probleme avec ma ati 9600xt - Matériels & problèmes divers - Hardware
Marsh Posté le 16-09-2005 à 17:41:53
Assures-toi que la définition et la fréquence de rafraîchissement correspondent bien aux caractéristiques de ton moniteur vidéo.
Desinstallation Pilotes et Logiciels ATI:
Il est indispensable de désinstaller totalement les pilotes et logiciels ati précédents:
Suivre scrupuleusement la procédure indiquée par ATI:
Uninstalling the ATI Control Panel and Display Driver
This section provides information on uninstalling the previous versions of your ATI Control Panel and ATI Display Driver for your Radeon® product.
   Note:  If you are using Windows 2000 or Windows XP, ensure that you have logged in with system administrative rights.
Before you can install the latest Catalyst software driver for your Radeon® product, you must uninstall the previous ATI Control Panel. To do this, follow these steps:
   1. Navigate to the Add/Remove programs tool provided by Microsoft. This tool is found in the Control Panel.
         Note:  Ensure all other applications are closed before continuing with the uninstall of the ATI Display Driver.
   2. Click the Change/Remove button. The ATI Control Panel Setup window is displayed.
   3. Select Remove, and click Next. A Confirm File Deletion dialog box is displayed.
   4. Click OK. The ATI Control Panel Setup window is displayed.
   5. Select No, and click Finish. You are returned to the Add/Remove Program tool.
You have successfully uninstalled the ATI Control Panel.
You are now ready to uninstall the ATI Display Driver. To do this, follow these steps:
   1. Select ATI Display Driver in the Add/Remove Program tool.
         Note:  If you have multiple display adapters installed, a dialog box will appear instructing you to choose which ATI Display driver to uninstall. Click the Select All button.
   3. Click Yes when prompted to confirm the uninstall of the ATI Display Driver.
   4. Reboot your system as prompted to compete the uninstall of the ATI Display Driver.
Note importante:
il ne faut pas laisser windows ré-installer les pilotes radeon !
Marsh Posté le 16-09-2005 à 17:51:25
j ai deja fait tout ca mais je vais le refaire.
mais par contre pour ce qui est de la definition et du taux de rafraichissement caractheristiques de mon moniteur je ne les connais pas et je ne sais pas commant les régler
Marsh Posté le 16-09-2005 à 18:00:37
Suivre scrupuleusement la procédure.
Après la désinstallation, la CG doit être vue comme une carte VGA "de base".
Marsh Posté le 16-09-2005 à 18:05:54
oui c est ce qui c ets affiché lorsque j ai desintallé tout les drivers
Marsh Posté le 16-09-2005 à 18:09:38
Quelle moniteur video as-tu ?
S'il s'agit d'un LCD, tu devrais avoir un pilote Windows pour le moniteur.
Le réglage se fait avec "Propriétés affichage", Onglet "paramètres" et bouton "avance", onglet "écran"
Petit conseil: désactiver "VPU recover"
Marsh Posté le 16-09-2005 à 18:15:27
Après désinstallation complète, la video est fortement dégradée (faible définition genre 640X480, nombre de couleurs limité (16 ?)).
Aller dans le Gestionnaire de périphérique pour "voir".
Au reboot, si Windows propose d'installer des pilotes pour la CG, ne PAS le laisser faire, et lancer le programme d'installation d'ATI.
Le laisser se dérouler entièrement sans intervenir (patience, c'est qqfois un peu long).
Puis rebooter de nouveau.
Choisir ensuite les options video dans "proprietes affichage".
Marsh Posté le 16-09-2005 à 18:33:45
voila c est fait!!
je vais maintenant voir si ca marche......
Marsh Posté le 16-09-2005 à 18:55:35
Essayes de démarrer en mode sans echec, et de reconfigurer les paramètres vidéos avant de rebooter en mode normal.
Marsh Posté le 16-09-2005 à 19:08:38
Essaye en AGP 4X ( pas de différence de perfs) en désactivant éventuellement le Fastwrite...
Regarde aussi ton Aperture Size (256 Max...)
Marsh Posté le 16-09-2005 à 19:10:07
Choisir les paramètres optimaux pour le moniteur.
-Quel moniteur video as-tu ?
-Quelle est la marque de la 9600XT ?
-Quels pilotes as-tu installés (version, provenance) ?
