[Kernel] Probleme compilation Kernel 2.6.9
Probleme compilation Kernel 2.6.9 [Kernel] - Installation - Linux et OS Alternatifs
Marsh Posté le 04-01-2005 à 17:37:01
Coucou voila je me lance dans la compilation de mon Kernel
Mais j'obtient à chaque foix un Kernel panic "UFS unable to mount Root FS"
Voila comment je procede :
1. cd /usr/src/
2. tar xvzf linux-2.6.9.tar.gz
3. ln -sfn linux-2.6.9 linux
4. cd linux
5. make menuconfig
6. je fait ma config
7. make
8. make modules_install
9. cp arch/x86_64/boot/bzimage /boot/vmlinuz-2.6.9
10. cp System.map /boot/System.map-2.6.9
11. je met à jours mon fichier GRUB
Ma distribution DEBIAN_Sarge AMD64
voici mes differants fichiers
.config (/usr/src/linux )
# Automatically generated make config: don't edit
CONFIG_X86_64=y
CONFIG_64BIT=y
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_X86_CMPXCHG=y
CONFIG_EARLY_PRINTK=y
CONFIG_HPET_TIMER=y
# CONFIG_HPET_EMULATE_RTC is not set
CONFIG_GENERIC_ISA_DMA=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_CLEAN_COMPILE=y
CONFIG_BROKEN_ON_SMP=y
# General setup
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
CONFIG_SYSCTL=y
# CONFIG_AUDIT is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_HOTPLUG=y
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_EMBEDDED=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_OBSOLETE_MODPARM=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
# Processor type and features
CONFIG_MK8=y
# CONFIG_MPSC is not set
# CONFIG_GENERIC_CPU is not set
CONFIG_X86_L1_CACHE_BYTES=64
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_X86_TSC=y
CONFIG_X86_GOOD_APIC=y
CONFIG_MICROCODE=m
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
CONFIG_X86_IO_APIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_MTRR=y
# CONFIG_SMP is not set
# CONFIG_PREEMPT is not set
CONFIG_GART_IOMMU=y
CONFIG_SWIOTLB=y
CONFIG_X86_MCE=y
# Power management options
CONFIG_PM=y
# CONFIG_SOFTWARE_SUSPEND is not set
# ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI=y
CONFIG_ACPI_BOOT=y
CONFIG_ACPI_INTERPRETER=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SLEEP_PROC_FS=y
CONFIG_ACPI_AC=m
CONFIG_ACPI_BATTERY=m
CONFIG_ACPI_BUTTON=m
CONFIG_ACPI_FAN=m
CONFIG_ACPI_PROCESSOR=m
CONFIG_ACPI_THERMAL=m
CONFIG_ACPI_ASUS=m
CONFIG_ACPI_TOSHIBA=m
# CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_BUS=y
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_PCI=y
CONFIG_ACPI_SYSTEM=y
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_PROC_INTF=m
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=m
# CONFIG_CPU_FREQ_24_API is not set
CONFIG_CPU_FREQ_TABLE=m
# CPUFreq processor drivers
CONFIG_X86_POWERNOW_K8=m
# Bus options (PCI etc.)
CONFIG_PCI=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
CONFIG_PCI_MSI=y
CONFIG_PCI_LEGACY_PROC=y
CONFIG_PCI_NAMES=y
# PCMCIA/CardBus support
CONFIG_PCMCIA=m
# CONFIG_PCMCIA_DEBUG is not set
CONFIG_YENTA=m
CONFIG_CARDBUS=y
CONFIG_PD6729=m
CONFIG_I82092=m
CONFIG_TCIC=m
# PCI Hotplug Support
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats / Emulations
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_MISC=m
CONFIG_IA32_EMULATION=y
CONFIG_IA32_AOUT=y
CONFIG_COMPAT=y
CONFIG_SYSVIPC_COMPAT=y
CONFIG_UID16=y
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=m
# Memory Technology Devices (MTD)
CONFIG_MTD=m
# CONFIG_MTD_DEBUG is not set
CONFIG_MTD_PARTITIONS=y
CONFIG_MTD_CONCAT=m
CONFIG_MTD_REDBOOT_PARTS=m
# CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
# CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
CONFIG_FTL=m
CONFIG_NFTL=m
CONFIG_NFTL_RW=y
CONFIG_INFTL=m
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
CONFIG_MTD_JEDECPROBE=m
CONFIG_MTD_GEN_PROBE=m
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=m
CONFIG_MTD_CFI_AMDSTD=m
CONFIG_MTD_CFI_AMDSTD_RETRY=0
CONFIG_MTD_CFI_STAA=m
CONFIG_MTD_CFI_UTIL=m
CONFIG_MTD_RAM=m
CONFIG_MTD_ROM=m
CONFIG_MTD_ABSENT=m
# Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=m
CONFIG_MTD_PHYSMAP_START=0x8000000
CONFIG_MTD_PHYSMAP_LEN=0x4000000
CONFIG_MTD_PHYSMAP_BANKWIDTH=2
CONFIG_MTD_PNC2000=m
CONFIG_MTD_SC520CDP=m
CONFIG_MTD_NETSC520=m
CONFIG_MTD_SBC_GXX=m
CONFIG_MTD_ELAN_104NC=m
CONFIG_MTD_SCx200_DOCFLASH=m
# CONFIG_MTD_AMD76XROM is not set
# CONFIG_MTD_ICHXROM is not set
# CONFIG_MTD_SCB2_FLASH is not set
CONFIG_MTD_NETtel=m
CONFIG_MTD_DILNETPC=m
CONFIG_MTD_DILNETPC_BOOTSIZE=0x80000
# CONFIG_MTD_L440GX is not set
CONFIG_MTD_PCI=m
# Self-contained MTD device drivers
CONFIG_MTD_PMC551=m
# CONFIG_MTD_PMC551_BUGFIX is not set
# CONFIG_MTD_PMC551_DEBUG is not set
CONFIG_MTD_SLRAM=m
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLKMTD=m
# Disk-On-Chip Device Drivers
CONFIG_MTD_DOC2000=m
CONFIG_MTD_DOC2001=m
CONFIG_MTD_DOC2001PLUS=m
CONFIG_MTD_DOCPROBE=m
CONFIG_MTD_DOCECC=m
# CONFIG_MTD_DOCPROBE_ADVANCED is not set
CONFIG_MTD_DOCPROBE_ADDRESS=0
# NAND Flash Device Drivers
CONFIG_MTD_NAND=m
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
CONFIG_MTD_NAND_IDS=m
CONFIG_MTD_NAND_DISKONCHIP=m
# CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED is not set
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
# CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE is not set
# Parallel port support
CONFIG_PARPORT=m
CONFIG_PARPORT_PC=m
CONFIG_PARPORT_PC_CML1=m
CONFIG_PARPORT_SERIAL=m
CONFIG_PARPORT_PC_FIFO=y
# CONFIG_PARPORT_PC_SUPERIO is not set
CONFIG_PARPORT_PC_PCMCIA=m
# CONFIG_PARPORT_OTHER is not set
CONFIG_PARPORT_1284=y
# Plug and Play support
# Block devices
CONFIG_BLK_DEV_FD=m
CONFIG_PARIDE=m
CONFIG_PARIDE_PARPORT=m
# Parallel IDE high-level drivers
CONFIG_PARIDE_PD=m
CONFIG_PARIDE_PCD=m
CONFIG_PARIDE_PF=m
CONFIG_PARIDE_PT=m
CONFIG_PARIDE_PG=m
# Parallel IDE protocol modules
CONFIG_PARIDE_ATEN=m
CONFIG_PARIDE_BPCK=m
CONFIG_PARIDE_COMM=m
CONFIG_PARIDE_DSTR=m
CONFIG_PARIDE_FIT2=m
CONFIG_PARIDE_FIT3=m
CONFIG_PARIDE_EPAT=m
# CONFIG_PARIDE_EPATC8 is not set
CONFIG_PARIDE_EPIA=m
CONFIG_PARIDE_FRIQ=m
CONFIG_PARIDE_FRPW=m
CONFIG_PARIDE_KBIC=m
CONFIG_PARIDE_KTTI=m
CONFIG_PARIDE_ON20=m
CONFIG_PARIDE_ON26=m
CONFIG_BLK_CPQ_DA=m
CONFIG_BLK_CPQ_CISS_DA=m
CONFIG_CISS_SCSI_TAPE=y
CONFIG_BLK_DEV_DAC960=m
CONFIG_BLK_DEV_UMEM=m
