[Topic Officiel] Leadtek nforce3 K8N ( pro) (probs et soluces)
Leadtek nforce3 K8N ( pro) (probs et soluces) [Topic Officiel] - Carte mère - Hardware
Marsh Posté le 23-02-2004 à 22:56:45
WinFast K8N/K8N PRO
overview & feature specification
  The Ultimate Socket 754 AMD Athlon 64 CPU Performance Platform
 Supports AMD Athlon 64 CPU
 HyperTransport link for nForce3 150 is 8b uplink, 16b downlink at 600MHz
 Supports Hardware Monitoring utility for observing system status.
 BIOS and hardware offers the CPU Over Temperature Shutdown (O.T.S) function to protect the CPU from burnout
 Supports CPU and Chipset Vcore, Vmem and AGP Vddq adjustments for better system compatibility
 Supports AGP 8X interface for high-end 3D Graphics cards
 Built-in ALC-658 6-channel surround sound via a SPDIF (coaxial) interface
 Six USB2.0 ports; four ports on the back panel, two ports for front panel pin header
 Supports three Firewire IEEE1394 interface
 Two Ultra ATA133 IDE dual channel interfaces, data transfer rate up to
 133MB/sec(The K8NW Pro offers an extra IDE for DATA Security)
 Built-in Silicon Image SiL3114 provides Four S-ATA with RAID 0/1 and 0+1 interface
 Dual LAN- one for 10/100Mbps and one for Gigabit LAN interface onboard
http://www.leadtek.com/motherboard/image/winfast_k8npro_1s.jpg
http://www.leadtek.com/motherboard/image/winfast_k8npro_2s.jpg
http://www.leadtek.com/motherboard/image/winfast_k8npro_3s.jpg
TEST : http://www.amdzone.com/articleview.cfm?articleid=1350
image du bios :
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/advanced_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/sysperf_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/cpumhz_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/agpmhz_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/memfreq_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/dramconfig_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/cpuvolt_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/agpvolt_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/memvolt_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/ldtbits_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/ldtspeed_small.JPG
http://www.amdzone.com/articleimages/motherboards/leadtek/k8n%20pro/pchealth_small.JPG
Pour tous les udpates bios etc ..... :
http://www.leadtek.com.tw/motherbo [...] 8n_1.shtml
tout ceci pour vous montrer ses bonnes propensions avec l'overclocking et ses réglages précis !!!
Message édité par anubis23 le 23-02-2004 à 23:14:03
Marsh Posté le 23-02-2004 à 23:18:48
up !!!
Marsh Posté le 24-02-2004 à 01:50:38
allons un petit up j'ai bossé là :)
Marsh Posté le 24-02-2004 à 02:01:44
elle est bien la leadteck combien de fsb max sans mod? :hello:
Marsh Posté le 24-02-2004 à 02:10:43
300 :)
Marsh Posté le 24-02-2004 à 02:17:27
je veux dire posible avec un amd64  :) tu as réussi a monter a 300fsb stable?
Marsh Posté le 24-02-2004 à 02:23:31
225 stable pour ma part, ce qui est supérieur à un 3400+ quand même ! pas encore assez étudié la chose pour l'instant, je vais faire d'autres tests.
j'ai vu sur un autre forum qu'un gar a réussi à monter à2800mhz avec cette carte, ce qui grandiose !!!
Marsh Posté le 24-02-2004 à 02:27:06
faudrais je créé le topic pour la asus k8v deluxe sauf j'ai le flemme [:ddr555]
Marsh Posté le 24-02-2004 à 02:48:01
je te comprend :)
Marsh Posté le 24-02-2004 à 02:50:45
parait qu'elle est bien je l'ai ei eu entre les mains mais j'ai préferré une nforce3 pour l'overclock moins puissante pour les app? mais pour les jeux c'est kif kif et ça s'averclock mieux, blocage agp/pci oblige !!!! msi ne fera jamais de mise à jour ! les constructeurs promettent mais c'est du marketting !
ou alors attendre le nforce 250 !!! mais c'est loin !!!! repoussé on le verra pas avant 3-4 mois alors nforce powa !!!
