pc2-5300 => quel core2duo ? (pas d'oc)
pc2-5300 => quel core2duo ? (pas d'oc) - Carte mère - Hardware
Marsh Posté le 26-09-2007 à 15:22:50
Voici ma config actuelle (je sais y'en a une tartine, mais bon je crois qu'ainsi tout y est) :
Processor(s)
Number of processors 1
Number of cores 1 per processor
Number of threads 2 (max 2) per processor
Name Intel Pentium 4 650
Code Name Prescott
Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
Package Socket 775 LGA
Family/Model/Stepping F.4.A
Extended Family/Model F.4
Core Stepping R0
Technology 90 nm
Core Speed 3415.4 MHz
Multiplier x Bus speed 17.0 x 200.9 MHz
Rated Bus speed 803.6 MHz
Stock frequency 3400 MHz
Instruction sets MMX, SSE, SSE2, SSE3, EM64T
L1 Data cache (per processor) 16 KBytes, 8-way set associative, 64-byte line size
Trace cache (per processor) 12 Kuops, 8-way set associative
L2 cache (per processor) 2048 KBytes, 8-way set associative, 64-byte line size
Chipset & Memory
Northbridge VIA PT880 Pro rev. 00
Southbridge VIA VT8237A rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x4
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 267.9 MHz (3:4)
DRAM Interleave 4-way
CAS# Latency (tCL) 4.0 clocks
RAS# to CAS# (tRCD) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 12 clocks
Command Rate (CR) 2T
System
System Manufacturer To Be Filled By O.E.M.
System Name To Be Filled By O.E.M.
System S/N To Be Filled By O.E.M.
Mainboard Vendor
Mainboard Model 4CoreDual-VSTA
BIOS Vendor American Megatrends Inc.
BIOS Version P1.10
BIOS Date 11/06/2006
Memory SPD
Module 1 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
Module 2 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
Carte graphique: 7950gt 512 ddr3.
Mon utilisation est principalement tournée vers du jeu.
Ma question est la suivante:
Souhaitant garder mes deux barettes de mémoire, vers quel core 2 duo dois je me tourner pour remplacer mon pentium4 ? que pensez vous de ma carte mère (Asrock 4dualcore-vsta) pour exploiter un c2d ?
Espérant avoir été clair, j'attends vos réponses impatiemment. Merci d'avance.
Marsh Posté le 26-09-2007 à 15:28:17
Sur ta carte mère tu peux mettre :Un E21*0, un E4*00, un E6*00 ou un E6*20.. mais pas de E6*50..
Marsh Posté le 26-09-2007 à 17:23:37
Merci de ta réponse.
Bon, admettons que je m'oriente vers un E6*20, qu'en est il de la compatibilité avec mes barettes de pc2-5300 ?
Sinon, serait il intéressant de changer de mobo ? (auquel cas je pourrais peut etre choisir un autre proco ?!?)
Marsh Posté le 26-09-2007 à 17:26:56
Ce sujet ne semble pas passionner grand monde...
svp, laissez moi un maximum d'infos, suis plutot novice en la matière.
Merci.
Marsh Posté le 26-09-2007 à 17:43:18
Non, pas interessant de changer de mobo..
Les E6*20 ont un FSB de 266 (ex: E6420 = 266*8 = 2.13Ghz)
Donc il te faut au minimum de la PC4200.. La PC5300 tournera au dessus du FSB ce qui te fera gagner un peu de perfs (mais rien de significatif..)
Ta ram serait également potentiellement compatible avec les E6*50 (ex: E6750 = 8*333 = 2.66Ghz) donc PC 5300 mini.. le souci est que ta carte mère n'est pas compatible..
Marsh Posté le 26-09-2007 à 18:13:56
ok, que penses tu du gain en perf par rapport à ma config actuelle (remplacement P4 pour E6420 ?) le but étant de pouvoir faire tourner correctement les jeux à venir (bioshock, crysis...)
Marsh Posté le 26-09-2007 à 21:17:35
a mon sens si tu sens que ca va pas niveau puissance CPU.. Et que tu sens deja les limites actuellement change.. sinon attends de voir..
