Topic Unik <<< Asus P4PE >>> i845PE -> photo blackpearl page 1
Topic Unik <<< Asus P4PE >>> i845PE -> photo blackpearl page 1 - Carte mère - Hardware
Marsh Posté le 05-03-2003 à 23:57:16
Reprise du premier post (génération automatique) :
bon ben je viens de l'avoir
c la p4b533 mais av serial ata, réso 10/100/1000, ddr333....
Specification
CPU:  Socket 478 for Intel® Pentium® 4 /Celeron up to 3.08GHz+
On-die 512/256KB L2 Cache with full speed
Intel Hyer-threading Technology ready
New power design supports up to 3.06GHz+ CPU speeds andabove
Chipset :  Intel 82845PE MCH
Intel 82801 DA ICH4
Front Side Bus 533/400 MHz
Memory 3 x 184-pin DIMM Sockets support
max. 2GB PC2700 / PC2100 (FSB533) or PC2100 / PC1600 (FSB400) ECC / non-ECC DDR SDRAM memory
Expansion Slots 1 x AGP 4X (1.5V only)
6 XPCI (one with ASUS BlueMagic PCI Slot
IDE 2 x UltraDMA 100 / 66 / 33
Flexible Serial ATA (optional)  Promise controller supports one ATA133 port and two serial ATA ports
RAID (optional) RAID 0 support by two to three parallel ATA connectors RAID 1 support by two Parallel or Serial ATA connectors
Audio (optional)  AD1980 6 Channel CODEC
LAN (optional)  BroadCom 10/100 Mbps or 1000 Mbps Ethernet controller
IEEE1394 (optional)  VIA 1394 controller
2 x 1394 port
Special Features CrashFree BIOS
Support S/PDIF in / out interface (on audio model only)
Power Loss Restart
ASUS® JumperFree
AGP warning LED
ASUS POST Reporter
ASUS EZ Plug?
ASUS EZ Flash
ASUS Q-Fan
ASUS MyLogo2
Multi-language BIOS
Overclocking Features Adjustable FSB/DDR ratio fixed AGP/PCI frequencies
CPU Vcore, memory voltage and AGP voltage adjustable 1.5V -> 1.85V
Voltages Ram 2.5V -> 2.9V
ASUS Jumperfree
C.P.R. (CPU Parameter Recall)
SFS (Stepless Frequenct Selection)
Back Panel I/O Ports 1 x Parallel
2 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
4 x USB 2.0 / 1.1
Internal I/O Connectors 1 x USB 2.0 / 1.1 connector support additional 2 USB 2.0 / 1.1 ports
CPU / Power / Chassis FAN connectors
20 pin ATX Power connector
4 pin ATX 12V Power connector
IDE LED connector, power LED connector
Chassis Intrusion, SM Bus, SIR
GAME/MIDI connector
S/PDIF out connector
ASUS® iPanel connector
CD / AUX / Modem audio in
Front Audio Panel connector
BIOS Features 4Mb Flash ROM, Award® BIOS, TCAV, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, Multi-language BIOS, ASUS® EZ Flash, MyLogo2
Industrial Standard PCI 2.2 USB 2.0
Manageability WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, Chassis Intrusion, SM Bus
Support CD Drivers
ASUS® PC Probe?
ASUS® LiveUpdate? Utility
Cyberlink® PowerPlayer SE?, VideoLive Mail?
Trend® Micro PC-cillin 2002 anti-virus software with Windows® XP support
Accessories User's manual
IDE Cable
FDD cable
2-connector UltraDMA cable (on serial ATA model only)
3-connector UltraDMA cable
2 port IEE1394 module and 2 x IEEE 1394 cable (on 1394 model only)
InterVideo WinCinema (GoldVersion Only)
2 X Serial ATA Cable (on serial ATA model only)
S/PDIF in / out module
I/O shield
Message édité par akhnotpierrot le 07-03-2003 à 12:28:28
Marsh Posté le 06-03-2003 à 00:32:00
en 1.5 ??? mais t'a foutu 2.9V pour tourné a 133MHz ou koi ??? !!!!