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_SX8=m
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_SIZE=65536
CONFIG_BLK_DEV_INITRD=y
CONFIG_LBD=y
# ATA/ATAPI/MFM/RLL support
CONFIG_IDE=m
CONFIG_BLK_DEV_IDE=m
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_IDE_SATA is not set
# CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=m
# CONFIG_IDEDISK_MULTI_MODE is not set
CONFIG_BLK_DEV_IDECS=m
CONFIG_BLK_DEV_IDECD=m
CONFIG_BLK_DEV_IDETAPE=m
CONFIG_BLK_DEV_IDEFLOPPY=m
CONFIG_BLK_DEV_IDESCSI=m
# CONFIG_IDE_TASK_IOCTL is not set
# CONFIG_IDE_TASKFILE_IO is not set
# IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=m
CONFIG_BLK_DEV_CMD640=y
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
# CONFIG_BLK_DEV_OFFBOARD is not set
CONFIG_BLK_DEV_GENERIC=m
CONFIG_BLK_DEV_OPTI621=m
CONFIG_BLK_DEV_RZ1000=m
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_ADMA=y
CONFIG_BLK_DEV_AEC62XX=m
CONFIG_BLK_DEV_ALI15X3=m
# CONFIG_WDC_ALI15X3 is not set
CONFIG_BLK_DEV_AMD74XX=m
CONFIG_BLK_DEV_ATIIXP=m
CONFIG_BLK_DEV_CMD64X=m
CONFIG_BLK_DEV_TRIFLEX=m
CONFIG_BLK_DEV_CY82C693=m
CONFIG_BLK_DEV_CS5520=m
CONFIG_BLK_DEV_CS5530=m
CONFIG_BLK_DEV_HPT34X=m
# CONFIG_HPT34X_AUTODMA is not set
CONFIG_BLK_DEV_HPT366=m
CONFIG_BLK_DEV_SC1200=m
CONFIG_BLK_DEV_PIIX=m
CONFIG_BLK_DEV_NS87415=m
CONFIG_BLK_DEV_PDC202XX_OLD=m
CONFIG_PDC202XX_BURST=y
CONFIG_BLK_DEV_PDC202XX_NEW=m
CONFIG_PDC202XX_FORCE=y
CONFIG_BLK_DEV_SVWKS=m
CONFIG_BLK_DEV_SIIMAGE=m
CONFIG_BLK_DEV_SIS5513=m
CONFIG_BLK_DEV_SLC90E66=m
CONFIG_BLK_DEV_TRM290=m
CONFIG_BLK_DEV_VIA82CXXX=m
# CONFIG_IDE_ARM is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_IDEDMA_IVB is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_BLK_DEV_HD is not set
# SCSI device support
CONFIG_SCSI=m
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST=m
CONFIG_CHR_DEV_OSST=m
CONFIG_BLK_DEV_SR=m
# CONFIG_BLK_DEV_SR_VENDOR is not set
CONFIG_CHR_DEV_SG=m
CONFIG_CHR_DEV_SCH=m
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
# SCSI Transport Attributes
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_SCSI_FC_ATTRS=m
# SCSI low-level drivers
CONFIG_BLK_DEV_3W_XXXX_RAID=m
CONFIG_SCSI_3W_9XXX=m
CONFIG_SCSI_ACARD=m
CONFIG_SCSI_AACRAID=m
CONFIG_SCSI_AIC7XXX=m
CONFIG_AIC7XXX_CMDS_PER_DEVICE=8
CONFIG_AIC7XXX_RESET_DELAY_MS=15000
CONFIG_AIC7XXX_DEBUG_ENABLE=y
CONFIG_AIC7XXX_DEBUG_MASK=0
CONFIG_AIC7XXX_REG_PRETTY_PRINT=y
CONFIG_SCSI_AIC7XXX_OLD=m
CONFIG_SCSI_AIC79XX=m
CONFIG_AIC79XX_CMDS_PER_DEVICE=32
CONFIG_AIC79XX_RESET_DELAY_MS=15000
CONFIG_AIC79XX_ENABLE_RD_STRM=y
CONFIG_AIC79XX_DEBUG_ENABLE=y
CONFIG_AIC79XX_DEBUG_MASK=0
CONFIG_AIC79XX_REG_PRETTY_PRINT=y
CONFIG_SCSI_MEGARAID=m
CONFIG_SCSI_SATA=y
CONFIG_SCSI_SATA_SVW=m
CONFIG_SCSI_ATA_PIIX=m
CONFIG_SCSI_SATA_NV=m
CONFIG_SCSI_SATA_PROMISE=m
CONFIG_SCSI_SATA_SX4=m
CONFIG_SCSI_SATA_SIL=m
CONFIG_SCSI_SATA_SIS=m
CONFIG_SCSI_SATA_VIA=m
CONFIG_SCSI_SATA_VITESSE=m
CONFIG_SCSI_BUSLOGIC=m
# CONFIG_SCSI_OMIT_FLASHPOINT is not set
CONFIG_SCSI_DMX3191D=m
CONFIG_SCSI_EATA=m
CONFIG_SCSI_EATA_TAGGED_QUEUE=y
CONFIG_SCSI_EATA_LINKED_COMMANDS=y
CONFIG_SCSI_EATA_MAX_TAGS=16
CONFIG_SCSI_EATA_PIO=m
CONFIG_SCSI_FUTURE_DOMAIN=m
CONFIG_SCSI_GDTH=m
CONFIG_SCSI_IPS=m
CONFIG_SCSI_INIA100=m
CONFIG_SCSI_PPA=m
CONFIG_SCSI_IMM=m
# CONFIG_SCSI_IZIP_EPP16 is not set
# CONFIG_SCSI_IZIP_SLOW_CTR is not set
CONFIG_SCSI_SYM53C8XX_2=m
CONFIG_SCSI_SYM53C8XX_DMA_ADDRESSING_MODE=1
CONFIG_SCSI_SYM53C8XX_DEFAULT_TAGS=16
CONFIG_SCSI_SYM53C8XX_MAX_TAGS=64
# CONFIG_SCSI_SYM53C8XX_IOMAPPED is not set
CONFIG_SCSI_IPR=m
# CONFIG_SCSI_IPR_TRACE is not set
# CONFIG_SCSI_IPR_DUMP is not set
CONFIG_SCSI_QLOGIC_ISP=m
CONFIG_SCSI_QLOGIC_FC=m
CONFIG_SCSI_QLOGIC_FC_FIRMWARE=y
CONFIG_SCSI_QLOGIC_1280=m
CONFIG_SCSI_DC395x=m
CONFIG_SCSI_DC390T=m
CONFIG_SCSI_DEBUG=m
# PCMCIA SCSI adapter support
CONFIG_PCMCIA_FDOMAIN=m
CONFIG_PCMCIA_QLOGIC=m
CONFIG_PCMCIA_SYM53C500=m
# Multi-device support (RAID and LVM)
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID5=m
CONFIG_MD_RAID6=m
CONFIG_MD_MULTIPATH=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
# Fusion MPT device support
CONFIG_FUSION=m
CONFIG_FUSION_MAX_SGE=40
CONFIG_FUSION_ISENSE=m
CONFIG_FUSION_CTL=m
CONFIG_FUSION_LAN=m
# IEEE 1394 (FireWire) support
CONFIG_IEEE1394=m
# Subsystem Options
# CONFIG_IEEE1394_VERBOSEDEBUG is not set
CONFIG_IEEE1394_OUI_DB=y
CONFIG_IEEE1394_EXTRA_CONFIG_ROMS=y
CONFIG_IEEE1394_CONFIG_ROM_IP1394=y
# Device Drivers
CONFIG_IEEE1394_PCILYNX=m
CONFIG_IEEE1394_OHCI1394=m
# Protocol Drivers
CONFIG_IEEE1394_VIDEO1394=m
CONFIG_IEEE1394_SBP2=m
# CONFIG_IEEE1394_SBP2_PHYS_DMA is not set
CONFIG_IEEE1394_ETH1394=m
CONFIG_IEEE1394_DV1394=m
CONFIG_IEEE1394_RAWIO=m
CONFIG_IEEE1394_CMP=m
CONFIG_IEEE1394_AMDTP=m
# I2O device support
CONFIG_I2O=m
CONFIG_I2O_CONFIG=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_SCSI=m
CONFIG_I2O_PROC=m
# Networking support
CONFIG_NET=y
# Networking options
CONFIG_PACKET=m
CONFIG_PACKET_MMAP=y
CONFIG_NETLINK_DEV=m
CONFIG_UNIX=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_FWMARK=y
CONFIG_IP_ROUTE_NAT=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_TOS=y
CONFIG_IP_ROUTE_VERBOSE=y
# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
# CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
# IP: Virtual Server Configuration
CONFIG_IP_VS=m
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IPV6=m
CONFIG_IPV6_PRIVACY=y
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_TUNNEL=m
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_BRIDGE_NETFILTER=y
# IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=m
CONFIG_IP_NF_FTP=m
CONFIG_IP_NF_IRC=m
CONFIG_IP_NF_TFTP=m
CONFIG_IP_NF_AMANDA=m
CONFIG_IP_NF_QUEUE=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_LIMIT=m
CONFIG_IP_NF_MATCH_IPRANGE=m
CONFIG_IP_NF_MATCH_MAC=m
CONFIG_IP_NF_MATCH_PKTTYPE=m
CONFIG_IP_NF_MATCH_MARK=m
CONFIG_IP_NF_MATCH_MULTIPORT=m
CONFIG_IP_NF_MATCH_TOS=m
CONFIG_IP_NF_MATCH_RECENT=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_DSCP=m
CONFIG_IP_NF_MATCH_AH_ESP=m
CONFIG_IP_NF_MATCH_LENGTH=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_MATCH_TCPMSS=m
CONFIG_IP_NF_MATCH_HELPER=m
CONFIG_IP_NF_MATCH_STATE=m
CONFIG_IP_NF_MATCH_CONNTRACK=m
