carte mère asus P2B et DD de 40Go - Hardware
Marsh Posté le 25-01-2002 à 10:24:54
Flash bios mais de toute facon tes disques tourneront en 66... la P2b ne fait pas le 100
Marsh Posté le 25-01-2002 à 10:28:49
heu... j'prend lequel ?
asupd328.exe ASUS LiveUpdate V3.28.03 for Windows 9X/ ME/ 2000/ NT4.0.
aflash.exe ASUS Plug and Play BIOS Flash Utility v1.32.
1. Add support for EON EN29F040.
2. Add support for SST 39SF040.
3. Add support for ST FWH M50FW040.
4. Add support for SST FWH 49LF004A.
flashk7m.exe ASUS Flash Utility for K7M series motherboard. Also known as Flash822.exe.
flash.exe ASUS Non Plug and Play BIOS Flash Utility for 1~2MB Flash EEPROM.
t2decu.zip EISA CFG Rev. 3.02A file for P/E-P55T2P4D M/B, DRAM configured up to 512MB.
asu5101.zip EISA CFG file for PCI/E-P54NP4 M/B, DRAM configureed up to 512MB.
ecu.zip EISA Configuration Utility for ASUS EISA motherboard.
icu_dos.zip ICU (ISA Configuration Utility) DOS version 1.24. * For Plug and Play BIOS only.
icu_win.zip
ICU (ISA Configuration Utility) Windows version 1.41. * For Plug and Play BIOS only.
Marsh Posté le 25-01-2002 à 10:32:52
c'est pas ce truc plutôt ?
bx2i1011.zip P2B BIOS Ver. 1011. 10/28/99
Support IDE hard disk larger than 32G bytes.
Revise microcode update support for Cu-Mine processors.
Fix Microsoft Pre-OS test failure Add microcode update support for Coppermine cA-2 stepping. (681)
Microcode update upgrade for PII 653, 672, and 673. 653: 00A->010; 672: 00B->00C; 673: 007->00A.
Fix boot failure with some boot managers installed.
Fix NMI error generated when some AGP card installed.
Fix Russian Y2K test program failed.
mais c'est dans les "Bios update files" et non "Bios Flash Utilities"...
c'est quoi la != entre les deux ?
[edtdd]--Message édité par Moustaaki--[/edtdd]
Marsh Posté le 25-01-2002 à 10:34:28
Moustaaki a écrit a écrit : c'est pas ce truc plutôt ? bx2i1011.zip P2B BIOS Ver. 1011. 10/28/99 Support IDE hard disk larger than 32G bytes. Revise microcode update support for Cu-Mine processors. Fix Microsoft Pre-OS test failure Add microcode update support for Coppermine cA-2 stepping. (681) Microcode update upgrade for PII 653, 672, and 673. 653: 00A->010; 672: 00B->00C; 673: 007->00A. Fix boot failure with some boot managers installed. Fix NMI error generated when some AGP card installed. Fix Russian Y2K test program failed. |
oui plutot celui la avec support disque plus grand que 32 .
Marsh Posté le 25-01-2002 à 10:42:07
burdigala a écrit a écrit : oui plutot celui la avec support disque plus grand que 32 . |
ok... maintenant, j'ai un fichier awd, j'en fais quoi ?
Marsh Posté le 25-01-2002 à 10:47:13
Je te conseille fortement de lire la procedure de flashage sur le site asus.
Marsh Posté le 25-01-2002 à 10:50:09
Après tu télécharges l'utilitaire "awdflash.exe" (en cherchant bien ça se trouve facilement)
tu le mets sur une disquette de boot avec ton fichier .awd
tu démarres ton pc sur la disquette et tu lance awdflash
ensuite tu fais ce qu'il te dit (note bien le non du fichier .awd pour pas écrire de conneries)
Marsh Posté le 25-01-2002 à 11:09:37
tu aura tout ce qui te faut ici:
http://www.clubic.com/m/pilotes/110.html
Perso j'ai utilisé BIOS Flash Utility v1.37 -> qui contient 'aflash.exe' DOS
Et le firmware 1012
J'ai une ASUS P2B Rev1.04
Marsh Posté le 25-01-2002 à 11:12:02
ok ! merci bp tout le monde !
en éspèrant que j'aurais pas encore des merdes (j'viens de bousiller mon modem BeWan adsl PCI d'une semaine...
je vous souhaite à tous une bonne journée et un bon we !
ciao
Marsh Posté le 25-01-2002 à 10:23:45
Qu'est ce qu'il faut faire pour que ma carte mère asus P2B accepte les gros disques durs (Maxtor/Western 40Go UDMA 100) ?
Que faut-il télécharger ? driver IDE ? flash du BIOS ? autre ?
