On Sun 28/04/2013 09:17:01 GMT your computer crashed crash dump file: C:\windows\Minidump\042813-8640-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x5A240) Bugcheck code: 0x7A (0x4, 0x200, 0xFFFFFA8006F24780, 0x40000C) Error: KERNEL_DATA_INPAGE_ERROR file path: C:\windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 28/04/2013 09:17:01 GMT your computer crashed crash dump file: C:\windows\memory.dmp This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0) Bugcheck code: 0x7A (0x4, 0x200, 0xFFFFFA8006F24780, 0x40000C) Error: KERNEL_DATA_INPAGE_ERROR Bug check description: This bug check indicates that the requested page of kernel data from the paging file could not be read into memory. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
2 crash dumps have been found and analyzed. No offending third party drivers have been found. Consider configuring your system to produce a full memory dump for better analysis.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Marsh Posté le 28-04-2013 à 11:51:40
Depuis quelques jours j'ai des problèmes de plantage et d'écran bleu sur mon PC. Il m'indique le soucis suivant: Kernel_Data_Inpage_Error.
J'ai testé les disques durs: RAS
J'ai testé les barrettes de RAM: RAS
J'aimerai éviter de réinstaller tout le système si possible.
Voici une capture d'écran du rapport Windows:
J'ai également fait une analyse avec Whocrashed, voici le rapport:
System Information (local)
computer name: MATHIEU
windows version: Windows 8 , 6.2, build: 9200
windows dir: C:\windows
CPU: GenuineIntel Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 8538275840 total
VM: 2147352576, free: 1929609216
Crash Dump Analysis
Crash dump directory: C:\windows\Minidump
Crash dumps are enabled on your computer.
Conclusion
Mathieu