Non pas du tout, voltage par défaut. Mais je crois qu'elle est vraiment pas mal du tout cette ram...  :love:
Maintenant je suis remonté en 2-2-2-5 parce qu'en fsb=150 ça passait plus...  ;)
Marsh Posté le 06-03-2003 à 00:52:47
qqun a il teste le bios 1003.09?et si oui quelles sont les differences avec l ancien niveau perfs?car moi je plafonne a 152fsb et memoire @ 405 en 2225 512 mo winbond de puces et de conception ddr3200.sur cette mobo je vais pas au dela de 2735 mhz alors que sur mon ancienne msi i845e avec le meme proc je montais a 2880mhz stables!!!!!j ai le 1002 officiel,j hesite a passer au bios beta.merci les gars :hello:
Marsh Posté le 06-03-2003 à 08:19:57
Allez Hop juste pour la forme , encore un nouveau bios le 1003.010 , ben oui ou ils attendent 3 mois pour en sortir 1 ou bien c'est 2 dans la même semaine ! Sont trop fort chez Asus... ;)
Et comme d'hab on ne sait pas non plus ce qu'il apporte de plus , mais bon , je viens de flashé là a l'instant et bon...rien de bien nouveau , mais je me dis que pour qu'il en sorte un aussi rapidement dérriere le 1003.009 c'est qu'ils ont dû s'appecevoir d'un chti soucis peut-être sur le 009... ou alors ils se reveillent enfin et se disent qu'il serait temps de s'y mettre quand même pour arriver a un 1003 final.
Marsh Posté le 06-03-2003 à 12:13:49
Bon alors ce AGP/PCI fix,il est résolu avec ce new bios??? y'a que ça qui compte pour moi avant de me lancer dans l'overclocking de mon proc!!! :D
Marsh Posté le 06-03-2003 à 12:15:06
kkun peut m'uploader le bios en http svp ? (peut pas dl a partir de ftp)
Marsh Posté le 06-03-2003 à 12:42:26
 [:yoyoz]
Marsh Posté le 06-03-2003 à 12:59:36
de retour sur mon piti topic, apres mes pb avec la p4g8x, je reviens a la p4pe, ma nouvelle :
P4PE black pearl  :love:  av PCB noir, revision 1.3 de la carte, trop belle.
je v la montée ce WE, je metrai le dernier bios, je connai deja ste carte par coeur et je vous dirai si agp fix ou pas et si l'oc est bon.
a bientot ;)
[HFR] AKHnoT [:akhnotpierrot] Membre de la team [HFR] BattleTeam
Marsh Posté le 06-03-2003 à 13:16:49
moi aussi je suis repassé à la p4pe :-D déçu de la p4g8x puis vallait mieu la revendre maintenant que quand le springdale et canterwood sortiront lol
T'as un plus en OC avec la bp ?
Marsh Posté le 06-03-2003 à 13:44:10
tu aura lu "je v la monté ce WE" ;)
Marsh Posté le 06-03-2003 à 13:53:52
J'attend ca avec impatience. La BP me plait vraiment  :whistle: ...
Marsh Posté le 06-03-2003 à 14:36:20
Marsh Posté le 06-03-2003 à 18:05:41
en tou cas le truc usb de 32meg c excellent :D
Marsh Posté le 06-03-2003 à 18:21:50
tu peux booter ou flasher avec ?
Marsh Posté le 06-03-2003 à 18:53:54
t'as une position fdd donc j'imagine que oui :D
Marsh Posté le 06-03-2003 à 19:01:18
Bonsoir,
parmi vous, est-ce que qq a essayé de booter avec une clef USB ?. Si oui quel est le parametrage à faire dans le bios ?.
Merci.
Message édité par vrobaina le 06-03-2003 à 19:01:29
Marsh Posté le 06-03-2003 à 19:52:18
ça m'interesses aussi ;-)
Bien que mon lecteur de disquette soit totalement silencieux une clé usb me ravirait :-)
Marsh Posté le 06-03-2003 à 20:55:24
http://forum.hardware.fr/icones/flag1.gif
=====>http://www.hardcoregamers.fr.st<=====
Marsh Posté le 06-03-2003 à 22:32:50
P4PE Black Pearl  :love:  :love:  :love:  :love:
Mon feed
Marsh Posté le 06-03-2003 à 22:46:30
j'ai chargé le bios 1003.010  ,  il tourne bien ;)
Message édité par Mandrak le 06-03-2003 à 22:55:32
autre passion >>  http://zupimages.net/viewer.php?id=19/35/p8a9.jpg
Marsh Posté le 06-03-2003 à 23:07:01
je vais essayer de booter avec une clé usb mais ca metonerait que ca marche
edit : ca marche pas car il n'est pas reconue ni meme détécté par le bios ds les disques amovible.