CONFIG_IP_NF_MATCH_OWNER=m
CONFIG_IP_NF_MATCH_PHYSDEV=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_SAME=m
CONFIG_IP_NF_NAT_LOCAL=y
CONFIG_IP_NF_NAT_SNMP_BASIC=m
CONFIG_IP_NF_NAT_IRC=m
CONFIG_IP_NF_NAT_FTP=m
CONFIG_IP_NF_NAT_TFTP=m
CONFIG_IP_NF_NAT_AMANDA=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_TOS=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_DSCP=m
CONFIG_IP_NF_TARGET_MARK=m
CONFIG_IP_NF_TARGET_CLASSIFY=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_IP_NF_TARGET_TCPMSS=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_IP_NF_COMPAT_IPCHAINS=m
CONFIG_IP_NF_COMPAT_IPFWADM=m
CONFIG_IP_NF_TARGET_NOTRACK=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_REALM=m
# IPv6: Netfilter Configuration
CONFIG_IP6_NF_QUEUE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_LIMIT=m
CONFIG_IP6_NF_MATCH_MAC=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_MULTIPORT=m
CONFIG_IP6_NF_MATCH_OWNER=m
CONFIG_IP6_NF_MATCH_MARK=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_AHESP=m
CONFIG_IP6_NF_MATCH_LENGTH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_LOG=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_TARGET_MARK=m
CONFIG_IP6_NF_RAW=m
# DECnet: Netfilter Configuration
CONFIG_DECNET_NF_GRABULATOR=m
# Bridge: Netfilter Configuration
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_XFRM=y
CONFIG_XFRM_USER=m
# SCTP Configuration (EXPERIMENTAL)
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_MSG is not set
# CONFIG_SCTP_DBG_OBJCNT is not set
# CONFIG_SCTP_HMAC_NONE is not set
# CONFIG_SCTP_HMAC_SHA1 is not set
CONFIG_SCTP_HMAC_MD5=y
CONFIG_ATM=y
CONFIG_ATM_CLIP=y
# CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
# CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_BRIDGE=m
CONFIG_VLAN_8021Q=m
CONFIG_DECNET=m
# CONFIG_DECNET_SIOCGIFCONF is not set
# CONFIG_DECNET_ROUTER is not set
CONFIG_LLC=y
CONFIG_LLC2=m
CONFIG_IPX=m
# CONFIG_IPX_INTERN is not set
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=y
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
CONFIG_IPDDP_DECAP=y
CONFIG_X25=m
CONFIG_LAPB=m
# CONFIG_NET_DIVERT is not set
CONFIG_ECONET=m
CONFIG_ECONET_AUNUDP=y
CONFIG_ECONET_NATIVE=y
CONFIG_WAN_ROUTER=m
# CONFIG_NET_HW_FLOWCONTROL is not set
# QoS and/or fair queueing
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CLK_JIFFIES=y
# CONFIG_NET_SCH_CLK_GETTIMEOFDAY is not set
# CONFIG_NET_SCH_CLK_CPU is not set
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_QOS=y
CONFIG_NET_ESTIMATOR=y
CONFIG_NET_CLS=y
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_ROUTE=y
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
# CONFIG_NET_CLS_IND is not set
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
# CONFIG_NET_CLS_ACT is not set
CONFIG_NET_CLS_POLICE=y
# Network testing
CONFIG_NET_PKTGEN=m
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
CONFIG_HAMRADIO=y
# Packet Radio protocols
CONFIG_AX25=m
# CONFIG_AX25_DAMA_SLAVE is not set
CONFIG_NETROM=m
CONFIG_ROSE=m
# AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_BAYCOM_PAR=m
CONFIG_YAM=m
CONFIG_IRDA=m
# IrDA protocols
CONFIG_IRLAN=m
CONFIG_IRNET=m
CONFIG_IRCOMM=m
# CONFIG_IRDA_ULTRA is not set
# IrDA options
CONFIG_IRDA_CACHE_LAST_LSAP=y
CONFIG_IRDA_FAST_RR=y
CONFIG_IRDA_DEBUG=y
# Infrared-port device drivers
# SIR device drivers
CONFIG_IRTTY_SIR=m
# Dongle support
CONFIG_DONGLE=y
CONFIG_ESI_DONGLE=m
CONFIG_ACTISYS_DONGLE=m
CONFIG_TEKRAM_DONGLE=m
CONFIG_LITELINK_DONGLE=m
CONFIG_MA600_DONGLE=m
CONFIG_GIRBIL_DONGLE=m
CONFIG_MCP2120_DONGLE=m
CONFIG_OLD_BELKIN_DONGLE=m
CONFIG_ACT200L_DONGLE=m
# Old SIR device drivers
CONFIG_IRPORT_SIR=m
# Old Serial dongle support
# CONFIG_DONGLE_OLD is not set
# FIR device drivers
CONFIG_USB_IRDA=m
CONFIG_SIGMATEL_FIR=m
CONFIG_VLSI_FIR=m
CONFIG_BT=m
CONFIG_BT_L2CAP=m
CONFIG_BT_SCO=m
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_CMTP=m
CONFIG_BT_HIDP=m
# Bluetooth device drivers
CONFIG_BT_HCIUSB=m
CONFIG_BT_HCIUSB_SCO=y
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
# CONFIG_BT_HCIUART_BCSP_TXCRC is not set
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIDTL1=m
CONFIG_BT_HCIBT3C=m
CONFIG_BT_HCIBLUECARD=m
CONFIG_BT_HCIBTUART=m
CONFIG_BT_HCIVHCI=m
CONFIG_NETDEVICES=y
CONFIG_DUMMY=m
CONFIG_BONDING=m
CONFIG_EQUALIZER=m
CONFIG_TUN=m
CONFIG_ETHERTAP=m
# ARCnet devices
CONFIG_ARCNET=m
CONFIG_ARCNET_1201=m
CONFIG_ARCNET_1051=m
CONFIG_ARCNET_RAW=m
CONFIG_ARCNET_COM90xx=m
CONFIG_ARCNET_COM90xxIO=m
CONFIG_ARCNET_RIM_I=m
CONFIG_ARCNET_COM20020=m
CONFIG_ARCNET_COM20020_PCI=m
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=m
CONFIG_HAPPYMEAL=m
CONFIG_SUNGEM=m
CONFIG_NET_VENDOR_3COM=y
CONFIG_VORTEX=m
CONFIG_TYPHOON=m
# Tulip family network device support
CONFIG_NET_TULIP=y
CONFIG_DE2104X=m
CONFIG_TULIP=m
# CONFIG_TULIP_MWI is not set
# CONFIG_TULIP_MMIO is not set
# CONFIG_TULIP_NAPI is not set
CONFIG_DE4X5=m
CONFIG_WINBOND_840=m
CONFIG_DM9102=m
CONFIG_PCMCIA_XIRCOM=m
CONFIG_PCMCIA_XIRTULIP=m
CONFIG_HP100=m
CONFIG_NET_PCI=y
CONFIG_PCNET32=m
CONFIG_AMD8111_ETH=m
# CONFIG_AMD8111E_NAPI is not set
CONFIG_ADAPTEC_STARFIRE=m
# CONFIG_ADAPTEC_STARFIRE_NAPI is not set
CONFIG_B44=m
CONFIG_FORCEDETH=m
CONFIG_EEPRO100=m
# CONFIG_EEPRO100_PIO is not set
CONFIG_E100=m
# CONFIG_E100_NAPI is not set
CONFIG_FEALNX=m
CONFIG_NATSEMI=m
CONFIG_NE2K_PCI=m
CONFIG_8139CP=m
CONFIG_8139TOO=m
# CONFIG_8139TOO_PIO is not set
CONFIG_8139TOO_TUNE_TWISTER=y
CONFIG_8139TOO_8129=y
# CONFIG_8139_OLD_RX_RESET is not set
CONFIG_SIS900=m
CONFIG_EPIC100=m
CONFIG_SUNDANCE=m
# CONFIG_SUNDANCE_MMIO is not set
CONFIG_VIA_RHINE=m
# CONFIG_VIA_RHINE_MMIO is not set
CONFIG_VIA_VELOCITY=m
# Ethernet (1000 Mbit)
CONFIG_DL2K=m
CONFIG_E1000=m
# CONFIG_E1000_NAPI is not set
CONFIG_NS83820=m
CONFIG_HAMACHI=m
CONFIG_YELLOWFIN=m
CONFIG_R8169=m
CONFIG_SK98LIN=m
CONFIG_TIGON3=m
# Ethernet (10000 Mbit)
CONFIG_IXGB=m
# CONFIG_IXGB_NAPI is not set
CONFIG_S2IO=m
# CONFIG_S2IO_NAPI is not set
# Token Ring devices
CONFIG_TR=y
CONFIG_IBMOL=m
CONFIG_3C359=m
CONFIG_TMS380TR=m
CONFIG_TMSPCI=m
CONFIG_ABYSS=m
# Wireless LAN (non-hamradio)
CONFIG_NET_RADIO=y
# Obsolete Wireless cards support (pre-802.11)
CONFIG_STRIP=m
