Deux ecrans avec GMA950 + Radeon X300 ? - Carte mère - Hardware
Marsh Posté le 10-08-2006 à 15:48:55
je crois que ce que tu cherches à faire est tout simplement impossible ...
Marsh Posté le 10-08-2006 à 15:57:40
Slt, je me susi souvenu de ça en lisant ton post, il s'agit d'un tuto tiré du forum Anandtech sur la MSI K8NGM2-FID (chipset 6150) qui comme le tien ne dispose que d'un DVI-D. Si j'ai bien compris il faut dand le bios indiquer que tu veux utiliser les 2 systèmes video (chipset et PCI). Je ne sais pas si cela t'aidera, mais on ne sait jamais ;-)
JB
. GeForce 6150 II. Multiple Monitors & TV Support
Supported Configurations by Onboard Video
The following combinations are supported in DualView mode:
digital monitor (onboard DVI) + analog monitor (onboard VGA)
digital monitor (onboard DVI) + TV (onboard TV out)
Unsupported Configurations by Onboard Video
As GeForce 6150 has only one RAMDAC (Random Access Memory Digital/Analog Converter) and hence two analog outs are impossible, the following combinations are not supported:
analog monitor (onboard DVI) + analog monitor (onboard VGA). (First of all connecting an analog monitor to onboard DVI is physically impossible because the onboard DVI connector is DVI-D that lacks 4-pin holes and hence a DVI to VGA adapter cannot be used.)
analog monitor (onboard VGA) + TV (onboard TV out). (Note that signals from onboard TV out are analog.)
Supported Configurations by Onboard Video + Dual-Head PCI-Express Video Card
The following combinations are supported in QuadrupleView mode:
monitor (video card) + monitor (video card)+ digital monitor (onboard DVI) + analog monitor (onboard VGA)
monitor (video card) + monitor (video card)+ digital monitor (onboard DVI) + TV (onboard TV out)
Remarks
In the above configurations, the video card is restricted to the nVIDIA brand. If you disable onboard video in BIOS, you can use an ATI video card.
Monitors can be used either landscape mode (default) or portrait mode. To change mode, right click NVIDIA Settings in the system tray, then choose "GPU name (Display #)" > Rotation Settings > Rotate 0, 90, 180, 270 degree.
The description of TV Setup in pages B6 to B8 of Quick User's Guide is wrong (referring to ATI software!). Please download the latest manual from MSI Global site.
Marsh Posté le 10-08-2006 à 16:04:21
merci pour ta reponse mais dans mon bios je ne trouve nul part une option qui me premettrai de preciser que je veux utiliser les deux en meme temps le pci express + la sortie video integree a la carte mere.
Marsh Posté le 10-08-2006 à 15:42:18
Bonjour a tous,
j'ai recement fait l'acquisition d'une carte mere gigabyte GA-8i945G-MF avec un chipset video integrer intel GMA 950.
sur cette carte mere, il y a un port pci express, sur lequel j'ai connecte une carte graphique ati radeon x300. jusqu'ici tout va bien. le probleme c'est que une fois ma radeon branchee mon autre sortie video (gma 950) est desactivee.
mon objectif est bien sur de brancher deux ecrans type crt (vga donc, pas dvi), un sur la sortie video GMA950 et l'autre sur la carte graphique radeon x300 pour pouvoir faire du dual screen sous windows xp. Si quelqu'un a la solution...
sur la carte graphique radeon x300 il y a une sortie vga et une dvi, sauf que c'est du dvi numerique et non du dvi analogique donc pas de possiblite de brancher un ecran ecran crt via un adaptateur (j'ai chercher, j'en ai meme acheter un pour tester et en effet cela ne peux pas fonctionner).
Donc j'en reviens a ma premiere idee brancher un ecran sur la sortie gma950 et l'autre ecran sur la carte graphique x300 (les deux en vga), j'ai bien sur regarder dans les options du bios de la carte mere, je ne trouve nul part une option traitant de l'affichage, mais je ne cheche peut-etre pas au bon endroit ?
Derniere precision, dans les propriete materiel sous windows xp, en depliant la rubrique carte graphique, j'ai uniquement les deux sorties de la x300, le gma950 n'apparait pas, il est desactive. je cherche donc a forcer sont activation meme si une carte graphique est branchee sur le port pci express.
enfin: quelqu'un a t il le numero de telephone de gigabyte france le site www.gigabyte.fr est en rade et le numero n'est pas dans la doc de la carte mere.
merci d'avance a tous.