Marsh Posté le 16-09-2005 à 19:21:48
mon moniteur est un vieu sony de 1995.....
la marque de ma 9600 ??? ba sur la boite c est marqué excalibur  radeon 9600 et aussi ya marqué HIS dessus
les pilotes installé vien du site de ati ce sont les plus recent la version  5.8 avec catalyste control center
Marsh Posté le 16-09-2005 à 19:34:50
mai_68:Essaye en AGP 4X ( pas de différence de perfs) en désactivant éventuellement le Fastwrite...
j ai deja essayé avec l agp en 4x et avec la version 5.3 et 5.4 des drivers d ati est ca marche mais ca se remet a buguer entre 2 et 60 minutes de jeux donc je ne comprend rien .........
desactiver le fastwrite je sais pas ou ca se trouve de meme que aperture size...
Marsh Posté le 16-09-2005 à 20:20:02
-Peux-tu préciser ta config (CM, proc, mémoire, etc..) ainsi que la version de windows ?
-Il doit y avoir un nom de modèle pour ton moniteur (en façade, sur étiquette à l'arrière,...), indiques-le, stp.
-Quels sont tes paramètres video actuels ?
-Assures-toi que la carte vidéo est bien enfoncée dans le slot.
-Verifies les branchements, côté carte, et côté moniteur.
 -Les pilotes de la carte mère sont-ils à jour ?
-Catalyst control center est inutile, télécharges et installes la version pilotes Radeon avec control center (si winXP):
http://www2.ati.com/drivers/5-8_xp [...] _25203.exe
Marsh Posté le 16-09-2005 à 20:56:14
proc: amd atlon 2600
memoire:256mb ddr-sdram
Cm:nec computer international
windows xp edition familiale
model du moniteur :CPD-15SF2
le branchement de la carte graphique sur la CM est bon enfin je pensse vu que je ne peux plus l enfoncer plus loin et pour l ecrant je ne sait pas car je dois utiliser un adaptateur fourni avec la CG qui doit bien etre mis
pour les pilotes de la CM je ne sait pas vu que je ne connais pas cette chose c est inconu pour moi je debute dans  linformatqiue.....
Marsh Posté le 16-09-2005 à 22:08:36
| dudek a écrit : mai_68:Essaye en AGP 4X ( pas de différence de perfs) en désactivant éventuellement le Fastwrite...   |
Les fonctions en question sont dans le BIOS...
Sinon, je crois que tu peux les trouver Paramètres/ Panneau de config/ Affichage/Paramètres/Avancé/onglet SmartGan (ou quelque chose comme ça...).
Sinon, désolé pour toi si ça ne marche, car l'AGP en 4X a déjà résolu pas mal de problème similaire sur des 9600 Pro ou XT (dont deux personnes autour de moi).
Sinon, faut peut être voir du côté de l'alim pas suffisante sur le 12V pour accepter sans broncher le passage d'une 9200SE à une 9600XT...
Marsh Posté le 17-09-2005 à 13:43:23
le fastwrite etait deja desactivé donc ca ne vien pas de ca
mais par contre j ai pu remarqué que le message out of scan range s affiche le plus souvant orsque je met l agp en 4x
Marsh Posté le 20-09-2005 à 18:09:10
a aussi un truc me trotine dans la tete ..
ce  probleme pourait il venir du manque de ram??? car j ai pu remarquer que lorsque mon jeux rame et plante pendant quelque seconde c est a ce moment la que l ecrant s eteint .
Marsh Posté le 27-09-2005 à 20:50:51
toujours personne pour m aider????
bon j ai peu etre un truc plus simple pour vous car j ai un message d erreure qui s affiche lorsque j instale les pilotes les plus recents.
le message est :
"VPU recover a reinitialisé votre accelerateur graphique car il ne répondais plus aux comande du pilote d affichage"
puis lorsque je clique sur ne pas envoyer le message d erreur il y a un nouveau message d erreur qui est
"vpu recover n a pas pu corriger un probleme de blocage materiel et a basculé en rendu logiciel. pour restaurer le rendu materiel vous devez redemarer votre ordinateur"
c est koi ce probleme svp aidez moi!!
Marsh Posté le 16-09-2005 à 17:30:39
bonjours à tous!
voila mon problème:
j ai acheté une ati 9600xt et ma carte précédente était une ati 9200se.
après avoir installé ma 9600 je constate que lorsque je joue ou lorsque je suis sur le bureau et en fonction du drivers j ai mon écran qui devient soit noir et je ne peux plus rien faire et/ou il devient noir avec un message "out of scan range", je suis donc obligé de faire un rebout pour le débloquer (aussi il m est arrivé que l ecran devienne noir et que le jeux ne soit pas planté car j entendais les bruitage de jeux normalement)
que dois je faire ????(vu que j ai déjà demandé a un magasin de réparation d ordi et le monsieur a l intérieur ne connaissait pas mon problème)
ps:j ai deja essayé de desinstaller tout les driver et de les enlever avec un driver cleaner mais ca n a pas marché