CONFIG_PCMCIA_WAVELAN=m
CONFIG_PCMCIA_NETWAVE=m
# Wireless 802.11 Frequency Hopping cards support
CONFIG_PCMCIA_RAYCS=m
# Wireless 802.11b ISA/PCI cards support
CONFIG_HERMES=m
CONFIG_PLX_HERMES=m
CONFIG_TMD_HERMES=m
CONFIG_PCI_HERMES=m
CONFIG_ATMEL=m
CONFIG_PCI_ATMEL=m
# Wireless 802.11b Pcmcia/Cardbus cards support
CONFIG_PCMCIA_HERMES=m
CONFIG_AIRO_CS=m
CONFIG_PCMCIA_ATMEL=m
CONFIG_PCMCIA_WL3501=m
# Prism GT/Duette 802.11(a/b/g) PCI/Cardbus support
CONFIG_PRISM54=m
CONFIG_NET_WIRELESS=y
# PCMCIA network device support
CONFIG_NET_PCMCIA=y
CONFIG_PCMCIA_3C589=m
CONFIG_PCMCIA_3C574=m
CONFIG_PCMCIA_FMVJ18X=m
CONFIG_PCMCIA_PCNET=m
CONFIG_PCMCIA_NMCLAN=m
CONFIG_PCMCIA_SMC91C92=m
CONFIG_PCMCIA_XIRC2PS=m
CONFIG_PCMCIA_AXNET=m
CONFIG_ARCNET_COM20020_CS=m
# Wan interfaces
CONFIG_WAN=y
CONFIG_DSCC4=m
CONFIG_DSCC4_PCISYNC=y
CONFIG_DSCC4_PCI_RST=y
CONFIG_LANMEDIA=m
CONFIG_SYNCLINK_SYNCPPP=m
CONFIG_HDLC=m
CONFIG_HDLC_RAW=y
CONFIG_HDLC_RAW_ETH=y
CONFIG_HDLC_CISCO=y
CONFIG_HDLC_FR=y
CONFIG_HDLC_PPP=y
CONFIG_HDLC_X25=y
CONFIG_PCI200SYN=m
CONFIG_WANXL=m
CONFIG_PC300=m
CONFIG_PC300_MLPPP=y
CONFIG_FARSYNC=m
CONFIG_DLCI=m
CONFIG_DLCI_COUNT=24
CONFIG_DLCI_MAX=8
CONFIG_WAN_ROUTER_DRIVERS=y
CONFIG_CYCLADES_SYNC=m
CONFIG_CYCLOMX_X25=y
CONFIG_LAPBETHER=m
CONFIG_X25_ASY=m
CONFIG_SBNI=m
# CONFIG_SBNI_MULTILINE is not set
# ATM drivers
CONFIG_ATM_TCP=m
CONFIG_ATM_LANAI=m
CONFIG_ATM_ENI=m
# CONFIG_ATM_ENI_DEBUG is not set
# CONFIG_ATM_ENI_TUNE_BURST is not set
CONFIG_ATM_FIRESTREAM=m
CONFIG_ATM_ZATM=m
# CONFIG_ATM_ZATM_DEBUG is not set
CONFIG_ATM_IDT77252=m
# CONFIG_ATM_IDT77252_DEBUG is not set
# CONFIG_ATM_IDT77252_RCV_ALL is not set
CONFIG_ATM_IDT77252_USE_SUNI=y
CONFIG_ATM_AMBASSADOR=m
# CONFIG_ATM_AMBASSADOR_DEBUG is not set
CONFIG_ATM_HORIZON=m
# CONFIG_ATM_HORIZON_DEBUG is not set
CONFIG_ATM_FORE200E_MAYBE=m
CONFIG_ATM_FORE200E_PCA=y
CONFIG_ATM_FORE200E_PCA_DEFAULT_FW=y
# CONFIG_ATM_FORE200E_USE_TASKLET is not set
CONFIG_ATM_FORE200E_TX_RETRY=16
CONFIG_ATM_FORE200E_DEBUG=0
CONFIG_ATM_FORE200E=m
CONFIG_ATM_HE=m
CONFIG_ATM_HE_USE_SUNI=y
CONFIG_FDDI=y
# CONFIG_DEFXX is not set
CONFIG_SKFP=m
CONFIG_HIPPI=y
CONFIG_ROADRUNNER=m
# CONFIG_ROADRUNNER_LARGE_RINGS is not set
CONFIG_PLIP=m
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPPOE=m
CONFIG_PPPOATM=m
CONFIG_SLIP=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
# CONFIG_SLIP_MODE_SLIP6 is not set
CONFIG_NET_FC=y
CONFIG_SHAPER=m
# CONFIG_NETCONSOLE is not set
# ISDN subsystem
CONFIG_ISDN=m
# Old ISDN4Linux
CONFIG_ISDN_I4L=m
CONFIG_ISDN_PPP=y
CONFIG_ISDN_PPP_VJ=y
CONFIG_ISDN_MPP=y
CONFIG_IPPP_FILTER=y
CONFIG_ISDN_PPP_BSDCOMP=m
CONFIG_ISDN_AUDIO=y
CONFIG_ISDN_TTY_FAX=y
CONFIG_ISDN_X25=y
# ISDN feature submodules
CONFIG_ISDN_DRV_LOOP=m
# ISDN4Linux hardware drivers
# Passive cards
CONFIG_ISDN_DRV_HISAX=m
# D-channel protocol features
CONFIG_HISAX_EURO=y
CONFIG_DE_AOC=y
# CONFIG_HISAX_NO_SENDCOMPLETE is not set
# CONFIG_HISAX_NO_LLC is not set
# CONFIG_HISAX_NO_KEYPAD is not set
CONFIG_HISAX_1TR6=y
CONFIG_HISAX_NI1=y
CONFIG_HISAX_MAX_CARDS=8
# HiSax supported cards
CONFIG_HISAX_16_3=y
CONFIG_HISAX_TELESPCI=y
CONFIG_HISAX_S0BOX=y
CONFIG_HISAX_FRITZPCI=y
CONFIG_HISAX_AVM_A1_PCMCIA=y
CONFIG_HISAX_ELSA=y
CONFIG_HISAX_DIEHLDIVA=y
CONFIG_HISAX_SEDLBAUER=y
CONFIG_HISAX_NETJET=y
CONFIG_HISAX_NETJET_U=y
CONFIG_HISAX_NICCY=y
CONFIG_HISAX_BKM_A4T=y
CONFIG_HISAX_SCT_QUADRO=y
CONFIG_HISAX_GAZEL=y
CONFIG_HISAX_HFC_PCI=y
CONFIG_HISAX_W6692=y
CONFIG_HISAX_HFC_SX=y
CONFIG_HISAX_ENTERNOW_PCI=y
# CONFIG_HISAX_DEBUG is not set
# HiSax PCMCIA card service modules
CONFIG_HISAX_SEDLBAUER_CS=m
CONFIG_HISAX_ELSA_CS=m
CONFIG_HISAX_AVM_A1_CS=m
CONFIG_HISAX_TELES_CS=m
# HiSax sub driver modules
CONFIG_HISAX_ST5481=m
CONFIG_HISAX_HFCUSB=m
CONFIG_HISAX_FRITZ_PCIPNP=m
CONFIG_HISAX_HDLC=y
# Active cards
CONFIG_ISDN_DRV_TPAM=m
CONFIG_HYSDN=m
CONFIG_HYSDN_CAPI=y
# CAPI subsystem
CONFIG_ISDN_CAPI=m
CONFIG_ISDN_DRV_AVMB1_VERBOSE_REASON=y
CONFIG_ISDN_CAPI_MIDDLEWARE=y
CONFIG_ISDN_CAPI_CAPI20=m
CONFIG_ISDN_CAPI_CAPIFS_BOOL=y
CONFIG_ISDN_CAPI_CAPIFS=m
CONFIG_ISDN_CAPI_CAPIDRV=m
# CAPI hardware drivers
# Active AVM cards
CONFIG_CAPI_AVM=y
CONFIG_ISDN_DRV_AVMB1_B1PCI=m
CONFIG_ISDN_DRV_AVMB1_B1PCIV4=y
CONFIG_ISDN_DRV_AVMB1_B1PCMCIA=m
CONFIG_ISDN_DRV_AVMB1_AVM_CS=m
CONFIG_ISDN_DRV_AVMB1_T1PCI=m
CONFIG_ISDN_DRV_AVMB1_C4=m
# Active Eicon DIVA Server cards
CONFIG_CAPI_EICON=y
CONFIG_ISDN_DIVAS=m
CONFIG_ISDN_DIVAS_BRIPCI=y
CONFIG_ISDN_DIVAS_PRIPCI=y
CONFIG_ISDN_DIVAS_DIVACAPI=m
CONFIG_ISDN_DIVAS_USERIDI=m
CONFIG_ISDN_DIVAS_MAINT=m
# Telephony Support
CONFIG_PHONE=m
CONFIG_PHONE_IXJ=m
CONFIG_PHONE_IXJ_PCMCIA=m
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=m
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_MOUSEDEV_PSAUX_ENABLE=y
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_TSDEV=m
CONFIG_INPUT_TSDEV_SCREEN_X=240
CONFIG_INPUT_TSDEV_SCREEN_Y=320
CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_EVBUG=m
# Input I/O drivers
CONFIG_GAMEPORT=m
CONFIG_SOUND_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
CONFIG_GAMEPORT_EMU10K1=m
CONFIG_GAMEPORT_VORTEX=m
CONFIG_GAMEPORT_FM801=m
CONFIG_GAMEPORT_CS461x=m
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=m
CONFIG_SERIO_CT82C710=m
CONFIG_SERIO_PARKBD=m
CONFIG_SERIO_PCIPS2=m
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
CONFIG_KEYBOARD_SUNKBD=m
# CONFIG_KEYBOARD_LKKBD is not set
CONFIG_KEYBOARD_XTKBD=m
CONFIG_KEYBOARD_NEWTON=m
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=m
CONFIG_MOUSE_SERIAL=m
# CONFIG_MOUSE_VSXXXAA is not set
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_ANALOG=m
CONFIG_JOYSTICK_A3D=m
CONFIG_JOYSTICK_ADI=m
CONFIG_JOYSTICK_COBRA=m
CONFIG_JOYSTICK_GF2K=m
CONFIG_JOYSTICK_GRIP=m
CONFIG_JOYSTICK_GRIP_MP=m
CONFIG_JOYSTICK_GUILLEMOT=m
CONFIG_JOYSTICK_INTERACT=m
CONFIG_JOYSTICK_SIDEWINDER=m
CONFIG_JOYSTICK_TMDC=m
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
CONFIG_JOYSTICK_IFORCE_232=y
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDDLER=m
CONFIG_JOYSTICK_DB9=m
CONFIG_JOYSTICK_GAMECON=m
CONFIG_JOYSTICK_TURBOGRAFX=m
CONFIG_INPUT_JOYDUMP=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_GUNZE=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=m
