 00:29:09
Pas mal pour gagner en place et en silence, mais pour le refroidissement ça ne doit pas être le top.
Reste à voir son prix en france.
>>>FEED<<<
Marsh Posté le 03-09-2008 à 02:27:17
J'ai l'impression que les caloducs sont quand même plus gros que les S1 ! apres a voir !
Topic Vente
Marsh Posté le 09-09-2008 à 12:53:53
Marsh Posté le 09-09-2008 à 13:33:49
plus en stock :(
Mon topik hardware vide
Marsh Posté le 09-09-2008 à 13:34:11
merci a toi noobzed :jap: donc on peut deja dire entre 30-40e ..
Message édité par Derdak le 09-09-2008 à 13:34:55
Marsh Posté le 19-09-2008 à 16:53:51
drapal sur le topic pour suivre son arrivée
edit :
un test en allemagne qui apparait très prometteur. A comparer au Trad²
http://www.computerbase.de/artikel [...] enkuehler/
edit 2 : dispo vers le 3/10 ici
http://www.caseking.de/shop/catalo [...] 11048.html
Message édité par Terenas le 19-09-2008 à 17:05:39
_.·´¯)Mon feedback(¯`·._ || What shall we die for ?
Marsh Posté le 20-09-2008 à 13:32:30
ah ! merci bien Terenas :) ca se presente bien quand meme , aussi bien que le HR03 , et avec deux caloducs en moins :)
Marsh Posté le 21-09-2008 à 14:03:43
drap :p
Marsh Posté le 21-09-2008 à 14:27:12
Est ce qu'AC vont sortir un Xtrem pour hd4xxx ? ( sauf si cela a déjà été fait :whistle: ) car bon le radiateur a pas l'air tiptop VS l'extreme :(
Message édité par bluedragon38 le 21-09-2008 à 14:27:26
Topic Vente
Marsh Posté le 21-09-2008 à 14:30:00
je pense pas que un Xtrem soit prévu pour les HD48*0
Marsh Posté le 28-09-2008 à 19:54:04
[:drapo]
Marsh Posté le 28-09-2008 à 22:42:29
Selon le test indiqué plus haut les caloducs sont de 6mm , j'aurais cru a du 8mm .
En tous cas c'est un bon rad a coté du vf1000 !
Je croix que mon vf1000 va gentillement rester sur ma 8800gt et que je vais attendre avant de changer le rad de ma 4870!
Il est là !!!
Marsh Posté le 28-09-2008 à 22:54:55
Mouais  :heink:
en faite si on trouve les mêmes ventilo ailleurs le S1 est de la même épaisseur
Marsh Posté le 28-09-2008 à 23:05:05
Marsh Posté le 28-09-2008 à 23:05:49
Un peux en "retard" ton quote non ? :D
Enfin bref je vais deja voir si je peux réussi a caller mon HR03 r600 ( en le moddant bien entendu ... sur ma hd4870 ! )
Topic Vente
Marsh Posté le 28-09-2008 à 23:19:56
ce qui m'étonnes c'est qu'il ressemble comme 2 gouttes d'eau à celui qui monté sur le shuriken sauf que d'un côté on un 3 fils et de l'autre un 4 fil PWM  :sweat:  dmg
Mieux faut tard que jamais  :p  en plus ça fait genre celui qui lit les thread avant de poster (alors qu'il suffit de répondre à un post au hasard :D )
nan, c'était juste inspiré de ce que madbarth avait fait sur un S1 avec 2 de ces ventilo dessus dans un autre thread... http://img133.imageshack.us/img133/2326/5431024x768mq7.th.jpg  ça en jette hein  :sol:
sauf qu'à 11€ le ventilo + le prix d'un S1 c'est plus très rentable fasse au musashi  :sweat:
j'sais plus quoi faire :(
Message édité par crazybiscuit78 le 28-09-2008 à 23:31:48
Marsh Posté le 29-09-2008 à 10:38:28
fait plouf plouf  :lol:
Messatsu !
Marsh Posté le 29-09-2008 à 17:27:37
Faudrait encore que le Scythe Musashi sois trouvable quelque part en vente...
Marsh Posté le 06-10-2008 à 22:42:26
tjs pas de news ? :o
Marsh Posté le 07-10-2008 à 14:02:01
Personnellement j'ai reçu le Musashi pour test mais j'ai pas eu les dates de disponibilité en magasin.
Topic de vente: http://forum.hardware.fr/hfr/Achat [...] 8206_1.htm
Marsh Posté le 07-10-2008 à 15:33:18
Alors ca donne quoi réellement :love:
Topic Vente
Marsh Posté le 07-10-2008 à 16:27:31
On attend tes impressions alors guigs23 :o
