P4B266, P4B266-E et P4B266-SE - Hardware
Marsh Posté le 17-05-2002 à 18:24:49
La p4B n'a pas d'USB 2 si je ne me trompe... Il ne sera dispo qu'avec la P4B533.
Raid c'est possible, mais il est sur laquelle le RAID
Marsh Posté le 17-05-2002 à 18:26:52
la se
Processor
Socket 478 for FC-PGA2 Pentium® 4 (Willamette/Northwood) 1.4GHz to 2.4GHz+
Chipset
North Bridge: Intel® 82845D Memory Controller Hub (Brookdale)
South Bridge: Intel® 82801BA I/O Controller Hub 2 (ICH2)
FSB
400 MHz
Memory
3 x DDR DIMM Sockets,
Max. 2GB unbuffered PC2100/PC1600 ECC/non-ECC DDR SDRAM Memory
Expansion Slots
1 x AGP 4X
6 x PCI
1 x CNR
VGA
AGP 4X Slot
Audio (Optional)
C-Media CMI8738 6-Channel Audio Controller
Hardware Monitoring
ASUS ASIC BACH
Special Features
Smart Card Reader Support
ASUS® MyLogo? for customized boot logos
ASUS® EZ Plug? for flexible power connectivity
ASUS® JumperFree?
S/PDIF in/out interface (Optional)
SFS (Stepless Frequency Selection)
Vcore & Vio adjustable
Internal I/O Interfaces
CD Audio-In Connector (Optional)
AUX Audio-In Connector (Optioanl)
Voice Modem Connector (Optional)
USB 1.1 connector to Support optional 2 USB Ports
CPU/SPS/Chassis FAN connectors
ATX Power Connector
IDE LED Connector
Front MIC & Headphone connectors
Back Panel I/O
2 x Serial Ports, 1 x Parallel Port, PS/2 Keyboard and Mouse Connector,
Game/Mic-in/Line-in/Line-out Ports (Optional), 2 USB 1.1 Ports
BIOS Feature
2Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, JumperFree
Form Factor
ATX
12" x 9.4" (30.5cm x 23.0cm)
la e
Processor
Chipset
FSB
400 MHz
Memory
Expansion Slots
1 x AGP 4X
6 x PCI
1 x CNR
VGA
AGP 4X Slot
Audio (Optional)
C-Media 8738 6-Channel Audio Controller
LAN Onboard (Option)
Intel 100/10Mbps Ethernet LAN Controller
Hardware Monitoring
ASUS ASIC BACH
Special Features
RAID Promise 20276 dual-channel ATA133 RAID 0, 1 (Optional)
USB 2.0 support (optional)
ASUS POST Reporter? for system voice warning
Memory Stick and Secure Digital Reader Support
ASUS MyLogo? for customizable boot logos
ASUS EZ Plug? for flexible power connectivity
ASUS® JumperFree?
Adjustable CPU Vcore & DDR Memory Voltage
Support iPanel
USB 2.0 connector to Support optional 4 USB Ports (optional)
ATX Power Connector
IDE LED Connector
Smart Card / Memory Stick / SD Reader connectors
Back Panel I/O
Game/Mic-in/Line-in/Line-out Ports, 2 USB 1.1 Ports, 2 USB 2.0 Ports, RJ-45 LAN Port (option)
BIOS Feature
4Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, JumperFree?
Form Factor
ATX
12.0" x 9.6" (30.5cm x 24.5cm)
la 266 Processor
Chipset
FSB
400 MHz
Memory
Expansion Slots
1 x AGP 4X
6 x PCI
1 x CNR
VGA
AGP 4X Slot
Audio (Optional)
Intel 100/10 Mbps Ethernet LAN Controller
Hardware Monitoring
ASUS ASIC BACH
Special Features
ASUS® POST Reporter? for system voice warnings
ASUS® JumperFree?
AUX Audio-In Connector (Optional)
ATX Power Connector
IDE LED Connector
Back Panel I/O
Game/Mic-in/Line-in/Line-out Ports (option), 2 USB 1.1 Ports, RJ-45 LAN Port (option)
BIOS Feature
Form Factor
ATX
[jfdsdjhfuetppo]--Message édité par machistador le 17-05-2002 à 18:28:13--[/jfdsdjhfuetppo]
Marsh Posté le 17-05-2002 à 18:30:00
Ca c'est de la réponse détaillée !!!
Je lis tout ça et je reviens...
Marsh Posté le 17-05-2002 à 18:37:30
Toutes I845D
P4B266 = P4B266-SE + USB 2.0
P4B266-E = P4B266 + Raid ATA 133
le tout de mémoire
à confirmer
Marsh Posté le 17-05-2002 à 18:40:59
Ca c'est du résumé
C'est d'ailleurs ce que je faisais...
Marsh Posté le 17-05-2002 à 18:56:59
C'est clair que le RAID j'en veux pas... (Y'a pas une version sans IDE
Mais l'USB 2... Au pire on peut le mettre en externe mais ça va revenir au même prix que le modèle qui l'intègre !
Marsh Posté le 17-05-2002 à 18:58:52
En résumé :
Commun à toutes :
- Processor
Chipset
FSB
400 MHz
Memory
Expansion Slots
1 x AGP 4X
6 x PCI
1 x CNR
VGA
AGP 4X Slot
Audio (Optional)
Hardware Monitoring
ASUS ASIC BACH
Special Features
ASUS® JumperFree?
Back Panel I/O
ATX Power Connector
IDE LED Connector
BIOS Feature
2Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, JumperFree? (4Mb pour la E mais on s'en fout...)
Form Factor
ATX
12" x 9.4" (30.5cm x 23.0cm) (+0.2" pour la E mais on s'en fout...)
Marsh Posté le 17-05-2002 à 19:02:05
Les différences :
--- LA SE : ----------------
Back Panel I/O
--- LA 266 : ---------------
Special Features
Back Panel I/O
--- LA E : -----------------
Special Features
Support iPanel
Back Panel I/O
Marsh Posté le 17-05-2002 à 19:04:35
En gros si je veux mettre un iPanel, je me farcis toutes les saloperies dont je ne veux pas... (Son, Réseau, RAID, ...)
C'est la merde quoi...
Marsh Posté le 17-05-2002 à 19:11:53
meuh non tu met ca!
http://www.jackypc.com/index2.php3?rub=articles&num=97
Marsh Posté le 17-05-2002 à 20:17:21
On m'a dit ici http://forum.hardware.fr/forum2.ph [...] =0&config= que les P4B266 n'aiment pas trop les barettes de ram Dane Elec.
Qqun peut confirmer ça ?
Marsh Posté le 17-05-2002 à 18:21:07
C'est quoi la différence ?
Quelqu'un peut me faire un récapitulatif ?
Je ne sais pas pourquoi, mais je n'arrive pas à accéder au site d'Asus...
"Dura lex, sed lex" (La Loi est dure mais c'est la Loi)