CONFIG_INPUT_UINPUT=m
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_SERIAL_NONSTANDARD=y
CONFIG_COMPUTONE=m
CONFIG_ROCKETPORT=m
CONFIG_CYCLADES=m
# CONFIG_CYZ_INTR is not set
# CONFIG_DIGI is not set
CONFIG_MOXA_INTELLIO=m
CONFIG_MOXA_SMARTIO=m
# CONFIG_ISI is not set
CONFIG_SYNCLINK=m
CONFIG_SYNCLINKMP=m
CONFIG_N_HDLC=m
# CONFIG_RISCOM8 is not set
# CONFIG_SPECIALIX is not set
CONFIG_SX=m
# CONFIG_RIO is not set
CONFIG_STALDRV=y
CONFIG_STALLION=m
CONFIG_ISTALLION=m
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_CS=m
# CONFIG_SERIAL_8250_ACPI is not set
CONFIG_SERIAL_8250_NR_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
# CONFIG_SERIAL_8250_DETECT_IRQ is not set
CONFIG_SERIAL_8250_MULTIPORT=y
CONFIG_SERIAL_8250_RSA=y
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_PRINTER=m
# CONFIG_LP_CONSOLE is not set
CONFIG_PPDEV=m
CONFIG_TIPAR=m
CONFIG_QIC02_TAPE=m
CONFIG_QIC02_DYNCONF=y
# Setting runtime QIC-02 configuration is done with qic02conf
# from the tpqic02-support package.  It is available at
# metalab.unc.edu or ftp://titus.cfw.com/pub/Linux/util/
# IPMI
CONFIG_IPMI_HANDLER=m
# CONFIG_IPMI_PANIC_EVENT is not set
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_IPMI_WATCHDOG=m
# Watchdog Cards
CONFIG_WATCHDOG=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
# Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=m
CONFIG_ACQUIRE_WDT=m
CONFIG_ADVANTECH_WDT=m
CONFIG_ALIM1535_WDT=m
CONFIG_ALIM7101_WDT=m
CONFIG_SC520_WDT=m
CONFIG_EUROTECH_WDT=m
CONFIG_IB700_WDT=m
CONFIG_WAFER_WDT=m
CONFIG_I8XX_TCO=m
CONFIG_SC1200_WDT=m
CONFIG_SCx200_WDT=m
CONFIG_60XX_WDT=m
CONFIG_CPU5_WDT=m
CONFIG_W83627HF_WDT=m
CONFIG_W83877F_WDT=m
CONFIG_MACHZ_WDT=m
# PCI-based Watchdog Cards
CONFIG_PCIPCWATCHDOG=m
CONFIG_WDTPCI=m
CONFIG_WDT_501_PCI=y
# USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_HW_RANDOM=m
CONFIG_NVRAM=m
CONFIG_RTC=m
CONFIG_GEN_RTC=m
CONFIG_GEN_RTC_X=y
CONFIG_DTLK=m
CONFIG_R3964=m
CONFIG_APPLICOM=m
# Ftape, the floppy tape device driver
CONFIG_FTAPE=m
CONFIG_ZFTAPE=m
CONFIG_ZFT_DFLT_BLK_SZ=10240
# The compressor will be built as a module only!
CONFIG_ZFT_COMPRESSOR=m
CONFIG_FT_NR_BUFFERS=3
CONFIG_FT_PROC_FS=y
CONFIG_FT_NORMAL_DEBUG=y
# CONFIG_FT_FULL_DEBUG is not set
# CONFIG_FT_NO_TRACE is not set
# CONFIG_FT_NO_TRACE_AT_ALL is not set
# Hardware configuration
CONFIG_FT_STD_FDC=y
# CONFIG_FT_MACH2 is not set
# CONFIG_FT_PROBE_FC10 is not set
# CONFIG_FT_ALT_FDC is not set
CONFIG_FT_FDC_THR=8
CONFIG_FT_FDC_MAX_RATE=2000
CONFIG_FT_ALPHA_CLOCK=0
CONFIG_AGP=y
CONFIG_AGP_AMD64=y
# CONFIG_AGP_INTEL_MCH is not set
CONFIG_DRM=y
CONFIG_DRM_TDFX=m
CONFIG_DRM_GAMMA=m
CONFIG_DRM_R128=m
CONFIG_DRM_RADEON=m
CONFIG_DRM_SIS=m
# PCMCIA character devices
CONFIG_SYNCLINK_CS=m
CONFIG_MWAVE=m
CONFIG_RAW_DRIVER=m
CONFIG_HPET=y
# CONFIG_HPET_RTC_IRQ is not set
CONFIG_HPET_MMAP=y
CONFIG_MAX_RAW_DEVS=256
CONFIG_HANGCHECK_TIMER=m
# I2C support
CONFIG_I2C=m
CONFIG_I2C_CHARDEV=m
# I2C Algorithms
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCF=m
# I2C Hardware Bus support
CONFIG_I2C_ALI1535=m
CONFIG_I2C_ALI1563=m
CONFIG_I2C_ALI15X3=m
CONFIG_I2C_AMD756=m
CONFIG_I2C_AMD8111=m
CONFIG_I2C_I801=m
CONFIG_I2C_I810=m
CONFIG_I2C_ISA=m
CONFIG_I2C_NFORCE2=m
CONFIG_I2C_PARPORT=m
CONFIG_I2C_PARPORT_LIGHT=m
CONFIG_I2C_PROSAVAGE=m
CONFIG_I2C_SAVAGE4=m
CONFIG_SCx200_ACB=m
CONFIG_I2C_SIS5595=m
CONFIG_I2C_SIS630=m
CONFIG_I2C_SIS96X=m
CONFIG_I2C_VIA=m
CONFIG_I2C_VIAPRO=m
CONFIG_I2C_VOODOO3=m
# Hardware Sensors Chip support
CONFIG_I2C_SENSOR=m
CONFIG_SENSORS_ADM1021=m
CONFIG_SENSORS_ADM1025=m
CONFIG_SENSORS_ADM1031=m
CONFIG_SENSORS_ASB100=m
CONFIG_SENSORS_DS1621=m
CONFIG_SENSORS_FSCHER=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM78=m
CONFIG_SENSORS_LM80=m
CONFIG_SENSORS_LM83=m
CONFIG_SENSORS_LM85=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_MAX1619=m
CONFIG_SENSORS_VIA686A=m
CONFIG_SENSORS_W83781D=m
CONFIG_SENSORS_W83L785TS=m
CONFIG_SENSORS_W83627HF=m
# Other I2C Chip support
CONFIG_SENSORS_EEPROM=m
CONFIG_SENSORS_PCF8574=m
CONFIG_SENSORS_PCF8591=m
CONFIG_SENSORS_RTC8564=m
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# Dallas's 1-wire bus
CONFIG_W1=m
CONFIG_W1_MATROX=m
CONFIG_W1_THERM=m
# Misc devices
CONFIG_IBM_ASM=m
# Multimedia devices
CONFIG_VIDEO_DEV=m
# Video For Linux
# Video Adapters
CONFIG_VIDEO_BT848=m
CONFIG_VIDEO_BWQCAM=m
CONFIG_VIDEO_CQCAM=m
CONFIG_VIDEO_W9966=m
CONFIG_VIDEO_CPIA=m
CONFIG_VIDEO_CPIA_PP=m
CONFIG_VIDEO_CPIA_USB=m
CONFIG_VIDEO_SAA5246A=m
CONFIG_VIDEO_SAA5249=m
CONFIG_TUNER_3036=m
CONFIG_VIDEO_STRADIS=m
CONFIG_VIDEO_ZORAN=m
CONFIG_VIDEO_ZORAN_BUZ=m
CONFIG_VIDEO_ZORAN_DC10=m
CONFIG_VIDEO_ZORAN_DC30=m
CONFIG_VIDEO_ZORAN_LML33=m
CONFIG_VIDEO_ZORAN_LML33R10=m
CONFIG_VIDEO_SAA7134=m
CONFIG_VIDEO_MXB=m
CONFIG_VIDEO_DPC=m
CONFIG_VIDEO_HEXIUM_ORION=m
CONFIG_VIDEO_HEXIUM_GEMINI=m
CONFIG_VIDEO_CX88=m
CONFIG_VIDEO_OVCAMCHIP=m
# Radio Adapters
CONFIG_RADIO_GEMTEK_PCI=m
CONFIG_RADIO_MAXIRADIO=m
CONFIG_RADIO_MAESTRO=m
# Digital Video Broadcasting Devices
CONFIG_DVB=y
CONFIG_DVB_CORE=m
# Supported Frontend Modules
CONFIG_DVB_TWINHAN_DST=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_SP887X_FIRMWARE_FILE="/usr/lib/hotplug/firmware/sc_main.mc"
CONFIG_DVB_ALPS_TDLB7=m
CONFIG_DVB_ALPS_TDMB7=m
