mount sous RED HAT 8.0
mount sous RED HAT 8.0 - Linux et OS Alternatifs
Marsh Posté le 29-10-2002 à 15:36:40
Voilà j'aimerais pouvoir voir mes données sur mes autres partitions depuis linux.
mais kan je fais un mount dev/hda1 /mnt
il me dit:
mount : type fs ntfs non pris en charge par le kernel
comment que je fais alors??
Marsh Posté le 29-10-2002 à 18:07:59
ici
http://forum.hardware.fr/forum1.ph [...] aterange=1
des infos. ici aussi :
Attention RedHat 8.0 users. If you want NTFS support, you now need only install an RPM to get it.
See our RedHat Page for more details.
If you are looking for help, then have a look at our updated NTFS FAQ (Frequently Asked Questions).
IRC: Anton and FlatCap (Richard) are almost permanently in our IRC channel: #ntfs on irc.freenode.net (formerly openprojects)
Drop in, and say hello.
Status
Latest stable new NTFS kernel driver: 2.1.0
The new NTFS driver is now part of the developmental Linux kernel series (2.5.x) and the latest release is included with kernels 2.5.33 and later.
The new NTFS driver has been backported to the stable Linux kernel series (2.4.x) and it is available from our download page.
Latest stable old NTFS kernel driver: 1.1.22
The old NTFS driver is part of the stable Linux kernel series (2.4.x) and the latest release is included with kernels 2.4.18 and later.
Before reporting bugs in either NTFS kernel driver, it would be great if you could try a kernel containing the latest NTFS driver first. Thanks.
About
The goals of this project are: create a new Linux kernel driver for the NTFS file system (v1.2 and later 3.0), user space utilities (e.g. format, ntfs check, etc.) and a library to avoid code duplication and provide access to NTFS to other GPLed programs.
News
We announce every release, of NTFS and LDM, on the NTFS mailing lists. Also we create a news item on FreshMeat and SourceForge (which will appear here too). Each item, below, is linked to the complete news article.
NTFS Support for RedHat 8.0 Users  (2002-10-20)
RedHat 8.0 RPMs for NTFS support at: http://linux-ntfs.sf.net/info/redhat.html RedHat install kernels that don't support NTFS. This has caused a lot of users
NTFS 2.1.0(a) available for Linux kernel 2.4.19/2.4.20-preBK  (2002-09-01)
The backport of the new NTFS driver (version 2.1.0a) to the Linux 2.4.x kernels is now available as a patch for kernel 2.4.19. Get it from the download page! http://linux-ntfs.sf.net/downloads.html If you use BitKeeper you can get it for kernel 2.4.20-pre5 by pulling from our repository: http://linux-ntfs.bkbits.net/ntfs-2.4
Linux LDM v0.0.8 (Windows Dynamic Disks)  (2002-08-09)
Minor updates and tidyups. Low urgency.
Debian packages for Linux-NTFS 1.6.0  (2002-07-20)
Debian packages for Linux-NTFS 1.6.0 are now available for download. Alternatively you can use apt-get, dselect, or the new aptitude tool to fetch and install the packages as they are part of the Debian 3.0 distribution now that was released today.
IL Y A BIEN UN PAQUETAGE !!!
FFFF
Marsh Posté le 30-10-2002 à 18:07:20
Merci beaucoup (mais j'avais fini par trouver apres mon engueulade)
Par contre j'ai pas accès a la partoche depuis un compte non-root même apres avoir configurer /etc/fstab
Marsh Posté le 30-10-2002 à 18:09:23
humm j'ai eu deja eu c pb avec les fat 32 ss redhat 8.0 ... euh je seche car j'ai reinstallé pour pouvior avoir a nveau accés !!
FFFF
Marsh Posté le 02-11-2002 à 15:48:31
Alors j'ai fini par trouver comment il fallait faire!
Tu crée un nouvo groupe pour ton compte (ex:2001).
Et dans le /etc/fstab tu rajoute a la fin dans ta ligne gid=2001
