[angelfire@OCEANE linux-wlan-ng-0.2.1-pre20-gabs]$ make config
-------------- Linux WLAN Configuration Script -------------
The default responses are correct for most users.
Build Prism2.x PCMCIA Card Services (_cs) driver? (y/n) [y]: n Build Prism2 PLX9052 based PCI (_plx) adapter driver? (y/n) [n]: n Build Prism2.5 native PCI (_pci) driver? (y/n) [n]: n Build Prism2.5 USB (_usb) driver? (y/n) [y]: y
Linux source directory [/usr/src/linux]:
The kernel source tree is version 2.6.8.1-10mdk. Kernel 2.5/2.6 support is highly experimental. The current kernel build date is Wed Sep 8 17:00:52 2004.
Marsh Posté le 01-12-2004 à 18:56:16
je n'arrive pas a installer wlan j'ai des erreurs
Alternate target install root directory on host []:
Module install directory [/lib/modules/2.6.8.1-10mdk]:
It looks like you have a System V init file setup.
Prefix for build host compiler? (rarely needed) []:
Build for debugging (see doc/config.debug) (y/n) [n]:
Configuration successful.
[angelfire@OCEANE linux-wlan-ng-0.2.1-pre20-gabs]$ make all
set -e; for d in src doc man etc; do make -C $d ; done
make[1]: Entering directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src'
set -e; for d in mkmeta p80211 prism2 shared wlanctl wland nwepgen wlancfg; do make -C $d ; done
make[2]: Entering directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/mkmeta'
gcc -E -M -I../include -I/usr/src/linux/include -D__LINUX_WLAN__ ../shared/p80211types.c ../shared/p80211metamsg.c ../shared/p80211metamib.c ../shared/p80211meta.c mkmetadef.c ../shared/p80211types.c ../shared/p80211metamsg.c ../shared/p80211metamib.c ../shared/p80211meta.c mkmetastruct.c > .depend
make[2]: Leaving directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/mkmeta'
mkdir -p obj
make[2]: Entering directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/p80211'
if test ! -d /home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/p80211/../.tmp_versions; then \
cp -rf /usr/src/linux/.tmp_versions /home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/p80211/../ ; \
fi
cp: ne peut évaluer `/usr/src/linux/.tmp_versions': No such file or directory
make[2]: *** [default] Erreur 1
make[2]: Leaving directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src/p80211'
make[1]: *** [all] Erreur 2
make[1]: Leaving directory `/home/angelfire/linux-wlan-ng-0.2.1-pre20-gabs/src'
make: *** [all] Erreur 2