CONFIG_DVB_ATMEL_AT76C651=m
CONFIG_DVB_CX24110=m
CONFIG_DVB_GRUNDIG_29504_491=m
CONFIG_DVB_GRUNDIG_29504_401=m
CONFIG_DVB_MT312=m
CONFIG_DVB_VES1820=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_TDA1004X_FIRMWARE_FILE="/usr/lib/hotplug/firmware/tda1004x.bin"
CONFIG_DVB_NXT6000=m
# Supported SAA7146 based PCI Adapters
CONFIG_DVB_AV7110=m
# CONFIG_DVB_AV7110_OSD is not set
CONFIG_DVB_BUDGET=m
CONFIG_DVB_BUDGET_CI=m
CONFIG_DVB_BUDGET_AV=m
CONFIG_DVB_BUDGET_PATCH=m
# Supported USB Adapters
CONFIG_DVB_TTUSB_BUDGET=m
CONFIG_DVB_TTUSB_DEC=m
# Supported FlexCopII (B2C2) Adapters
CONFIG_DVB_B2C2_SKYSTAR=m
# Supported BT878 Adapters
CONFIG_DVB_BT8XX=m
CONFIG_VIDEO_SAA7146=m
CONFIG_VIDEO_SAA7146_VV=m
CONFIG_VIDEO_VIDEOBUF=m
CONFIG_VIDEO_TUNER=m
CONFIG_VIDEO_BUF=m
CONFIG_VIDEO_BTCX=m
CONFIG_VIDEO_IR=m
# Graphics support
CONFIG_FB=y
CONFIG_FB_CIRRUS=m
CONFIG_FB_PM2=m
CONFIG_FB_PM2_FIFO_DISCONNECT=y
CONFIG_FB_CYBER2000=m
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
CONFIG_FB_VGA16=m
CONFIG_FB_VESA=m
CONFIG_VIDEO_SELECT=y
CONFIG_FB_HGA=m
# CONFIG_FB_HGA_ACCEL is not set
CONFIG_FB_RIVA=m
CONFIG_FB_RIVA_I2C=y
CONFIG_FB_RIVA_DEBUG=y
CONFIG_FB_MATROX=m
CONFIG_FB_MATROX_MILLENIUM=y
CONFIG_FB_MATROX_MYSTIQUE=y
CONFIG_FB_MATROX_G450=y
CONFIG_FB_MATROX_G100=y
CONFIG_FB_MATROX_I2C=m
CONFIG_FB_MATROX_MAVEN=m
CONFIG_FB_MATROX_MULTIHEAD=y
CONFIG_FB_RADEON_OLD=m
CONFIG_FB_RADEON=m
CONFIG_FB_RADEON_I2C=y
# CONFIG_FB_RADEON_DEBUG is not set
CONFIG_FB_ATY128=m
CONFIG_FB_ATY=m
CONFIG_FB_ATY_CT=y
CONFIG_FB_ATY_GX=y
CONFIG_FB_ATY_XL_INIT=y
CONFIG_FB_SIS=m
CONFIG_FB_SIS_300=y
CONFIG_FB_SIS_315=y
CONFIG_FB_NEOMAGIC=m
CONFIG_FB_KYRO=m
CONFIG_FB_3DFX=m
# CONFIG_FB_3DFX_ACCEL is not set
CONFIG_FB_VOODOO1=m
CONFIG_FB_TRIDENT=m
# CONFIG_FB_TRIDENT_ACCEL is not set
CONFIG_FB_VIRTUAL=m
# Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_MDA_CONSOLE=m
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=m
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# Logo configuration
# CONFIG_LOGO is not set
# Sound
CONFIG_SOUND=m
# Advanced Linux Sound Architecture
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_BIT32_EMUL=m
CONFIG_SND_RTCTIMER=m
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# Generic devices
CONFIG_SND_MPU401_UART=m
CONFIG_SND_OPL3_LIB=m
CONFIG_SND_VX_LIB=m
CONFIG_SND_DUMMY=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
# PCI devices
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_ALI5451=m
CONFIG_SND_ATIIXP=m
CONFIG_SND_AU8810=m
CONFIG_SND_AU8820=m
CONFIG_SND_AU8830=m
CONFIG_SND_AZT3328=m
CONFIG_SND_BT87X=m
CONFIG_SND_CS46XX=m
CONFIG_SND_CS46XX_NEW_DSP=y
CONFIG_SND_CS4281=m
CONFIG_SND_EMU10K1=m
CONFIG_SND_KORG1212=m
CONFIG_SND_MIXART=m
CONFIG_SND_NM256=m
CONFIG_SND_RME32=m
CONFIG_SND_RME96=m
CONFIG_SND_RME9652=m
CONFIG_SND_HDSP=m
CONFIG_SND_TRIDENT=m
CONFIG_SND_YMFPCI=m
CONFIG_SND_ALS4000=m
CONFIG_SND_CMIPCI=m
CONFIG_SND_ENS1370=m
CONFIG_SND_ENS1371=m
CONFIG_SND_ES1938=m
CONFIG_SND_ES1968=m
CONFIG_SND_MAESTRO3=m
CONFIG_SND_FM801=m
CONFIG_SND_FM801_TEA575X=m
CONFIG_SND_ICE1712=m
CONFIG_SND_ICE1724=m
CONFIG_SND_INTEL8X0=m
CONFIG_SND_INTEL8X0M=m
CONFIG_SND_SONICVIBES=m
CONFIG_SND_VIA82XX=m
CONFIG_SND_VX222=m
# ALSA USB devices
CONFIG_SND_USB_AUDIO=m
# PCMCIA devices
# Open Sound System
CONFIG_SOUND_PRIME=m
CONFIG_SOUND_BT878=m
CONFIG_SOUND_CMPCI=m
# CONFIG_SOUND_CMPCI_FM is not set
# CONFIG_SOUND_CMPCI_MIDI is not set
CONFIG_SOUND_CMPCI_JOYSTICK=y
CONFIG_SOUND_EMU10K1=m
CONFIG_MIDI_EMU10K1=y
CONFIG_SOUND_FUSION=m
CONFIG_SOUND_CS4281=m
CONFIG_SOUND_ES1370=m
CONFIG_SOUND_ES1371=m
CONFIG_SOUND_ESSSOLO1=m
CONFIG_SOUND_MAESTRO=m
CONFIG_SOUND_MAESTRO3=m
CONFIG_SOUND_ICH=m
CONFIG_SOUND_SONICVIBES=m
CONFIG_SOUND_TRIDENT=m
# CONFIG_SOUND_MSNDCLAS is not set
# CONFIG_SOUND_MSNDPIN is not set
CONFIG_SOUND_VIA82CXXX=m
CONFIG_MIDI_VIA82CXXX=y
CONFIG_SOUND_OSS=m
# CONFIG_SOUND_TRACEINIT is not set
# CONFIG_SOUND_DMAP is not set
# CONFIG_SOUND_AD1816 is not set
CONFIG_SOUND_AD1889=m
CONFIG_SOUND_SGALAXY=m
CONFIG_SOUND_ADLIB=m
CONFIG_SOUND_ACI_MIXER=m
CONFIG_SOUND_CS4232=m
CONFIG_SOUND_SSCAPE=m
CONFIG_SOUND_GUS=m
CONFIG_SOUND_GUS16=y
CONFIG_SOUND_GUSMAX=y
CONFIG_SOUND_VMIDI=m
CONFIG_SOUND_TRIX=m
CONFIG_SOUND_MSS=m
CONFIG_SOUND_MPU401=m
CONFIG_SOUND_NM256=m
CONFIG_SOUND_MAD16=m
CONFIG_MAD16_OLDCARD=y
CONFIG_SOUND_PAS=m
CONFIG_SOUND_PSS=m
CONFIG_PSS_MIXER=y
CONFIG_SOUND_SB=m
# CONFIG_SOUND_AWE32_SYNTH is not set
CONFIG_SOUND_WAVEFRONT=m
CONFIG_SOUND_MAUI=m
CONFIG_SOUND_YM3812=m
CONFIG_SOUND_OPL3SA1=m
CONFIG_SOUND_OPL3SA2=m
CONFIG_SOUND_YMFPCI=m
# CONFIG_SOUND_YMFPCI_LEGACY is not set
CONFIG_SOUND_UART6850=m
CONFIG_SOUND_AEDSP16=m
CONFIG_SC6600=y
CONFIG_SC6600_JOY=y
CONFIG_SC6600_CDROM=4
CONFIG_SC6600_CDROMBASE=0x0
# CONFIG_AEDSP16_MSS is not set
# CONFIG_AEDSP16_SBPRO is not set
# CONFIG_AEDSP16_MPU401 is not set
CONFIG_SOUND_TVMIXER=m
CONFIG_SOUND_KAHLUA=m
CONFIG_SOUND_ALI5455=m
CONFIG_SOUND_FORTE=m
CONFIG_SOUND_RME96XX=m
CONFIG_SOUND_AD1980=m
# USB support
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_BANDWIDTH=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_SPLIT_ISO=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_UHCI_HCD=m
# USB Device Class drivers
CONFIG_USB_AUDIO=m