Marsh Posté le 24-02-2004 à 02:52:38
moi je l'ai acheter par manque de choix tous simplement [:ddr555]
Marsh Posté le 24-02-2004 à 02:53:44
pour le dual channel bof (le nforce a un chip qui gère très bien ça pour remplacer ce dual channel mais à 600 mhz mais un coup d'overclock et hop, on approche les 800 des kt 800)
de l'ordre de 1-2 % parait il car le process sera saturé, ça sert à rien c'est du marketting c'est tout... par contre le nforce 3 250 j'ai hâte !!!
Marsh Posté le 24-02-2004 à 02:55:56
j'ai tester a 600mhz aucune différence avec un bus de 800, ouai j'ai hate au nforce3 250 le s-ata va enfin arreter de passer par le pci  :)
Marsh Posté le 24-02-2004 à 02:55:57
elle est très bonne ta carte !!! aussi valable que la mienne, moins overclockable c'est tout, mais meilleurs en tests petit méchant !!!! asus très bonnes cartes !!! (toutes celles que j'ai eu roxaient un max) mais kt800 pas overclock avancé c'est tout.
hors ce prob tu as une super carte,une des meilleurs :)
Marsh Posté le 24-02-2004 à 02:58:07
j'ai hate au prochain chip via avec agp/pci lock  :) le nforce3 se ferais deffoncer si elle l'aurait présentement  :D
Message édité par The_Fury le 24-02-2004 à 02:58:14
Marsh Posté le 24-02-2004 à 02:59:50
c'est clair aucune différences (sauf pour des trucs comme winrar etc... quelques secondes de plus et alors ?) j'en suis à 667 et m'en fous, par contre je dépasse le 3400+ !!! j'espère régler mon prob de ddr4200 c'est tout...snifff ça m'attriste ça mais c'est peut être  un prob matos vais voir demain avec le magasin où je l'ai acheté ils sont sympas...
vais faire chez eux un memtest. si c'est bon retours sav.
leadteak est une très bonne carte et un autre test le confirme(faut que je retrouve le lien) (à chauqe fois achat recommandé et entre 8  et 9 sur 10).
Marsh Posté le 24-02-2004 à 03:03:42
euh moi je suis a 681mhz d hypertransport mais sur la sk8n,qui a le nforce3 pro150.
question:qu aura le nforce250 que n a pas le nforce150?quel socket?
Marsh Posté le 24-02-2004 à 03:05:59
via ou sys !!! c'est clair que sys est prometteur !!! ça explose tout dans les tests... vais attendre un peu pour changer ma carte mère... mais pour l'insatn,t nforce 3 powa!!!
et puis la prochaine révision en 250 pourrait changer la donne !
en tout cas je choisirais la meilleur ! m'en fous des figths gnagnagna ce chipset est gnagnagna ! seul le plus intéressant aura mon intéret.
pour l'instant c'est le nforce 3 pour ses grande possibilité d'overclock (blocage agp/pci toutes les tensions controlables etc... ce que ne font pas les autres...)
vivement la nouvelle génération ! on en est qu'aux balbutiement, ça va bientôt vite murir tout ça !!! mais sys est réellement prometteur !
Marsh Posté le 24-02-2004 à 03:06:18
socket 939 il aura un meilleur bus (1200 je pense) avec le s-ata/raid qui passe plus par le pci  le reste je sais pas :)
Marsh Posté le 24-02-2004 à 03:09:03
chiottes j ai meme pas un piti espoir que ca sorte aussi socket 940?pour mon piti opteron qui se degourdisse les jambes :(
Marsh Posté le 24-02-2004 à 03:09:06
elle tournera à 800 mhz et aura le dual (géré par un chip indépendant direct en communication avec le processeur et qui pourrait atteindre les 1000mhz mais question perfos faut pas s'attendre à une foudre de guerre...) en tout cas ce chip est la meilleure solution pour l'instant, limitée mais sera débridée dans nforce3 250 , enfin on verra... car les promesse constructeur on connait ça hein  :lol:
Marsh Posté le 24-02-2004 à 03:10:07
oui surment sur le socket 940 aussi
Marsh Posté le 24-02-2004 à 03:10:56
boaf le 754 a encore une longue vie devant lui, d'après les test les perfos sont quasi équivalentes... enfin on verra... en tout cas tous les constructeurs ont une longue roadmap pour les 754 donc...
