[Debian Etch/2.6.18] Problème de make menuconfig
Problème de make menuconfig [Debian Etch/2.6.18] - Installation - Linux et OS Alternatifs
Marsh Posté le 30-06-2007 à 15:16:55
Bonjour à tous !
        J'essaye de compiler mon noyau et voici l'erreur que j'obtiens sur un make menuconfig:
  1. make menuconfig
  2.   HOSTCC  scripts/basic/fixdep
  3.   HOSTCC  scripts/basic/docproc
  4.   HOSTCC  scripts/kconfig/conf.o
  5.   HOSTCC  scripts/kconfig/kxgettext.o
  6.   HOSTCC  scripts/kconfig/mconf.o
  7.   HOSTCC  scripts/kconfig/zconf.tab.o
  8.   HOSTLD  scripts/kconfig/mconf
  9.   HOSTCC  scripts/kconfig/lxdialog/checklist.o
  10. In file included from scripts/kconfig/lxdialog/checklist.c:24:
  11. scripts/kconfig/lxdialog/dialog.h:31:20: error: curses.h: Aucun fichier ou répertoire de ce type
  12. In file included from scripts/kconfig/lxdialog/checklist.c:24:
  13. scripts/kconfig/lxdialog/dialog.h:128: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âuse_colorsâ
  14. scripts/kconfig/lxdialog/dialog.h:129: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âuse_shadowâ
  15. scripts/kconfig/lxdialog/dialog.h:131: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âattributesâ
  16. scripts/kconfig/lxdialog/dialog.h:143: error: expected â)â before â*â token
  17. scripts/kconfig/lxdialog/dialog.h:146: error: expected â)â before â*â token
  18. scripts/kconfig/lxdialog/dialog.h:147: error: expected â)â before â*â token
  19. scripts/kconfig/lxdialog/dialog.h:148: error: expected â)â before â*â token
  20. scripts/kconfig/lxdialog/dialog.h:149: error: expected â)â before â*â token
  21. scripts/kconfig/lxdialog/dialog.h:151: error: expected â)â before â*â token
  22. scripts/kconfig/lxdialog/checklist.c:31: error: expected â)â before â*â token
  23. scripts/kconfig/lxdialog/checklist.c:59: error: expected â)â before â*â token
  24. scripts/kconfig/lxdialog/checklist.c:95: error: expected â)â before â*â token
  25. scripts/kconfig/lxdialog/checklist.c: In function âdialog_checklistâ:
  26. scripts/kconfig/lxdialog/checklist.c:117: error: âWINDOWâ undeclared (first use in this function)
  27. scripts/kconfig/lxdialog/checklist.c:117: error: (Each undeclared identifier is reported only once
  28. scripts/kconfig/lxdialog/checklist.c:117: error: for each function it appears in.)
  29. scripts/kconfig/lxdialog/checklist.c:117: error: âdialogâ undeclared (first use in this function)
  30. scripts/kconfig/lxdialog/checklist.c:117: error: âlistâ undeclared (first use in this function)
  31. scripts/kconfig/lxdialog/checklist.c:117: warning: left-hand operand of comma expression has no effect
  32. scripts/kconfig/lxdialog/checklist.c:121: warning: implicit declaration of function âendwinâ
  33. scripts/kconfig/lxdialog/checklist.c:122: warning: implicit declaration of function âfprintfâ
  34. scripts/kconfig/lxdialog/checklist.c:122: warning: incompatible implicit declaration of built-in function âfprintfâ
  35. scripts/kconfig/lxdialog/checklist.c:122: error: âstderrâ undeclared (first use in this function)
  36. scripts/kconfig/lxdialog/checklist.c:140: error: âCOLSâ undeclared (first use in this function)
  37. scripts/kconfig/lxdialog/checklist.c:141: error: âLINESâ undeclared (first use in this function)
  38. scripts/kconfig/lxdialog/checklist.c:143: warning: implicit declaration of function âdraw_shadowâ
  39. scripts/kconfig/lxdialog/checklist.c:143: error: âstdscrâ undeclared (first use in this function)
  40. scripts/kconfig/lxdialog/checklist.c:145: warning: implicit declaration of function ânewwinâ
  41. scripts/kconfig/lxdialog/checklist.c:146: warning: implicit declaration of function âkeypadâ
  42. scripts/kconfig/lxdialog/checklist.c:146: error: âTRUEâ undeclared (first use in this function)
  43. scripts/kconfig/lxdialog/checklist.c:148: warning: implicit declaration of function âdraw_boxâ
