Probleme avec gmplayer ss mdk 9 (résolu)
Probleme avec gmplayer ss mdk 9 (résolu) - Débats - Linux et OS Alternatifs
Marsh Posté le 10-11-2002 à 08:48:47
j'ai recup les sources, j'ai compilé, installé, mplayer marche correctement (mais j'ai pas de commandes au clavier) mais impossible de lancer gmplayer pourtant j'ai mis l'option enable--GUI a la compilation...
au lancement j'ai ceci :
  1. Using GNU internationalization
  2. Original domain: messages
  3. Original dirname: /usr/share/locale
  4. Current domain: mplayer
  5. Current dirname: /usr/local/share/locale
  6. MPlayer 0.90pre9-3.2 (C) 2000-2002 Arpad Gereoffy (see DOCS)
  7. CPU: Advanced Micro Devices Athlon 4 PM Palomino/Athlon MP Multiprocessor/Athlon
  8. XP eXtreme Performance (Family: 6, Stepping: 2)
  9. CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
  10. Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE
  11. [cfg] read config file: /home/bitman/.mplayer/gui.conf
  12. Xlib:  extension "XFree86-VidModeExtension" missing on display ":0.0".
  13. vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display)
  14. Reading /home/bitman/.mplayer/codecs.conf: can't open '/home/bitman/.mplayer/cod              ecs.conf': No such file or directory
  15. Reading /usr/local/etc/mplayer/codecs.conf: 38 audio & 110 video codecs
  16. font: can't open file: /home/bitman/.mplayer/font/font.desc
  17. font: can't open file: /usr/local/share/mplayer/font/font.desc
  18. Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
  19. Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup               scripts.
  20. Using usleep() timing
  21. Can't open input config file /home/bitman/.mplayer/input.conf : No such file or               directory
  22. Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or               directory
  23. Falling back on default (hardcoded) input config
  24. Gdk-ERROR **: BadWindow (invalid Window parameter)
  25.   serial 166 error_code 3 request_code 20 minor_code 0
que faire ?
Message édité par bitman le 14-11-2002 à 08:35:24
Marsh Posté le 10-11-2002 à 10:20:27
il te manque peut-être une librairie gtk-devel ou un truc du même gout...
Marsh Posté le 10-11-2002 à 11:04:07
[:bresse] je pense pas ca c installé correctement...
par contre qqun peut m'expliquer ca :
et ca :
Marsh Posté le 10-11-2002 à 11:17:13
Deja tu devrais corriger toutes les petites merdes que tu as, à savoir :
* il ne trouve pas les fonts pour la gui, fauidrait les installer soit dans /home/bitman/.mplayer/font/ soit dans /usr/local/share/mplayer/font/
* Pour le RTC, laisse tomber ou change les droit sur /dev/rtc en jouant avec les users/groupes
* il ne trouve pas le fichier inout.conf. Ce n'est pas grave mais normalement, il devrait etre la
Voila corrige toutes ses petites erreurs, et on verra si ton erreur grave n'est pas une conséquence de celles la
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
Marsh Posté le 10-11-2002 à 11:19:21
et ca :
Ben il te manque l'extension XVIDEO, donc la lecture des films va  etre un peu molle :D  Tu as quelle carte video pour avoir ce message ???
Pour le 1024, il te dit juste que dans un souci d'optimisation, tu pourrais mettre cette valeur dans le fichier /proc/sys/dev/rtc/max-user-freq, mais je ne sais pas pq :)
Marsh Posté le 10-11-2002 à 11:32:48
j'ai une GF4 4200  :D (avec les drivers installés)
pour les ptites merde ok je veux bien les résoudres mais les fontes sont déja dans usr/ machin ...  :(
Message édité par bitman le 10-11-2002 à 11:33:02
Marsh Posté le 10-11-2002 à 12:36:48
T'aurais pas ca dans ton fichier XF86Config par hasard :
Option "DisableVidModeExtension" "true"
parce que sinan...
Ce n'est point ma façon de penser qui a fait mon malheur, c'est celle des autres.
Marsh Posté le 10-11-2002 à 13:57:50
nan mais laisse tomber ça, c'est pas méchant
par contre, regarde effectivement si tu n'as pas une options qui désactive le vidmode
et dis moi, tu lance bien gmplayer depuis l'utilisateur propriétaire de te session X ?
