[apt] problème d'installation logiciel
problème d'installation logiciel [apt] - Linux et OS Alternatifs
Marsh Posté le 09-10-2004 à 13:45:05
Je viens d'installer apt4rpm sur ma Suse, le fonctionnement étant celui d'apt les debianistes sont les bienvenus. J'essai donc d'installer divers logiciels mais je rencontre le meme type de problème:
  1. Suse:~ # apt-get -fm install kynaptic
  2. Reading Package Lists... Done
  3. Building Dependency Tree... Done
  4. The following extra packages will be installed:
  5.   SDL XFree86-libs alsa anjuta atk atk-devel esound esound-devel gconf2
  6.   gconf2-devel gdk-pixbuf glib2 glib2-devel glibc glibc-devel glibc-locale
  7.   gnome-keyring gnome-themes gnome-themes-extras gnome-vfs2 gnome-vfs2-devel
  8.   grip gtk2 gtk2-devel id3lib indent libart_lgpl libavc1394 libbonobo
  9.   libbonobo-devel libbonoboui libbonoboui-devel libcroco libgcc
  10.   libglade2-devel libgnome libgnome-devel libgnomecanvas libgnomecanvas-devel
  11.   libgnomecups libgnomeprint libgnomeprint-devel libgnomeprintui
  12.   libgnomeprintui-devel libgnomeui libgnomeui-devel libidl libidl-devel libidn
  13.   libraw1394 librsvg libstdc++ libstdc++-devel libtool libwnck-devel libxml2
  14.   libxml2-devel linc-devel openssl openssl-devel orbit2 orbit2-devel pango
  15.   pango-devel popt popt-devel shared-mime-info ulb-themes zapping zlib
  16.   zlib-devel
  17. The following packages will be upgraded
  18.   SDL XFree86-libs alsa anjuta atk esound gconf2 gdk-pixbuf glib2 glibc
  19.   glibc-devel glibc-locale gnome-themes gnome-vfs2 grip gtk2 id3lib
  20.   libart_lgpl libavc1394 libbonobo libbonoboui libgcc libgnome libgnomecanvas
  21.   libgnomeprint libgnomeprintui libgnomeui libidl libraw1394 librsvg libstdc++
  22.   libstdc++-devel libxml2 libxml2-devel openssl orbit2 pango popt zapping zlib
  23.   zlib-devel
  24. The following packages will be REPLACED:
  25.   bonobo-activation (by libbonobo)  gnome-vfs-extras (by gnome-vfs2)
  26. The following packages will be REMOVED:
  27.   bonobo gabber gnome-libs gnome-print gnomemm juk kino libglade
  28. The following NEW packages will be installed:
  29.   atk-devel esound-devel gconf2-devel glib2-devel gnome-keyring
  30.   gnome-themes-extras gnome-vfs2-devel gtk2-devel indent kynaptic
  31.   libbonobo-devel libbonoboui-devel libcroco libglade2-devel libgnome-devel
  32.   libgnomecanvas-devel libgnomecups libgnomeprint-devel libgnomeprintui-devel
  33.   libgnomeui-devel libidl-devel libidn libtool libwnck-devel linc-devel
  34.   openssl-devel orbit2-devel pango-devel popt-devel shared-mime-info
  35.   ulb-themes
  36. 41 upgraded, 31 newly installed, 2 replaced, 8 removed and 883 not upgraded.
  37. Need to get 0B/102MB of archives.
  38. After unpacking 132MB of additional disk space will be used.
  39. Do you want to continue? [Y/n] Y
  40.         XFree86-libs = 4.3.99.902-40 is needed by XFree86-libs-4.3.99.902-43.31
  41.         popt = 1.7-176 is needed by popt-1.7-176.3
  42.         zlib-devel = 1.2.1-70 is needed by zlib-devel-1.2.1-70.6
  43.         zlib = 1.2.1-70 is needed by zlib-1.2.1-70.6
  44.         openssl = 0.9.7d-15 is needed by openssl-0.9.7d-15.13
  45.         gdk-pixbuf = 0.22.0-57 | gdk-pixbuf = 0.22.0-62.4 is needed by gdk-pixbuf-0.22.0-62.7
  46.         popt-devel = 1.7-176 is needed by popt-devel-1.7-176.3
  47. E: Transaction set check failed
Comment régler le problème ?
Merci de votre aide  :hello:
Message édité par nodus le 09-10-2004 à 21:33:14
Marsh Posté le 09-10-2004 à 21:33:35
