Mélange barrettes - Carte mère - Hardware
Marsh Posté le 30-01-2010 à 08:25:29
J'ai recu ce mail ce matin. Donc si je comprends bien il faut que j'envoie mes 2 barrettes par La Poste. Super je fait comment pour utiliser mon PC moi maintenant ?
Please do not reply directly to this e-mail as this address is not monitored.
Corsair Technical Support has sent you a message regarding Case #1111111
Dear Valued Corsair Customer,
Thank you for your patience. For your return, please reference RMA #1111111.
For your convenience, click the following link to automatically generate an address label for your return.
Please also mark the RMA number clearly on your package, and ship your RMA to the following address:
Attn: RMA Department
Corsair Memory BV
Tunerstraat 3, 1322CB
Almere, The Netherlands
Phone 510-657-8747
PACKAGING INSTRUCTIONS:
* DO NOT return any Corsair product in a standard mailing envelope! Please only use a padded envelope or proper fitting box.
* We strongly recommend using a carrier that will provide you with a tracking # and option for added insurance for your package. Any package that arrives empty will be returned to the sender. In addition, Corsair is not liable for any lost/stolen packages. Corsair will only replace the product which we physically receive.
* Please make sure your complete address is included within the package: first/last name, telephone # and complete return address. Be aware, some shipping stores do not include your contact details on the address label.
* Please include a copy of this RMA Confirmation with your shipment
CORSAIR REPLACEMENT SHIPMENT
* Once your package is received, Corsair will process your replacement order in 3-5 days.
All replacements will be shipped UPS Standard. Please allow 2-4 business days transit time for delivery.
We will inform you of any product delays or problems making a shipment within this time frame.
* All replacement orders are shipped at Corsair's expense via UPS services
To check the status of your RMA, please click on the link below:
De plus les frais de port vont etre à me charge ?
Merci de vos réponse.
Marsh Posté le 30-01-2010 à 09:36:48
Il faut que tu envoie les deux car il faut que les deux barrettes soient identiques pour fonctionner en dual channel donc ils vont te changer les deux et oui malheureusement le port sera à ta charge mais c'est moins cher que des barrettes neuves.
Marsh Posté le 28-01-2010 à 21:00:50
Je possède 2 barrettes de RAM DDR2 de 1Go chacune ( PC6400 donc 800 Mhz, Cas 4,4,4,12) Corsair. (http://www.provantage.com/corsair- [...] SMC031.htm)
Hier l'une d'entre elle ma lâchée. Ecran bleu a chaque démarrage de Windows.
Je serais intéressé par la même barrette mais en Cas 5,5,5,15. http://www.ldlc.com/fiche/PB00030831.html
Qu'elle sera la conséquence du faite que je mélange ces 2 types de barrettes ??
Merci.