Marsh Posté le 10-11-2002 à 17:50:04
le msg plus haut c qd je lance a partir d'un shell
sinon je le lance en auto avec konqueror, comme xine etc quoi, en association de fichiers
Marsh Posté le 13-11-2002 à 00:47:13
Pourquoi ne pas installer la paquet du PLF ?
Marsh Posté le 13-11-2002 à 00:52:33
paske je n'ai aucune idée de ce que ca peut etre  :lol:
Marsh Posté le 13-11-2002 à 09:44:22
T'as pas repondu a ma question pour ta config XFree...
Marsh Posté le 13-11-2002 à 09:45:30
-> http://plf.zarb.org
Marsh Posté le 13-11-2002 à 11:28:47
sorry esprit, apres verif mon xfree etait comme il faut :D
hum apres un petit format pour cause d'acces au net impossible et irrésolvable (pour moi), j'ai repris l'install au départ en créant le fichier win32 des codecs AVANT de compiler le jambon, ca marche nickel  :D en root
par contre en user j'ai ca :
Failed to open /dev/rtc: Permission denied (mplayer should be setuid root or /dev/rtc should be readable by the user.)
ca a pas l'air bien méchant, si ce n'est que je ne sais pas quelle est la meilleure solution (ni comment le faire a vrai dire hihihi)
vous avez fait quoi vous autres ? :o
Message édité par bitman le 13-11-2002 à 11:29:53
Marsh Posté le 13-11-2002 à 11:39:41
tu fais "ls -l /dev/rtc" pour savoir a quel groupe il appartient, et tu ajoutes ton user dans le groupe en question.
Ca devrait faire l'affaire.
Marsh Posté le 13-11-2002 à 12:01:36
il appartiens a root, donc je me suis mis root en groupe supplémentaire pour "bitman" mais c pareil :/
edit : pas tout a fais le msg a change :
probleme résolu ! --> [root@bitmachine rtc]# echo 1024 > max-user-freq  :bounce:
oups pas résolu en fait gt resté en roor [:rougit]
je crois que gmplayer n'arrive pas a acceder aux rep de conf par défaut, il me cherche tout dans /home/bitman/.mplayer
Message édité par bitman le 13-11-2002 à 12:25:31
Marsh Posté le 13-11-2002 à 12:30:23
dans ce cas tu ruses en copiant les fichiers qui vont bien ou il faut :D
Marsh Posté le 13-11-2002 à 12:35:24
Oui, installe le PLF media, tu en auras besoin si un jour tu veux compresser des DVD en mpeg4.
urpmi.addmedia plf... etc c'est sur leur site.
Marsh Posté le 13-11-2002 à 13:11:35
j'ai urpmi le plf, mais a vrai dire j'ai pas top compris a quoi ca servais [:le kneu]
Marsh Posté le 13-11-2002 à 13:58:47
A ajouter une source de paquets pour urpmi.
PLF te donne accès à ces paquets :
Here you will find some package that cannot be included into the Mandrake distro for legal reasons (copyright/license/patent).
dont mplayer.
Donc commence par désinstaller ton mplayer foireux puis tu fais un :
urpmi mplayer-gui mplayer-fonts
Message édité par gm_superstar le 13-11-2002 à 13:59:59
Incongru : une FAQ abandonnée sur les Standards du Web - FAQ périmée de blabla@Prog
Marsh Posté le 13-11-2002 à 21:50:08
heuu l'est pas foireux mon mplayer  :cry:
cai juste qu'il marche ken root ! ca peut avoir un rapport avec le fait que j'ai tous fais en root pour l'install ?
Marsh Posté le 13-11-2002 à 21:52:55
:pfff:
Marsh Posté le 13-11-2002 à 21:54:23
lol !  :lol:
mais les releases se suivent à un rythme efreiné ces temps ci  :D
aller hop, une petite install de mplayer
Marsh Posté le 13-11-2002 à 21:57:54
huummmm la question a 10.000 ?
je sais installer compiler ca va c pas dur, mais...désinstaller je fais comment ?  [:totoz]
ou alors je urpmise par dessus mais c la mdk 9 j'ai peur que ca merde (ya plein de rpm qui chibrent avec ste distro non ?)
Marsh Posté le 13-11-2002 à 22:17:46
make uninstall ?
Sinon tout ce qui est installé est normalement dans /usr/local/ donc il te suffira de regarder ce qu'il y a dans les sous-répertoires, et supprimer à la main ce que mplayer a mis...