# USB Bluetooth TTY can only be used with disabled Bluetooth subsystem
CONFIG_USB_MIDI=m
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_RW_DETECT is not set
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_DPCM=y
CONFIG_USB_STORAGE_HP8200e=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
# USB Human Interface Devices (HID)
CONFIG_USB_HID=m
CONFIG_USB_HIDINPUT=y
# CONFIG_HID_FF is not set
CONFIG_USB_HIDDEV=y
# USB HID Boot Protocol drivers
CONFIG_USB_KBD=m
CONFIG_USB_MOUSE=m
CONFIG_USB_AIPTEK=m
CONFIG_USB_WACOM=m
CONFIG_USB_KBTAB=m
CONFIG_USB_POWERMATE=m
CONFIG_USB_MTOUCH=m
CONFIG_USB_EGALAX=m
CONFIG_USB_XPAD=m
CONFIG_USB_ATI_REMOTE=m
# USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
CONFIG_USB_HPUSBSCSI=m
# USB Multimedia devices
CONFIG_USB_VICAM=m
CONFIG_USB_DSBR=m
CONFIG_USB_IBMCAM=m
CONFIG_USB_KONICAWC=m
CONFIG_USB_OV511=m
CONFIG_USB_PWC=m
CONFIG_USB_SE401=m
CONFIG_USB_SN9C102=m
CONFIG_USB_STV680=m
CONFIG_USB_W9968CF=m
# USB Network adaptors
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_USBNET=m
# USB Host-to-Host Cables
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_GENESYS=y
CONFIG_USB_NET1080=y
CONFIG_USB_PL2301=y
# Intelligent USB Devices/Gadgets
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_ZAURUS=y
CONFIG_USB_CDCETHER=y
# USB Network Adapters
CONFIG_USB_AX8817X=y
# USB port drivers
CONFIG_USB_USS720=m
# USB Serial Converter support
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_SAFE=m
# CONFIG_USB_SERIAL_SAFE_PADDED is not set
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_EZUSB=y
# USB Miscellaneous drivers
CONFIG_USB_TIGL=m
CONFIG_USB_AUERSWALD=m
CONFIG_USB_RIO500=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_LED=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_PHIDGETSERVO=m
CONFIG_USB_TEST=m
# USB Gadget Support
CONFIG_USB_GADGET=m
CONFIG_USB_GADGET_NET2280=y
CONFIG_USB_NET2280=m
# CONFIG_USB_GADGET_PXA2XX is not set
# CONFIG_USB_GADGET_GOKU is not set
# CONFIG_USB_GADGET_SA1100 is not set
# CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_ZERO=m
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_GADGETFS=m
CONFIG_USB_FILE_STORAGE=m
# CONFIG_USB_FILE_STORAGE_TEST is not set
CONFIG_USB_G_SERIAL=m
# Firmware Drivers
CONFIG_EDD=m
# File systems
CONFIG_EXT2_FS=m
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT3_FS=m
CONFIG_EXT3_FS_XATTR=y
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_JBD=m
# CONFIG_JBD_DEBUG is not set
CONFIG_FS_MBCACHE=m
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
# CONFIG_REISERFS_FS_XATTR is not set
CONFIG_JFS_FS=m
CONFIG_JFS_POSIX_ACL=y
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_FS_POSIX_ACL=y
CONFIG_XFS_FS=m
CONFIG_XFS_RT=y
CONFIG_XFS_QUOTA=y
CONFIG_XFS_SECURITY=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_MINIX_FS=m
CONFIG_ROMFS_FS=m
CONFIG_QUOTA=y
CONFIG_QFMT_V1=m
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS_FS=m
CONFIG_AUTOFS4_FS=m
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_ZISOFS_FS=m
CONFIG_UDF_FS=m
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
# CONFIG_NTFS_RW is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_SYSFS=y
CONFIG_DEVFS_FS=y
# CONFIG_DEVFS_MOUNT is not set
# CONFIG_DEVFS_DEBUG is not set
CONFIG_DEVPTS_FS_XATTR=y
CONFIG_DEVPTS_FS_SECURITY=y
CONFIG_TMPFS=y
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# Miscellaneous filesystems
CONFIG_ADFS_FS=m
# CONFIG_ADFS_FS_RW is not set
CONFIG_AFFS_FS=m
CONFIG_ASFS_FS=m
# CONFIG_ASFS_RW is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
CONFIG_BEFS_FS=m
# CONFIG_BEFS_DEBUG is not set
CONFIG_BFS_FS=m
CONFIG_EFS_FS=m
CONFIG_JFFS_FS=m
CONFIG_JFFS_FS_VERBOSE=0
CONFIG_JFFS_PROC_FS=y
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
# CONFIG_JFFS2_FS_NAND is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_CRAMFS=y
CONFIG_VXFS_FS=m
CONFIG_HPFS_FS=m
CONFIG_QNX4FS_FS=m
# CONFIG_QNX4FS_RW is not set
CONFIG_SYSV_FS=m
CONFIG_UFS_FS=m
# CONFIG_UFS_FS_WRITE is not set
# Network File Systems
CONFIG_NFS_FS=m
CONFIG_NFS_V3=y
CONFIG_NFS_V4=y
CONFIG_NFS_DIRECTIO=y
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_TCP=y
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=m
CONFIG_SUNRPC=m
CONFIG_SUNRPC_GSS=m
CONFIG_RPCSEC_GSS_KRB5=m
CONFIG_SMB_FS=m
# CONFIG_SMB_NLS_DEFAULT is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS is not set
# CONFIG_CIFS_XATTR is not set
# CONFIG_CIFS_POSIX is not set
CONFIG_NCP_FS=m
# CONFIG_NCPFS_PACKET_SIGNING is not set
# CONFIG_NCPFS_IOCTL_LOCKING is not set
# CONFIG_NCPFS_STRONG is not set
CONFIG_NCPFS_NFS_NS=y
CONFIG_NCPFS_OS2_NS=y
# CONFIG_NCPFS_SMALLDOS is not set
CONFIG_NCPFS_NLS=y
CONFIG_NCPFS_EXTRAS=y
CONFIG_CODA_FS=m
# CONFIG_CODA_FS_OLD_API is not set
CONFIG_AFS_FS=m
CONFIG_RXRPC=m
# Partition Types
CONFIG_PARTITION_ADVANCED=y
CONFIG_ACORN_PARTITION=y
CONFIG_ACORN_PARTITION_CUMANA=y
# CONFIG_ACORN_PARTITION_EESOX is not set
CONFIG_ACORN_PARTITION_ICS=y
# CONFIG_ACORN_PARTITION_ADFS is not set
# CONFIG_ACORN_PARTITION_POWERTEC is not set
CONFIG_ACORN_PARTITION_RISCIX=y
CONFIG_OSF_PARTITION=y
CONFIG_AMIGA_PARTITION=y
CONFIG_ATARI_PARTITION=y
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
CONFIG_BSD_DISKLABEL=y
CONFIG_MINIX_SUBPARTITION=y