  44. scripts/kconfig/lxdialog/checklist.c:148: error: âattributesâ undeclared (first use in this function)
  45. scripts/kconfig/lxdialog/checklist.c:149: warning: implicit declaration of function âwattrsetâ
  46. scripts/kconfig/lxdialog/checklist.c:150: warning: implicit declaration of function âmvwaddchâ
  47. scripts/kconfig/lxdialog/checklist.c:152: warning: implicit declaration of function âwaddchâ
  48. scripts/kconfig/lxdialog/checklist.c:156: warning: implicit declaration of function âprint_titleâ
  49. scripts/kconfig/lxdialog/checklist.c:159: warning: implicit declaration of function âprint_autowrapâ
  50. scripts/kconfig/lxdialog/checklist.c:166: warning: implicit declaration of function âsubwinâ
  51. scripts/kconfig/lxdialog/checklist.c:191: warning: implicit declaration of function âprint_itemâ
  52. scripts/kconfig/lxdialog/checklist.c:197: warning: implicit declaration of function âprint_arrowsâ
  53. scripts/kconfig/lxdialog/checklist.c:200: warning: implicit declaration of function âprint_buttonsâ
  54. scripts/kconfig/lxdialog/checklist.c:202: warning: implicit declaration of function âwnoutrefreshâ
  55. scripts/kconfig/lxdialog/checklist.c:204: warning: implicit declaration of function âdoupdateâ
  56. scripts/kconfig/lxdialog/checklist.c:207: warning: implicit declaration of function âwgetchâ
  57. scripts/kconfig/lxdialog/checklist.c:214: error: âKEY_UPâ undeclared (first use in this function)
  58. scripts/kconfig/lxdialog/checklist.c:214: error: âKEY_DOWNâ undeclared (first use in this function)
  59. scripts/kconfig/lxdialog/checklist.c:224: error: âFALSEâ undeclared (first use in this function)
  60. scripts/kconfig/lxdialog/checklist.c:225: warning: implicit declaration of function âscrollokâ
  61. scripts/kconfig/lxdialog/checklist.c:226: warning: implicit declaration of function âwscrlâ
  62. scripts/kconfig/lxdialog/checklist.c:235: warning: implicit declaration of function âwrefreshâ
  63. scripts/kconfig/lxdialog/checklist.c:285: warning: incompatible implicit declaration of built-in function âfprintfâ
  64. scripts/kconfig/lxdialog/checklist.c:286: warning: implicit declaration of function âdelwinâ
  65. scripts/kconfig/lxdialog/checklist.c:290: error: âKEY_LEFTâ undeclared (first use in this function)
  66. scripts/kconfig/lxdialog/checklist.c:291: error: âKEY_RIGHTâ undeclared (first use in this function)
  67. make[2]: *** [scripts/kconfig/lxdialog/checklist.o] Erreur 1
  68. make[1]: *** [menuconfig] Erreur 2
  69. make: *** [menuconfig] Erreur 2
Je ne vois pas ce qui cloche ! on dirait qu'il me manque un package ? D'ou vient d'erreur !?
Merci d'avance !
RedVivi[cpp]
Message édité par redvivi le 30-06-2007 à 15:19:02
Marsh Posté le 30-06-2007 à 15:44:00
il te faut le paquet de developpement de ncurses : libncurses5-dev
Ce n'est point ma façon de penser qui a fait mon malheur, c'est celle des autres.
Marsh Posté le 30-06-2007 à 16:02:51
Merci ! ça marche !
Marsh Posté le 30-06-2007 à 16:32:24
Après la création du paquet deb kernel-image avec fakeroot et son installation, fautil modifier grub ?
Marsh Posté le 30-06-2007 à 16:33:38
Normalement il le fait à l'installation du paquet comme un grand.
Tu peux toujours verifier en jetant un oeil à /boot/grub/menu.lst que ton nouveau noyau est bien configuré dans grub.
Marsh Posté le 30-06-2007 à 16:48:06
Ok, et pour la sauvegarde du noyau en cours ?
Marsh Posté le 30-06-2007 à 17:22:18
J'ai dis une betise !? ça ne se sauvegarde pas un noyau !?
Marsh Posté le 30-06-2007 à 17:41:27
C'est à dire ?
Si tu installes un nouveau noyau, l'ancien n'est pas supprimé pour autant.
Tant que tu ne desinstalles pas explicitement un noyau, il reste dispo et inclus dans le menu de grub.
Marsh Posté le 30-06-2007 à 19:56:28
Si grub le fait pas > update-grub
Marsh Posté le 30-06-2007 à 20:00:01
Ok ça fonctionne! Merci à tous !
