Xlib: connection to ":1.0" refused by server
Xlib: connection to ":1.0" refused by server - Installation - Linux et OS Alternatifs
Marsh Posté le 23-09-2003 à 20:55:17
J'essaye de recompiler libbonoboui-2.4.0-1mdk.src.rpm
mais il me sort ça en fin de listing et ej ne sais pas comment résoudre le probleme....
make  check-TESTS
make[3]: Entering directory `/usr/src/RPM/BUILD/libbonoboui-2.4.0/tests'
Xlib: No protocol specified
(lt-test-ui-auto:29531): Gtk-WARNING **: cannot open display:
FAIL: test-ui-auto
1 of 1 tests failed
make[3]: *** [check-TESTS] Erreur 1
make[3]: Leaving directory `/usr/src/RPM/BUILD/libbonoboui-2.4.0/tests'
make[2]: *** [check-am] Erreur 2
make[2]: Leaving directory `/usr/src/RPM/BUILD/libbonoboui-2.4.0/tests'
make[1]: *** [check-recursive] Erreur 1
make[1]: Leaving directory `/usr/src/RPM/BUILD/libbonoboui-2.4.0/tests'
make: *** [check-recursive] Erreur 1
error: Bad exit status from /var/tmp/rpm-tmp.82619 (%build)