Marsh Posté le 24-02-2004 à 03:11:57
je serai quand meme etonne que nvidia ne le sorte pas en socket 754 et 940.enfin je dis ca c est pour me rassurer :)
Marsh Posté le 24-02-2004 à 03:13:20
les nouveaux chipset 754 en profiterons (voir certaines prévisions) sauf le 1200 (mais tous s'accorde à dire que c'est inutil car le cpu sera saturé...il l'est déjà à 800... pour 754 c'est le 1000 qui arrive en chipset bien sur mais ce sont des gadgets je pense, je peux me tromper, ce n'est qu'un avis)
Marsh Posté le 24-02-2004 à 03:13:41
toute facon avec la grande différence entre un opteron socket 940 et amd64 socket 939 y vont surment le sortir aussi
Marsh Posté le 24-02-2004 à 03:14:11
parce qu au prix que ca m a coute,ca me ferait caguer qu on nous oublie,nous,les socket 754 et940!!!!ceci dit je ne regrette pas du tout mon achat,c est d une stabilite,comment dire,intelienne......j ai bon espoir sur le socket
Marsh Posté le 24-02-2004 à 03:14:25
marketing intel va avoir un bus de 1200 faus que amd replique meme si sa apporte rien
Marsh Posté le 24-02-2004 à 03:14:49
sont pas fous !!! nvidia ou d'autres constructeurs sortiront des chips adaptés aux deux sockets pas d'inquiétudes à avoir :)
et même sans ecc (ça s'est sur !)
Marsh Posté le 24-02-2004 à 03:15:28
les opteron ne seront pas oublié regarde les roadmap les opteron 3ghz son prévu pour début 2005  :)
Marsh Posté le 24-02-2004 à 03:16:33
marketting oui pour le bus. mais non faut se rassurer il y a des roadmap longues de deux ans sur les 754 et 940 rassures toi the boss :)
Message édité par anubis23 le 24-02-2004 à 03:17:23
Marsh Posté le 24-02-2004 à 03:16:46
deja que je lorgne sur un opteron 148 du cote des states(un pote a moi y va) couple a du nforce3 pro250,et ma tres bonne samsung qui ne rechigne pas a monter en frequence au volt d oriigine soit 2.5v,associe a du vrai 64b dans 3 matins,je salive par avance
Marsh Posté le 24-02-2004 à 03:17:48
bientôt bientôt :)
Marsh Posté le 24-02-2004 à 03:18:27
bien bien ca,les enfants grace a vos connaissances je vais passer une bonne nuit ;)
ou pourrais je trouver une roadmap officielle amd pour les annees a venir?
Marsh Posté le 24-02-2004 à 03:19:03
je te cherche ca
Marsh Posté le 24-02-2004 à 03:20:08
moi aussi merci fury :)
Marsh Posté le 24-02-2004 à 03:21:57
rhâ je suis passer dessus mais là pas trop envie de chercher, je crois qu'il y a un super topic sur hardware sur les différentes cartes mères pour tout ce bon matos... cherches dans les liens tu auras ta réponses ! enfin j'espère...
mais rassures toi !!!! à l'époque les socket a amd même après des années n'ont pas été oubliés :) dors bien de bonnes choses arrivent :)
Marsh Posté le 24-02-2004 à 03:22:01
http://www.x86-secret.com/pics/rdmpq4.gif
Marsh Posté le 24-02-2004 à 03:22:53
Marsh Posté le 24-02-2004 à 03:24:44
fabuleux je vais pouvoir a changer juste le proc.rhaaaaaa l opteron 152!!!!!!!!!!!!!!!!merci pour la source the fury tu es un as ;)
