Boutique HTPC/Mini-Pc - Exclu boitiers inside - Venez-voir ! [Projet] - Mini PC - Hardware
Marsh Posté le 17-12-2010 à 11:45:00
Première proposition en full aluminium :
Model: e5
Material: Aluminum 100%
Color: Black / Silver / Gold
Support Motherboard: Micro ATX / Mini ITX
Motherboard
HDD: 2x3.5''(or 1x2.5''+1x3.5'') standard hard
drive bits
ODD: 1*1slim slot-loading optical drive
Cooling Devices: 2× 60X60X15mm ultra-quiet
fans, multi-hole design of cooling
Extension Function: equipped with 1xbig PCI
expansion slots standard, 1 eSATA expansion
Front Interface: 2 USB
Card Reader: Multi-Card Reader
Power Position: Standard 1U chassis PSU or
Built-in board PSU
Remote Control: Optional MCE remote control
with internal IR
Net Weight: 4.2KG
Model: eHDD
Hard Drive Slots: 10x3.5-inch drive bays
Dimension: 435mm × 390mm × 70mm (length ×
width × height)
Power Position:: Flex ATX PSU supply
Cooling :2x60mmx60mmx15mm silent fans,
2x60mmx60mmx15mm silent fans bay,
Link Accessories: E-Sata expansion Board
(Optional)
Net Weight
Model: e6
Motherboard
HDD: 1x2.5''+2x3.5''standard hard drive bits
ODD: 1×5.2-inch standard optical drive
Cooling Devices: 2× 80X80X25mm ultra-quiet
Extension Function: 4xsmall PCI expansion
slots standard,
Power Position: Standard ATX PSU bay
with internal IR
Model: e6v
Motherboard
VFD screen:1xVFD screen
slots standard,
with internal IR
Model: e7
Support Motherboard: ATX / Micro ATX / Mini
ITX Motherboard
HDD: 4× 3.5'' standard hard drive
ODD: 1×5.2'' standard optical drive
Expansion slots:4x big PCI
Front Interface: 2USB ports
Dimension: 435X390X157mm (L*W*H)
Power Supply: Standard ATX power supply
position
Remote Control:Optional MCE remote control
with internal IR
Model: e7t
Touch screen:1x7'' touch screen LCD
ITX Motherboard
position
with internal IR
Model: Mini999
Material: outer aluminum in steel
Support Motherboard: Mini ITX Motherboard
HDD: 1× 2.5-inch standard hard drive
cooling:1个40mmx40mmx10mm ultra-quiet
fans,
Dimension:206mm×80mm×187mm (L*W*H)
Power Position: Optional Built-in board PSU
Net Weight:2.5KG
Material: 100% All aluminum
Color: black/red/silver
Support motherboard: Mini ITX motherboard
HDD: 1*2.5” standard hard drive bay
ODD: A slim slot-loading optical drive
Dimension: 197*197*75(L x W x H)
Power Supply: optional build in DC power
with internal IR
Net Weight: 1.6KG
Model: ITX 5
Color: silver/golden
Dimension: 200 x 200x 55mm(L x W x H)
Net Weight: 1.4KG
Model: ITX 7
Color: black/Golden/silver
HDD: 1*3.5” + 1*2.5'' standard hard drive bay
Dimension: 240*250*95(L x W x H)
with internal IR
Net Weight: 2.3KG
Model: ITX 7
Extension Function: equipped with 1xsmall PCI
expansion slots
Cooling Devices: 1× 80X80X25mm ultra-quiet fan
with internal IR
Marsh Posté le 17-12-2010 à 12:56:29
salut
uniquement en terme de boitier ? de carte mere et de tout le reste
y a pas vraiment de boutique vraiment specialisée dans le sff en langue francaise ![]()
perso je vais te deconseiller d importer du chinois c'est le meilleur moyen de chopé une mauvaise réputation
par contre du japonais ou du coréen
ps : tien les 2 boutiques les plus complete au niveau du sff en europe
http://www.mini-tft.de http://www.picco.nl/
pps: ne remonte pas ton topic toute les 10 minutes non plus le mcdo c'est pas ici
Marsh Posté le 17-12-2010 à 14:25:41
Il en faut pour tout les goûts.
La boutique proposera (à terme hein
) toute une gamme de produits adaptée au monde du mini-pc et du home-cinema, dont des boitiers, des cartes mères, de la ram, des alim micro, flex et nano, des télécommandes, etc...
