MSI 6382 Ca vaut le coup ou pas? please help me - Carte mère - Hardware
MarshPosté le 06-09-2002 à 13:39:28
voila on me propose un carte mere MSI6382 micro atx pour 350frs MSI 6382 (KT266), 1.5Ghz+, UDMA 33/66/100
socket A micro ATX mobo from MSI using the KT266/VT8366 and VT8233 chipset. It is capable of running cpu's up to 1.5Ghz. Uses DDR memory 200/266FSB for fast prosessing, 2 slots up to 2GB. (The memory speed can be set independently of FSB so allowing 100FSB with 266 DDR memory). UDMA 33/66/100. FSB 100/133. 1 AGP (2.0 1x/2x/4x), 3 PCI, on board creative sound pci 128(with line in, line out, mic and games socket), 1FDD, 2 serial, 1 parallel, 2 USB ports (with 4 aditional via cables from the mobo, cables not supplied). Size 24.3cm x 23.3cm. Please note that this board is an OEM version from MSI and comes without a CNR socket or hardware monitoring QQ sait quel CPU je peux mettre dessus Athlon XP peut etre??
Marsh Posté le 06-09-2002 à 13:39:28
