Abit WN-2S+ (nForce4 bi-CPU Opteron + SLI)
Abit WN-2S+ (nForce4 bi-CPU Opteron + SLI) - Carte mère - Hardware
Marsh Posté le 22-01-2005 à 16:59:10
Une nouvelle carte Mere chez Abit : WN-2S+
CPU
l Supports 1600 MHz Hyper-Transport AMD Dual Opteron processors (1XX, 2XX series)
Chipset
nVidia CrushK8-04 Pro Chipset
Memoire
4 * 184-pin DIMM sockets ECC Registered memory.
Supports Dual channel DDR 400/333 (Max. 8GB)
Graphics port
PCI Express x16 graphics interface with SLI
SATA
Supports 4 ports SATA II (from CK8-04 SLI)
Audio
5.1 Channel AC97 Audio (Realtek ALC658)
Support 24-bit S/P DIF In/Out
Jack Sensing support (Mic In / Line In / Line Out)
USB2.0
8-port USB 2.0 Supports 480 Mb/s data transfer rate
IEEE 1394
Supports 3 Ports IEEE 1394a at 100/200/400 Mb/s transfer rate
LAN
1 x Intel 82540EM Gigabit Ethernet controller
1 x Cicada CIS8201 PHY with RGMII
Support ACPI & Wake on LAN
ABIT Engineered
ABIT SoftMenuTM Technology
Internal I/O Connectors
2 x PCI Express x16 slot
1 x PCI Express x4 slot (bandwidth support PCI-E x2)
1 x PCI Express x1 slot
1 x PCI slot
1 x SLI switch key connector
1 x Floppy port supports up to 2.88MB
4 x SATA connector
2 x Ultra ATA 133/100/66/33 connector
2 x Dual USB 2.0 headers (1 for front connection)
2 x IEEE 1394a headers
1 x FPIO header
1 x FP-Audio header
1 x NIC LED header
1 x SATA FPIO header
1 x CD-IN
1 x Com port header
Panneau arriere I/O
1 x PS/2 Keyboard + 1 x PS/2 Mouse
1 x Parallel Port connector
1 x S/PDIF IN, 1 x S/PDIF OUT
1 x Audio connector (Surround right/left, rear right/left, center/subwoofer)
1 x Audio connector (Line Out, Line-in, MIC-in)
1 x IEEE1394a port
2 x USB connectors + 1 x RJ-45 LAN Connector
Divers
ATX form factor 12 “ x 10.5”(305 x 265 mm)
Quelques photos :
http://www.pcperspective.com/images/news/wn2s_top.jpg
http://www.pcperspective.com/images/news/wn2s_side.jpg
http://www.pcperspective.com/images/news/wn2s_connectors.jpg
Ce serait parfait si c'était un Athlon FX 64 sur un 939 au lieu de l'Opteron ;-(
Message édité par lonely le 22-01-2005 à 17:11:49
Marsh Posté le 22-01-2005 à 17:22:25
"Ce serait parfait si c'était un Athlon FX 64 sur un 939 au lieu de l'Opteron ;-("
Tout a fait daccord avec toi, j attendais avec impatiente une NForce 4 de chez ABIT, et voila ce qui nous pondent, une carte mere qu on pourra jamais achetez nous particulier, c est une carte mere pour riche et je pese mes mots, rien qu avec le prix de 2xOpteron on a une configue de luxe avec du gros matos. :o
Voila un petit coup de gueule, mais ce n est que mon avis. :D
Marsh Posté le 22-01-2005 à 17:52:29
miam miam
ça arrive qd cette bete :??:  :love:
mon topic de vente
Marsh Posté le 24-01-2005 à 04:03:32
carte mere Tyan bi-opteron SLI
http://2cpu.co.kr/zboard/zboard.php?id=2DEX&no=111