En ce qui concerne les boitiers, l'objectif est évidemment de proposer des produits originaux, non disponibles chez le concurrent, forcément.
Je suis en contact avec de nombreux fabricants asiatiques : chinois, taiwanais, sud coréen et japonais.
Le problème des sud-coréen, c'est qu'ils ont déjà de nombreux partenaires oem pour l'Europe, et même si ce n'est pas pour le marché français à proprement parler, c'est verrouillé pour l'instant (à voir dans l'avenir, ils m'envoient aussi quelques signes encourageants alors bon
Les japonais privilégient souvent leur marché intérieur (pour les bonnes grosses marques j'entends).
Les produits présentés pour l'instant sont de conception taiwannaise, mais de fabrication chinoise, une qualité intermédiaire en somme.
J'ai aussi un partenaire taiwannais qui fait d'excellents boitiers home-cinema, avec écran oled et telco mce Philips, mais le problème c'est que la qualité à un prix et qu'en ce moment l'euro n'est pas au mieux de sa forme...
Contrairement au idées reçues, les chinois sont aussi capables de proposer de très bons produits, mais c'est comme partout, il faut monter en prix.
Lian Li et compagnie font faire leur produit en Chine (souvent à Shenzen), par les mêmes fabricants, il ne faut pas l'oublier, tout est question de cahier des charges.
En ce qui me (nous) concerne, il n'est pas question de devenir une marque qui conçoit des boitiers (comme Lan Gear présent aussi sur le forum), en tout cas pas dans un premier temps. On pense plutôt faire venir des produits qui existe déjà, mais qui ne sont pas accessibles au marché français, voire européen.
Et je pense qu'il en faut pour toute les bourses, y compris du plus "bas de gamme", tout est question de positionnement tarifaire et de marketing (à mettre en parallèle avec la ddr avec la gamme value par exemple).
Certains n'ont pas besoin d'un Lian-Li pour ce faire un petit NAS maison, mais voudraient quand même bien quelque chose de pas trop moche sous le bureau.
Sinon, je connaissais déjà les deux boutiques que tu m'a cité, merci quand même.
Personnellement, j'aimerais créer quelque chose de sensiblement différent, plus orienté home-cinema PC / NAS Home-Made, mais avec des produits plus originaux.
En ce qui concerne mes posts, ça n'était pas des "up", mais des "réservations".
Marsh Posté le 17-12-2010 à 15:49:07
Il y a des boitiers pour faire une configuration musclée (jeux, traitement lourds, etc.) ?
Marsh Posté le 17-12-2010 à 16:02:36
moi ce qui me manquerai le plus c'est des ALIM de puissance suffisante pour des machine un peu burnée a des tarifs admissible
Marsh Posté le 17-12-2010 à 16:51:44
| arkrom a écrit : moi ce qui me manquerai le plus c'est des ALIM de puissance suffisante pour des machine un peu burnée a des tarifs admissible |
Tu as le Silverstone SG06 qui est dispo avec une alim SFX 450W 80+ bronze pour faire quelque chose de compact (~11 litres) et un peu musclé. Mais j'en voie pas d'autre...
Marsh Posté le 17-12-2010 à 16:56:11
ca me dferai chier d'acheter un boitier pour pas l'utiliser et juste piquer l'alim .. en prime ca rentrera pas dans mon boitier actuelle
vu que, de memoire le sugo utilise une alim ATC conventionnelle, juste un peu plus "courte" non ??
edit , pour info je monte ca dans un SG45V2 qui a fumé sa mobal
... au pire je prendrai une alim made in shuttle, vu qu'ils ont des I7 y doit y avoir des trucs qui tiennent la charge au cataloque
edit 2
http://www.ldlc.com/fiche/PB00094994.html
500W bronze ... ca va, on a vu pire niveau tarif, c'est le bruit qui m'inquiète
Marsh Posté le 17-12-2010 à 17:03:53
| arkrom a écrit : ca me dferai chier d'acheter un boitier pour pas l'utiliser et juste piquer l'alim .. en prime ca rentrera pas dans mon boitier actuelle |
Non, alim au standard SFX (125 x 100 x 63.5 mm, ~0,79 litres), plus petit que le format ATX (150 x 160 x 86 mm, ~2 litres).
Disponible sur Materiel.net à 75€.
