que pensez vous de mes reglages de xp2400+
que pensez vous de mes reglages de xp2400+ - Carte mère - Hardware
Marsh Posté le 18-01-2006 à 23:25:42
Bonsoir à tous,
que pensez vous des reglages de mon pc et que faudrait il faire pour ameliorer les perf ????
Merci d avance
ST
CPU-Z Report
CPU-Z version 1.31.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Thoroughbred
Specification AMD Athlon(TM) XP 2400+
Family / Model / Stepping 6 8 1
Extended Family / Model 7 8
Package Socket A
Core Stepping B0
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 2000.0 MHz
Clock multiplier x 15.0
Front Side Bus Frequency 133.3 MHz
Bus Speed 266.7 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2000.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A7V8X, REV 1.xx
BIOS vendor Award Software, Inc.
BIOS revision ASUS A7V8X ACPI BIOS Revision 1006
BIOS release date 09/13/2002
Chipset VIA KT400 (VT8377) rev. 00
Southbridge VIA VT8235 rev. 00
Graphic Interface AGP
AGP Status enabled, rev. 2.0
AGP Data Transfer Rate 4x
AGP Max Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 166.7 MHz
FSB:DRAM FSB + 33 MHz
DRAM Interleave 4-way
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 7 clocks
# of memory modules 2
Module 0 DDR-SDRAM PC2700 - 512 MBytes
Module 1 DDR-SDRAM PC2700 - 512 MBytes