Marsh Posté le 13-11-2002 à 22:24:31
c'est tout ? :o
Marsh Posté le 13-11-2002 à 23:05:41
L'installation a échoué:
        libdv2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libggi2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgii0 est nécessaire à mplayer-0.90-0.pre9.3plf
        libdv.so.2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libggi.so.2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgg.so.0 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgii.so.0 est nécessaire à mplayer-0.90-0.pre9.3plf
        liblzo.so.1 est nécessaire à mplayer-0.90-0.pre9.3plf
[root@bitmachine mplayer]#
génial non ?  :lol:
je suppose kil existe une fonction pour savoir quel paquet installer pour avoir des libs non ?
urpmi m'a DL ceci :
libdha0.1-0.90-0.pre9.3plf.i586.rpm  mplayer-fonts-1.0-3plf.noarch.rpm
libfaad2_0-1.1-2plf.i586.rpm         mplayer-gui-0.90-0.pre9.3plf.i586.rpm
liblirc0-0.6.5-2mdk.i586.rpm         mplayer-skins-1.3-1plf.noarch.rpm
libmad0-0.14.2b-4mdk.i586.rpm        win32-codecs-1.0-1plf.i586.rpm
libnas2-1.6-1mdk.i586.rpm            xvid-20021107-1plf.i586.rpm
mplayer-0.90-0.pre9.3plf.i586.rpm
j'ai installé toutes les libs, le xvid, nickel, mais le mplayer y veut pas  :(
Message édité par bitman le 13-11-2002 à 23:12:01
Marsh Posté le 13-11-2002 à 23:16:23
Tu dois installer une source pour les contribs aussi :
urpmi.addmedia contrib ftp://ftp.lip6.fr/pub/linux/distr [...] ntrib/RPMS with ../../i586/Mandrake/base/hdlist2.cz
et tu refais urpmi mplayer-gui il te téléchargera les paquets qui manquent.
Marsh Posté le 13-11-2002 à 23:40:24
en effet il m'a téléchargé des trucs en plus, mplayer etc c'est installé comme il faut, il marche nickel en root, et ca foire encore en user ...  :cry:
CPU: Advanced Micro Devices Athlon 4 PM Palomino/Athlon MP Multiprocessor/Athlon XP eXtreme Performance (Family: 6, Stepping: 2)
Reading /home/bitman/.mplayer/codecs.conf: can't open '/home/bitman/.mplayer/codecs.conf': No such file or directory
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Linux hardware RTC timing (1024Hz)
SKIN dir 1: '/home/bitman/.mplayer/Skin'
SKIN dir 2: '/usr/local/share/mplayer/Skin'
[skin] error in skin config file on line 10: file not found ( /usr/local/share/mplayer/Skin/default/main )
Skin configfile read error ( default ).
[bitman@bitmachine bitman]$
fo que je lui donne des permission je crois, paskil arrive pas a lire/ecrire dans mon ./mplayer non ?
Message édité par bitman le 13-11-2002 à 23:44:56
Marsh Posté le 13-11-2002 à 23:54:59
derniere information : en lisant mes fichiers avec mplayer, ca lance le gui aussi, donc j'oublie le mystere des gmplayer pour l'instant  :o
merci a ceux qui m'ont proposé leur aide ! :bounce:
Marsh Posté le 13-11-2002 à 23:59:29
Marsh Posté le 14-11-2002 à 00:03:39
gm_superstar a écrit a écrit :
urpmi mplayer-skins ?
ils y sont (sont moches d'ailleurs hihihi)
Marsh Posté le 14-11-2002 à 00:22:03
Bon en fait tu dois modifier ton fichier de config et remplacer toutes les occurences de /usr/local/share par /usr/share/
Marsh Posté le 14-11-2002 à 00:50:50
Essaie Proton alors.
Marsh Posté le 14-11-2002 à 01:01:05
cai celle que j'ai choisie  :)
zoli player mplayer, mieux que xine je trouve, meme si j'en ai chié un peu pour l'installer :/
Marsh Posté le 14-11-2002 à 08:17:21
j'ai eu le meme probleme ,
Il a suffit que je fasse
chmod -R 755 /usr/local/share/mplayer/
Marsh Posté le 14-11-2002 à 08:21:59
argh la solution au moment ou j'en avait plus besoin !!!!  :D