Marsh Posté le 17-12-2010 à 17:25:00
Merci à vous de faire vivre le topic, même si on frise le hs.
Justement, je cherche aussi des fabricants d'alim en flex-atx, micro-atx, et atx, de maxi 300/400W.
Aucun intérêt me direz-vous, y'en a déjà sur le net...
Oui, mais pas en 80+ bronze, silver ou gold, là ça se corse.
Pour l'instant, je suis brocou**le, mais je ne désespère pas.
En ce qui concerne les alim nano, c'est encore pire.
Marsh Posté le 17-12-2010 à 17:30:25
| zeblods a écrit : Il y a des boitiers pour faire une configuration musclée (jeux, traitement lourds, etc.) ? |
Ca par exemple, avec écran Oled et telco MCE
Je pense que ça laisse un peu de place...
Par contre le prix est trop élevé en ce moment, car l'euro est trop faible...
Marsh Posté le 17-12-2010 à 17:38:32
| nodarche a écrit : Merci à vous de faire vivre le topic, même si on frise le hs. Justement, je cherche aussi des fabricants d'alim en flex-atx, micro-atx, et atx, de maxi 300/400W. Aucun intérêt me direz-vous, y'en a déjà sur le net... Oui, mais pas en 80+ bronze, silver ou gold, là ça se corse. Pour l'instant, je suis brocou**le, mais je ne désespère pas. En ce qui concerne les alim nano, c'est encore pire. |
en effet ca derive "legerement"
au moins ca montre les problèmes qu'on a avec ce type de config
j'avais cherché aussi des alim type pico PSU en plus burnée et j'avais jamais trouvé plus de 250W
si tu veut du puissant et en taille contenu (mais a prix d'or
) vise les fabricant de matos embarqué indus
en alim open frame ou micro format pour rack 1/2U y a des trucs sympa pour celui qui a un rein en trop a vendre
Marsh Posté le 17-12-2010 à 17:42:14
ben heu les fabricant d alim sont connu , fsp forton , channel well, seasonic, topower, 7team
et si tu trouves ou supermicro fait fabriquer ses alim tu pourras avoir du 80+ platinium
ou encore comme akrom la dis les fabricant d alim industriel
Marsh Posté le 17-12-2010 à 17:51:23
| madpo a écrit : |
Se sont les principaux c'est clair, mais l'objectif est de trouver un fabriquant qui peut faire du 80+ bronze mini en format "exotique" ou sur moins de 300W, et là, à moins de lancer soit même une ligne production (et il est pas question de ça ici
), y'a pas grand chose.
Marsh Posté le 17-12-2010 à 17:56:40
Réflexions sur le sujet du mini-itx, puisque c'est la question.
Depuis des années (et plus) mes PC étaient dans une tour, avec une carte mère AT (c'est dire que c'est pas d'hier...) puis ATX, avec des cartes ISA, puis PCI, pour agrémenter l'ordinaire, et aussi parce qu'il fallait bien ajouter les fonctions qui n'étaient pas sur la carte mère ou USB.(graphique, son, réseau, SCSI, TV).
Un jour je me suis rendu compte que sur ma carte ATX il n'y avait pratiquement plus rien dans les slots PCI, alors je suis passé au Micro-ATX.
Le micro-ATX m'a permis de changer de boitier, en passant de la tour (je n'aimais pas le desktop), au format cube (Silverstone SG01), mieux adapté à mon mobilier actuel.
Maintenant, je vois qu'en mini-itx j'aurais pratiquement la même chose, mais qui pourrait s'intégrer dans un boitier plus petit, genre SG05, avec la même configuration.
Probablement ma prochaine machine sera mini-itx dans un boitier genre SG05, c'est pour dire que beaucoup d'utilisateurs qui ne se servent pas de leur machine pour jouer et se montent ou se font monter "une tour" désespérement vide, pourraient passer au mini-itx pour guère plus cher avec un résultat bien plus agréable à la vue et logeable plus facilement.
Ce marché ne devrait donc pas être réservé au HTPC ni au NAS perso ou mini serveur Linux d'utilisateur averti, mais destiné aussi à monsieur tout le monde pour son PC de tous les jours, pour peu que ce soit mis à sa portée et pas réservé au connaisseur.
çà ne remplacera pas le PC de chez XX à 299€ la tour en hypermarché, mais pour un public qui accepte un certain surcoût, çà peut être attrayant si la qualité est aussi au rendez vous.
Marsh Posté le 17-12-2010 à 17:58:50
| nodarche a écrit : |
ben heu forton a du 250 W gold , en open frame tu peu facilement trouver un equivalent 80+
Marsh Posté le 17-12-2010 à 18:42:57
C'est du beau boitier, c'est sur.
Mais en ce qui me concerne, je veux faire une configuration la plus compacte et silencieuse possible, tout en ne me limitant pas sur les performances : ce sera mon PC principal.
Plutôt un boitier dans le style du SG05/SC06/SG07, ou Lan Gear Infinity.
Mettre une carte mère mini-ITX dans un boitier capable d'acceuillir de l'ATX (cf. les 7 bais d'extension du boitier que tu m'as "proposé" ) je n'en voie pas trop l'intérêt.
Marsh Posté le 18-12-2010 à 00:54:32
plutôt intéressants les premiers boîtiers!, je me suis commandé une asrock PV530, que j'ai toujours dans son carton d'ailleurs, et je ne sais pas trop dans quoi la mettre.
la voici, avec son format bâtard micro ATX dans un sens, mini ITX dans l'autre
http://www.ldlc.com/fiche/PB00104497.html
carte commandée un peu sur un coup de tête, peut faire htpc/serveur.
j'ai un peu fait une connerie car ya pas de port IDE, adieu disque dur de 20Go et lecteur dvd.. par contre je peux y mettre carte réseau + carte son (ou autre). low profile possible.
autre particularité je me suis commandé une alim de ce type dans le but de rendre ce PC alimentable par une batterie.
http://cgi.ebay.fr/160W-8V-28V-Min [...] 0697259857
donc voilà, parmi les bôitiers, le e6 est très bien mais toute la place pour l'emplacement alim ATX est inutile.
le e5 a l'air excellent mais je ne pourrai y mettre que la carte réseau PCIe 1x.
une idée de boîtier "bâtard" pour aller avec cette carte bâtarde?
l'e5 semble tout de même être le boîtier idéal pour cette carte, en mettant cette perte du port PCI de côté
peut-être verra-t-on la même mais avec processeur Nano dual-core et chipset VIA VN1000.. (ce sera plutôt proche du Bobcat comme plate-forme).
Marsh Posté le 18-12-2010 à 11:16:31
Oups, double post !
Marsh Posté le 18-12-2010 à 11:21:47
| yf38 a écrit : Bonjour, |
C'était le principe du Shuttle au départ.
Je suis d'accord avec le raisonnement, que je pousserais même un peu plus loin :
Pour moi, on assiste à la fin du pc "desktop" en ce moment, l'avenir est au "cloud", les os seront accessible en vt depuis n'importe quelle machine (style chromeOS, windows 8 aussi je crois ?) et l'ordinateur de monsieur tout le monde deviendra le smartphone.
Donc personnellement, à horizon 10 ans je ne vois plus personne acheter une "tour", au mieux, les gens conserveront juste un serveur de données à domicile.
Même le jeux sera en nuage, avec des solutions de type onlive, la montée des débits de la fibre fera le reste.
Cela dit on s'égare du sujet.
En ce qui concerne les boitiers itx, j'en posterai la semaine prochaine, j'en ai des kilos en pdf.
Marsh Posté le 18-12-2010 à 11:24:34
crois pas ca ... madame michu est pas asses aware pour etre "cloudé"
le jour ou internet coupe elle est perdu
et les gamers continueront a vouloir des tours pour avoirs des chevaux au cul pour la video ... le PC survivra longtemps encore selon moi
Marsh Posté le 18-12-2010 à 12:47:38
| arkrom a écrit : crois pas ca ... madame michu est pas asses aware pour etre "cloudé" |
Madame Michu dans 10 ans elle sera au cimetière...
Marsh Posté le 18-12-2010 à 12:49:28
| madpo a écrit : |
Autant pour moi, ça m'avait échappé, en même temps, j'ai pas encore trop regardé du coté des alims.
Si tu as 2/3 liens, je suis preneur.
Marsh Posté le 18-12-2010 à 12:50:22
| nodarche a écrit : Madame Michu dans 10 ans elle sera au cimetière... |
crois pas ça, le cloud est un effet de mode si on peut dire ...
et de toute façon je ne crois pas que cela fasse plaisir au fabricant de materiel informatique que les gens achetes un client leger et un ecran ![]()
le lien de l alim http://www.fsp-group.com.tw/englis [...] &proid=754
elles existe de 250W à 600 W
Marsh Posté le 18-12-2010 à 12:55:32
| zeblods a écrit : |
Je suis d'accord, mais l'objectif de la boutique est de proposer des produits orientés PC de salon et itx, alors que le "cube" (lan gear ou silverstone) est plutôt un boitier de lan.
Cela étant, si tu pars sur de l'itx, j'aurais sans doute des choses pas trop mal à proposer, je posterai ça la semaine pro.
On pourra pas (déjà ?) tout faire non plus.
Marsh Posté le 18-12-2010 à 13:03:10
@ nodar MP moi j'ai bossé pour une boutique qui a tenté ce meme creneau ( et c'est LAMENTABLEMENT planté
faut que je te file deux trois conneries qu'ils avais fait eux pour t'eviter de faire la meme
Marsh Posté le 18-12-2010 à 13:09:37
| blazkowicz a écrit : plutôt intéressants les premiers boîtiers!, je me suis commandé une asrock PV530, que j'ai toujours dans son carton d'ailleurs, et je ne sais pas trop dans quoi la mettre. |
Le prix sera peu être un poil élevé au regard de ce que tu as mis pour le reste.
C'est pour mettre ou comme boitier, sur un bureau, sous la tv..?
Marsh Posté le 18-12-2010 à 13:25:53
| arkrom a écrit : @ nodar MP moi j'ai bossé pour une boutique qui a tenté ce meme creneau ( et c'est LAMENTABLEMENT planté |
je suis preneur.
Après, je pense faire un investissement limité au départ pour prendre la température, et j'ai l'avantage d'être sur un créneau "online", donc pas besoin de boutique.
D'où l'intérêt de communiquer sur les forums pour déceler quelques produits susceptibles de faire l'unanimité.
Comme je l'ai dit plus haut, j'ai déjà une boutique en prod (qui n'a rien à voir avec l'informatique), dont je n'arrive pas encore à vivre mais qui se développe tranquillement, alors je voudrais pas la plomber non plus.
Je pense avoir déjà dégoté un produit à "fort potentiel" de vente (a priori
), de la ddr3 (ou autre mémoire) qualité made in Taïwan (a ne pas confondre avec le made in china, mais je pense qu'ici tout le monde le savait déjà
) garantie à vie.
Tient, elle est d'ailleurs dispo sur cdisount : http://www.cdiscount.com/informati [...] 333co.html
Par exemple, je pense pouvoir faire ce modèle aux alentours de 80/85 euros out, qu'en pensez vous, 80€ pour 8 giga, ca parait honnête non ?
Marsh Posté le 18-12-2010 à 13:31:35
Moi je voie plutôt le "cube" comme l'avenir du PC : les cartes mères sont de plus en plus complètes, aujourd'hui dans la plupart des cas la seule chose qu'il reste à rajouter à une carte mère mini ITX c'est une bonne carte graphique.
Utiliser un boitier moyen tour ATX pour mettre une configuration qui se résume à une carte mère mini ITX + carte graphique, je trouve ça un peu idiot. D'autant plus qu'un boitier "cube" se glisse vraiment partout du fait de son très faible encombrement.
Un peu le créneau des Shuttle, mais avec une certaine flexibilité en plus.
A voir si tu as quelque chose de vraiment intéressent, mais pour le moment je pars sur une base de SG05B-450W + carte mère ASUS AM3 M4A88T-I Deluxe + Phenom II x6 1055T 95W + HD5750 Go! Green + 8Go de ram + SSD Intel Posteville 120Go.
Marsh Posté le 18-12-2010 à 15:11:51
On s'est mal compris,
pour moi le cube, c'est un boitier plus grand que le mini-itx (style lian-li), mais moins qu'une tour, comme le dabox.
Pour le reste, je suis d'accord, d'autant plus qu'avec le fusion, le processeur de monsieur et madame tout le monde sera carrément suffisant pour l'utilisation standard de pc.
Sur ce, je décroche un peu, c'est pas tout ça mais c'est bientôt noël, et j'ai pas de cadeaux !
Marsh Posté le 18-12-2010 à 16:39:41
niveau formfactor ce que j'adorerai trouver c'est une ITX +CG via un riser pour avoir un format proche d'un lecteur DVD de salon classique
unb peu a la mozart SX
mais a pris raisonnable quoi
Marsh Posté le 18-12-2010 à 21:48:22
| arkrom a écrit : niveau formfactor ce que j'adorerai trouver c'est une ITX +CG via un riser pour avoir un format proche d'un lecteur DVD de salon classique |
Ca va peut-être pouvoir ce faire alors...
Format mini-itx, avec riser optionnel.
Le problème de ces boitiers c'est le prix de leurs accessoires : écran oled + télécommande mce.
Mais si j'arrive à trouver le fabriquant de l'oled et que je propose une autre telco avec, ça devrait le faire. ![]()
Marsh Posté le 18-12-2010 à 21:53:02
le meme avec une alim pas trop pourrave et je t'epouse de suite
OSEF de l'ecran/telco si on a un clavier MCE a souris integré
Marsh Posté le 19-12-2010 à 10:54:36
Pour m'intéresser pas mal aux HTPC, voici ce qui est important pour la majorité des acheteurs :
- des dimensions compatibles hifi, y compris en profondeur : inférieur à 40 cm sinon ça ne rentre pas dans les meubles...
- un boitier bien ventilé ventilo mini 8 cm, de préférence sur les cotés
- une alim pas trop exotique ou livré avec du genre 250w en 80+ et silencieuse
- un lecteur optique bien intégré (slim en slot in ou classique avec cache tiroir)
- mini ITX ou micro ATX, ça dépend, les 2 plaisent
Pour les plus, on peut citer :
- des emplacements disques dur avec amortisseur et compatible 2,5"
- des ports usb en facade voir un lecteur sd...
- un port IR compatible MCE (les gens préfèrent acheter une logitech harmony qu'une nieme telco), pour l'écran, c'est pas indispensable...
Marsh Posté le 19-12-2010 à 12:52:28
| arkrom a écrit : |
Il est tout à fait envisageable de gérer l'ecran oled et la telco sous forme de déclinaison de produit cela dit.
Pour l'alim, c'est flex-atx ou sftx (???).
Je pense qu'il est préférable de partir sur des modèles déjà sur le marché.
Marsh Posté le 19-12-2010 à 13:09:29
| Ducleto1980 a écrit : Pour m'intéresser pas mal aux HTPC, voici ce qui est important pour la majorité des acheteurs : |
Merci pour cette contribution, en ce qui concerne les points soulevés, je suis d'accord, à part peut-être pour l'alim, car certains préfèrent selon moi payer moins cher le boitier et avoir le libre choix de l'alim.
Pour le contrôleur ir, le problème et qu'il est souvent fourni AVEC la télécommande, il existe par contre pas mal de modèles usb, mais l'intégration n'est pas la même non plus...
Les ports usb et sd card deviennent un standard de nos jours et en ce qui concerne les amortisseurs, il faut monter en gamme je pense, c'est comme pour les racks. ![]()
Marsh Posté le 17-12-2010 à 11:44:41
je me présente, je m'appelle Arnaud, je suis gérant d'une petite société spécialisée dans la vente en ligne (un seul site en production pour le moment).
J'ai pour projet d'ouvrir en 2011 une boutique en ligne spécialisée dans les HTPC, Mini-PC, NAS, et autre petit format d'ordinateur.
Et je me pose la question de la viabilité d'un tel projet, sachant que vivre de la vente en ligne, à petite échelle, c'est pas évident.
L'idée de cette boutique est née après avoir moi-même voulu monter une petite config de salon, j'ai fait un peu le tour des boutiques et j'en suis vite arrivé à la conclusion que l'offre française en la matière était vraiment pauvre, surtout en terme de boitiers, contrairement à ce qui peut ce faire en Asie.
D'autant plus que Bobcat et Llano "pousse au cul" !
Du coup, j'envisage de créer une marque OEM pour importer un certain nombre de boitiers et d'accessoires dédiés aux Mini-PC, Media Center, NAS et autres config de salon.
Je me permets donc de créer ce topic afin de prendre un peu la température, j'y posterai des photos de boitiers et autres matériels qu'il est possible d'importer vers la France, histoire de voir ce que vous en pensez.
J'attends vos réactions et attentes sur le sujet.
Cordialement.
EDIT :
05/03/2001 > Réouverture du sondage !
Message édité par nodarche le 07-03-2011 à 10:17:41
