Bonsoir j'ai un pb avc mon pc sa fait plusieurs fois qu'il crash et suit un écran beu -_- du coup j'ai utilisé un logiciel pour savoir le pb " WHOCRASHED" si quelqu'un veut bien m'éclairer svp ; merci d'avance
On Sat 16/04/2011 17:56:16 GMT your computer crashed crash dump file: C:\Windows\Minidump\041611-14726-01.dmp This was probably caused by the following module: ataport.sys (ataport+0x1C74) Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0) Error: KMODE_EXCEPTION_NOT_HANDLED file path: C:\Windows\system32\drivers\ataport.sys product: Microsoft® Windows® Operating System company: Microsoft Corporation description: ATAPI Driver Extension Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
Marsh Posté le 16-04-2011 à 21:04:15
Bonsoir
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