Message édité par PlayTime le 06-03-2003 à 23:14:28
Marsh Posté le 06-03-2003 à 23:45:38
moi ma clé avec la black pearl je peu la mettre soit en mode HDD (disk dur) soit en mode FDD (disket), je suis a peu pres sur qu'en FDD ca boot dessus
Marsh Posté le 06-03-2003 à 23:54:49
dire qu'avec une clé USB on pourrait mettre 3.1  :whistle:
Marsh Posté le 07-03-2003 à 00:15:08
quelques photos de la P4PE black pearl :
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0156.JPG
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0158.JPG
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0171.JPG
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0178.jpg
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0177.jpghttp://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0180.JPG
http://akhnotpierrot.free.fr/Photos/Matos/P4PE%20BP/DSCN0179.jpg
les tests demain ds la nuit :D
Marsh Posté le 07-03-2003 à 01:00:27
viiiiiiiiiiiiiiiite vendredi soir que je la test ste BP....rev 1.03 :D, j'avai qu'une 1.01 ava :D
Marsh Posté le 07-03-2003 à 01:26:20
alors le fix agp pci roule ou pas car pas envie de flasher pour le moment mais jen ai marre de ce prob  :fou:
Marsh Posté le 07-03-2003 à 01:36:30
bah non ça marche pas.
j'ai l'impression que le seul truc qui change dans ces bios c'est le numero.
Marsh Posté le 07-03-2003 à 01:43:04
mais c normal c la spécialité ati en se moment, ils anoncent des possibilité d'oc énorme et total a plus de 150 de fsb, bah j'entend que des scrouitch au cask et ma carte pci adsl ne se connect pas.....bref ca oc trop les port ....
sur p4pe et p4g8x....la p4g8x etant le pire avec les pb de 9700 pro
Marsh Posté le 07-03-2003 à 01:59:32
aknotpierrot, on te dit de mettre le ratio a 34/67 et la c'est bloque sans soucis...
Marsh Posté le 07-03-2003 à 07:40:54
c quoi l'adresse deja chez Intel pour voir le correspondance entre le N° de serie et la revision du core ?
Marsh Posté le 07-03-2003 à 08:09:08
cpu-z te donne la revision du core sans rien demonter.....
Marsh Posté le 07-03-2003 à 11:29:00
ici : http://processorfinder.intel.com/scripts/default.asp
A plus
Marsh Posté le 07-03-2003 à 12:28:06
hum....
et tu pense pas que j'ai deja pu essayé non ;)
chez moi rien ne marche, meme la manip avec els 5 redemarage la, ca block rien .
Marsh Posté le 07-03-2003 à 13:03:43
hum....
+1 :kaola:  , çà fixe mes genoux chez oim
Marsh Posté le 07-03-2003 à 13:05:45
J'ai une PE de la semaine passée, et elle est aussi une rev 1.03
C'est censé apporter quoi de neuf?
Marsh Posté le 07-03-2003 à 13:08:40
aucune id, pas grand chose a mon avis, et ca regle pas le pb pci/agp fix
Marsh Posté le 07-03-2003 à 13:17:26
akhnotpierrot > tu as eu une P4B533-V il me semble. Je ne vois pas ce que la P4PE apporte de plus niveau perfs. Ton avis ?
"Pour aimer la gloire, il faut faire grand cas des hommes, il faut croire en eux."
Marsh Posté le 07-03-2003 à 13:19:30
pareil, novi perf, quedalle, mais je change tou le temps, depuis la p4b533-v j'ai eu la p4pe rev 1.01, une p4g8x rev 1.02 et la je reviens sur P4PE avec une BalckPearl rev 1.03 en attendant l'asus avec le canterwood (c plus le nom)
Marsh Posté le 07-03-2003 à 13:59:29
Cool, merci beaucoup, je vient d'avoir un C1.
Par contre, je vais aussi vous quitter comme OW31, puisque je vais passer sur un P4G8X Deluxe.
Mai_s je resterai qd meme avec vous, la p4pe va a ma copine, pour viré son XP 1700+ et sa MSI KT3 Ultra ARU.
Marsh Posté le 07-03-2003 à 15:22:25
 :ouch:  :ouch:  ouaa t'en as eut des cartes tonton pierrot :lol:
