Problème resolution écran sous KDE - Linux et OS Alternatifs
Marsh Posté le 22-03-2006 à 19:18:35
C/C de ton "xorg.conf", please.
Marsh Posté le 22-03-2006 à 21:03:29
locate xorg.conf
Marsh Posté le 22-03-2006 à 21:41:14
Bonjour .
Si tu es sous sous debian version sarge, c est xfree. Donc c est le fichier /etc/X11/xfree86.conf  qui va t' interesser  .
Marsh Posté le 22-03-2006 à 22:05:22
# XF86Config-4 (XFree86 X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the XF86Config-4 manual page.
# (Type "man XF86Config-4" at the shell prompt.)
# This file is automatically updated on xserver-xfree86 package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xfree86
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands as root:
#   cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
#   md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
#   dpkg-reconfigure xserver-xfree86
Section "Files"
 FontPath	"unix/:7100"  	# local font server
 # if the local font server has problems, we can fall back on these
 FontPath	"/usr/lib/X11/fonts/misc"
 FontPath	"/usr/lib/X11/fonts/cyrillic"
 FontPath	"/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath	"/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath	"/usr/lib/X11/fonts/Type1"
 FontPath	"/usr/lib/X11/fonts/CID"
 FontPath	"/usr/lib/X11/fonts/Speedo"
 FontPath	"/usr/lib/X11/fonts/100dpi"
 FontPath	"/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
 Load	"GLcore"
 Load	"bitmap"
 Load	"dbe"
 Load	"ddc"
 Load	"dri"
 Load	"extmod"
 Load	"freetype"
 Load	"glx"
 Load	"int10"
 Load	"record"
 Load	"speedo"
 Load	"type1"
 Load	"vbe"
EndSection
Section "InputDevice"
 Identifier	"Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
 Option  "XkbRules"	"xfree86"
 Option  "XkbModel"	"pc105"
 Option  "XkbLayout"	"fr"
 Option  "XkbVariant"	"pc105"
EndSection
 Identifier	"Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/input/mice"
 Option  "Protocol"  "ImPS/2"
 Option  "Emulate3Buttons"	"true"
 Option  "ZAxisMapping"  "4 5"
EndSection
Section "Device"
 Identifier	"Carte vidéo générique"
 Driver  "vesa"
EndSection
Section "Monitor"
 Identifier	"Écran générique"
 HorizSync	30-65
 VertRefresh	50-75
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier	"Default Screen"
 Device  "Carte vidéo générique"
 Monitor  "Écran générique"
 DefaultDepth	24
 SubSection "Display"
 	Depth  1
 EndSubSection
 	Depth  4
 EndSubSection
 	Depth  8
 EndSubSection
 	Depth  15
 EndSubSection
 	Depth  16
 EndSubSection
 	Depth  24
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier	"Default Layout"
 Screen  "Default Screen"
 InputDevice	"Generic Keyboard"
 InputDevice	"Configured Mouse"
EndSection
Section "DRI"
 Mode	0666
EndSection
Marsh Posté le 23-03-2006 à 11:21:58
Je dirais
mais ca doit revenir au meme...
Marsh Posté le 22-03-2006 à 19:10:23
Bonjour à tous, )
je viens d'installer kde sous debian... tout marche bien, sauf que je peux pas changer de resolution et ca reste bloqué à 600*480 (assez embetant
Je sais que ma carte monte plus car sous windows je tournais en 1200*1024...
Quelqu'un sait comment on peut changer ca (j'ai deja essayé dans la config de x, ca change rien)
Pareil pour le refraichissement, ca reste bloqué à 73Hz...
Merci d'avance
Bitonio