CONFIG_SOLARIS_X86_PARTITION=y
CONFIG_UNIXWARE_DISKLABEL=y
CONFIG_LDM_PARTITION=y
# CONFIG_LDM_DEBUG is not set
CONFIG_SGI_PARTITION=y
CONFIG_ULTRIX_PARTITION=y
CONFIG_SUN_PARTITION=y
# CONFIG_EFI_PARTITION is not set
# Native Language Support
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="cp437"
CONFIG_NLS_CODEPAGE_437=m
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
CONFIG_NLS_UTF8=m
# Profiling support
CONFIG_PROFILING=y
CONFIG_OPROFILE=m
# Kernel hacking
# CONFIG_DEBUG_KERNEL is not set
CONFIG_MAGIC_SYSRQ=y
# CONFIG_FRAME_POINTER is not set
# Security options
CONFIG_SECURITY=y
# CONFIG_SECURITY_NETWORK is not set
CONFIG_SECURITY_CAPABILITIES=m
CONFIG_SECURITY_ROOTPLUG=m
# CONFIG_SECURITY_SELINUX is not set
# Cryptographic options
CONFIG_CRYPTO=y
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_AES=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_ARC4=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_TEST=m
# Library routines
CONFIG_CRC_CCITT=m
CONFIG_CRC32=m
CONFIG_LIBCRC32C=m
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=m
Grub : menu.lst ( /boot/grub )
# menu.lst - See: grub(8), info grub, update-grub(8)
#            grub-install(8), grub-floppy(8),
#            grub-md5-crypt, /usr/share/doc/grub
#            and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
default  0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout  5
splashimage=(hd1,0)/boot/grub/splashimages/debian_cooleye.xpm.gz
# Pretty colours
color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line)  and entries protected by the
# command 'lock'
# e.g. password topsecret
#      password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title  Windows 95/98/NT/2000
# root  (hd0,0)
# makeactive
# chainloader +1
# title  Linux
# root  (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default optons below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specifiv kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
# kopt=root=/dev/hdb1 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=(hd1,0)
## should update-grub create alternative automagic boot options
## e.g. alternative=true
##      alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
##      lockalternative=false
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
##      altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
##      howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
##      memtest86=false
# memtest86=true
## ## End Default Options ##
title  Debian GNU/Linux, kernel 2.6.9-test
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.9 root=/dev/hdb1 ro
savedefault
boot
title  Debian GNU/Linux, kernel 2.6.8-9-amd64-k8
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.8-9-amd64-k8 root=/dev/hdb1 ro
initrd  /boot/initrd.img-2.6.8-9-amd64-k8
savedefault
boot
title  Debian GNU/Linux, kernel 2.6.8-9-amd64-k8 (recovery mode)
root  (hd1,0)
kernel  /boot/vmlinuz-2.6.8-9-amd64-k8 root=/dev/hdb1 ro single
savedefault
boot
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title  Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/hda1
title  Microsoft Windows XP Professionnel
root  (hd0,0)
savedefault
makeactive
chainloader +1
Ou est ce que je me plante ?
merci de m'aider
PS : je ne veux pas installer un noyau tout fait
je veux juste apprendre et pouvoir le modifier par la suite
Marsh Posté le 04-01-2005 à 17:40:54
Si tout tes systèmes de fichiers sont en modules, ça risque pas de marcher.
Tu dois compiler en dur celui qui correspond au système de fichier de ta partition (ou faire un initrd mais bon).
Marsh Posté le 04-01-2005 à 17:41:48
Ça me gave de lire tout ton .config, mais tu as certainement oublié de mettre en dur ton controleur de disque dur ou ton système de fichiers.
Marsh Posté le 04-01-2005 à 17:42:12
tu aurais tout les pilotes de filesystem en modules par hasard... du coup forcément c'est dur pour le noyau d'aller chercher le bon module sur une partition qu'il ne peut pas lire ;)
Chết rồi ! ✍ ⌥⌘ http://codeberg.org/gwh
Marsh Posté le 04-01-2005 à 17:42:57
Combo :D
Marsh Posté le 04-01-2005 à 17:43:54
J'vous ai quand même tous grillé [:udok]
Marsh Posté le 04-01-2005 à 17:44:06
Grillé une fois mais j'en ai quand même grillé un :D
Marsh Posté le 04-01-2005 à 17:45:30
oui mais moi j'ai au moins parcouru son .config pour constater que les fs sont en module :p
Marsh Posté le 04-01-2005 à 17:48:30
Erreur tellement classique du débutant que ça valait même pas la peine de vérifier que c'était ça  :kaola:
Marsh Posté le 05-01-2005 à 16:20:37
voila merci
vi je suis debutant
j'ai repris ce .config du Kernel-header-2.6.8-9-AMD-K8 de la distrib SARGE-Debian AMD64
Maintenant c'est d'autres p'tit soucis que j'arrive pas à resoudre
Ma carte son est une Hercule Game Theater xp j'ai donc mis en module le SND-cs46XX pour profiter du son de ma carte
mais voila quand je log dans KDE je n'ai pas de son tout de suite apres 30 secondes j'ai un message qui pop
"Sound server fatal error - CPU OVERLOAD - Abording"
ensuite quand je clicke sur le ok de ce message le son fonctionne
Marsh Posté le 05-01-2005 à 16:23:02
T'as fais une recherche sur Google avant ? :o
http://www.linuxquestions.org/ques [...] did=151126
