Pb de bluescreen, quel matériel est a l'origine? - Matériels & problèmes divers - Hardware
Marsh Posté le 06-08-2011 à 15:49:26
Hello, le bsod est souvent ( mais pas toujours) du a la Ram.....
Marsh Posté le 06-08-2011 à 18:20:22
ok mais comment en etre sur alors?
et quel type de pb? chaleur?
Marsh Posté le 07-08-2011 à 00:16:01
pour tester la ram ya ubcd ultimate boot cd (google est ton ami)
un cd bootable avec plein d'utilitaires pour tester le pc :-)
donc ya mem test pour tester la mémoire
pour la température va dans le bios apres avoir testé la ram
(un dépoussierage du pc ?)
Marsh Posté le 07-08-2011 à 00:41:20
salut telecharge wocrashed http://www.01net.com/telecharger/w [...] 00572.html
et colle le résultat si tu veux bien .
Marsh Posté le 07-08-2011 à 13:58:59
RAPPORT DE WHOCRASHED:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 06/08/2011 13:11:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080611-12948-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x32492B)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8585C024, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sat 06/08/2011 12:38:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\080611-13275-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8584E8FC, 0x0, 0x0)
On Fri 15/07/2011 07:59:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071511-13774-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85877714, 0x0, 0x0)
On Thu 14/07/2011 14:15:03 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071411-13275-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8581C024, 0x0, 0x0)
On Wed 13/07/2011 18:44:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071311-14024-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8588669C, 0x0, 0x0)
On Mon 11/07/2011 20:22:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071111-13837-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8581A8FC, 0x0, 0x0)
On Mon 11/07/2011 17:31:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\071111-16536-01.dmp
This was probably caused by the following module: hal.sys (hal+0xEFCD)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8578E024, 0xFFFFFFFFF2000040, 0x800)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hal.sys .
Google query: hal.sys WHEA_UNCORRECTABLE_ERROR
On Sat 09/07/2011 20:11:06 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070911-14211-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8586E8FC, 0x0, 0x0)
On Sat 09/07/2011 19:19:00 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070911-14040-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85883024, 0x0, 0x0)
On Tue 05/07/2011 21:21:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070511-13790-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85891314, 0x0, 0x0)
On Tue 05/07/2011 13:52:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070511-14274-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF858698FC, 0x0, 0x0)
On Fri 01/07/2011 19:49:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070111-12604-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8582847C, 0x0, 0x0)
On Fri 01/07/2011 18:46:14 GMT your computer crashed
crash dump file: C:\Windows\Minidump\070111-14071-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF858868FC, 0x0, 0x0)
On Thu 30/06/2011 12:56:22 GMT your computer crashed
crash dump file: C:\Windows\Minidump\063011-13244-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF8582879C, 0x0, 0x0)
On Thu 30/06/2011 12:49:07 GMT your computer crashed
crash dump file: C:\Windows\Minidump\063011-13743-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF858858FC, 0x0, 0x0)
Conclusion
38 crash dumps have been found and analyzed. Only 15 are included in this report. 6 third party drivers have been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
hal.sys
unknown
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Marsh Posté le 07-08-2011 à 14:40:37
| Citation : This problem might be caused by a thermal issue |
Oui surchauffe, reste à trouver quoi .
Peux-tu renseigner ta config complète ? Est-ce toi qui l'a montée?
Marsh Posté le 07-08-2011 à 14:44:33
Télécharge aussi http://www.clubic.com/telecharger- [...] nitor.html et poste un screen en retour si tu veux bien
Marsh Posté le 07-08-2011 à 15:52:10
config: win 7, 2 barettes de 1Go (que je viens de tester et elles sont ok)
rapport de hardware monitor:
Marsh Posté le 07-08-2011 à 16:12:28
Télécharge http://www.ocbase.com/perestroika/index.php?Download
et stresse le GPU & le CPU pour commencer
http://www.ozone3d.net/benchmarks/fur/index.php?lang=1 pour la CG
Tu n'as pas mis l'alim et les ventirad sur ta config .
A lire http://www.nhfr.org/t4467-stress-tests
Marsh Posté le 07-08-2011 à 16:33:13
c'est une alim de base, je l'ai changée ya un ptit bout de temps déja, j'étais passé d'une 480W a une un poil plus puissante (500 ou 550W je sais plus, et la je peux pas demonter pour voir)
pour les ventirad je comprend pas trop...(désolé pour mon ignorance) c'est les ventilo ca ? a part celui de l'alim, celui du boitier et ceux propre aux CPU et carte graphique, j'en a pas...
p.s: c'est un pc monté soi meme
j'ai lancé OCCT, je posterais les resultats, par contre ya 2 test GPU et 2 test CPU et je ne peux pas faire le GPU: MEMTEST, j'ai lancé le GPU: OCCT
edit: ah ok pour le GPUMEMTEST c'est parcque j'ai pas la bonne carte graphique
Marsh Posté le 07-08-2011 à 17:34:09
j'ai lancé un lancé un test OCCT CPU tout en regardant hardware monitoring et il semblerais que le CPU chauffe anormalement non?
si c bien le CPU, je peux y faire quoi? parcqu'il a été démonté ya pas longtemps, est il possible qu'il soit mal remonté et que ca soit qui le fasse surchauffé?
Marsh Posté le 07-08-2011 à 17:43:51
Ventirad d origine ???? un des clip est peut etre mal mis, mais bon, les bsod avec ça....!!!!!
Marsh Posté le 07-08-2011 à 17:46:27
Oui ça doit certainement venir d'un mauvais remontage si il a été démonté il y'a peu (dans la mesure ou tout fonctionnait bien avant)
Il faut démonter le rad, nettoyer le CPU avec un chiffon ( c'est plus facile quand il est tiède-gaffe à pas se bruler
) remettre de la pâte thermique et voir ce que ça donne. http://www.assemblersonpc.websitec [...] mbler.html
Sinon concernant l'alim il serait bien de l’identifier au passage, lors du démontage du rad.
Marsh Posté le 07-08-2011 à 19:15:47
j'ai demonté et remonté le CPU mais il semblait bien mis pourtant, au redemarrage, le systeme a reconnu un l'installation d'un nouveau CPU
l'alim c'est bien une 550W (si tu veux d'autre carac dis moi)
je relance un test OCCT CPU pour voir si ca chauffe toujours
Marsh Posté le 07-08-2011 à 19:30:10
ca fait exactement pareil que le test précédent...
je sais pas trop quoi faire...je vais attendre voir si ca replante
une question: c'est normal que la température du CPU augmente jusqu'a 75° pdt le test OCCT ? c'est p'tet pas du tout le CPU la cause du pb sinon?
edit: tu as parlé de pâte thermique...j'en ai plus du tout sur le CPU...je suppose que c'est pas top mais ca peut venir de la le pb?
Marsh Posté le 07-08-2011 à 21:43:17
| Julio0105 a écrit : |
Il y'a de forte chances en effet que ce ne soit que ça. Il va falloir en acheter .
Marsh Posté le 07-08-2011 à 22:30:07
ok merci, j'vais faire ca alors
mais depuis que j'ai démonté et remonté le proc, plus de plantage... mais un petit coup de pâte devrait ameliorer les choses, me reste plus qu'a en trouver
Marsh Posté le 06-08-2011 à 15:44:24
bonjour,
j'ai un pb de blue screen depuis quelque temps, mon pc plante grossomodo toutes les heures, et lors du redemarrage windows m'affiche ce message (voir plus bas)
j'ai cherché un peu sur le net pour savoir ce que ca signifiait et apparement c'est un pb matériel...
ma question est: quel matériel ???
je suppose qu'il y'en a un qui chauffe trop, mais est ce la carte graphique, le processeur, la ram, etc ???
j'ai vu qu'on pouvait utiliser le logiciel OCCT mais j'y comprend pas tout et j'ai peur de faire des conneries...
j'ai aussi lancé whocrashed mais idem j'y comprend rien...(je peux mettre le rapport si il faut)
bref si qqun pouvait m'aider a trouver le materiel a l'origine de mon bluescreen, ca serait sympa
d'avance merci
rapport d'erreur:
Signature du problème :
Nom d’événement de problème: BlueScreen
Version du système: 6.1.7601.2.1.0.256.1
Identificateur de paramètres régionaux: 1036
Informations supplémentaires sur le problème :
BCCode: 124
BCP1: 00000000
BCP2: 8585C024
BCP3: 00000000
BCP4: 00000000
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Fichiers aidant à décrire le problème :
C:\Users\juju\AppData\Local\Temp\WER-27518-0.sysdata.xml
Lire notre déclaration de confidentialité en ligne :
http://go.microsoft.com/fwlink/?li [...] cid=0x040c
Si la déclaration de confidentialité en ligne n’est pas disponible, lisez la version hors connexion :
C:\Windows\system32\fr-FR\erofflps.txt
