erreurs sur un Western Digital Caviar WD800 PATA
erreurs sur un Western Digital Caviar WD800 PATA - Disque dur - Hardware
Marsh Posté le 06-10-2008 à 15:22:53
J'ai monté dans une machine un Western Digital Caviar WD800 PATA (un disque d'excellent qualité à mon humble avis).
La machine est basée sur une carte-mère Fujitsu-Siemens MSI MS-6340 avec un Athlon à 1 GHz
Au démarrage, au moment de monter le filesystem /dev/sda8 (/home), j'ai de beaux messages d'erreurs dans mon dmesg, regardez:
[   27.223982] SCSI subsystem initialized
[   27.387473] libata version 3.00 loaded.
[   27.479013] pata_via 0000:00:07.1: version 0.3.3
[   27.526444] scsi0 : pata_via
[   27.566784] scsi1 : pata_via
[   27.566993] ata1: PATA max UDMA/66 cmd 0x1f0 ctl 0x3f6 bmdma 0xd000 irq 14
[   27.567063] ata2: PATA max UDMA/66 cmd 0x170 ctl 0x376 bmdma 0xd008 irq 15
[   27.731619] ata1.00: ATA-6: WDC WD800LB-60DNA1, 80.07A80, max UDMA/100
[   27.731706] ata1.00: 156301488 sectors, multi 16: LBA48
[   27.747600] ata1.00: configured for UDMA/66
[   28.066456] ata2.00: ATAPI: LITE-ON DVDRW SOHW-1213S, TS08, max UDMA/33
[   28.150265] Floppy drive(s): fd0 is 1.44M
[   28.173821] FDC 0 is a post-1991 82077
[   28.238334] ata2.00: configured for UDMA/33
[   28.238723] scsi 0:0:0:0: Direct-Access     ATA      WDC WD800LB-60DN 80.0 PQ: 0 ANSI: 5
[   28.239874] scsi 1:0:0:0: CD-ROM            LITE-ON  DVDRW SOHW-1213S TS08 PQ: 0 ANSI: 5
[   29.502307] Driver 'sr' needs updating - please use bus_type methods
[   29.509031] Driver 'sd' needs updating - please use bus_type methods
[   29.509341] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
[   29.509488] sd 0:0:0:0: [sda] Write Protect is off
[   29.509553] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   29.509595] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   29.509780] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
[   29.509867] sd 0:0:0:0: [sda] Write Protect is off
[   29.509930] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[   29.509965] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   29.510053]  sda:sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[   29.513701] Uniform CD-ROM driver Revision: 3.20
[   29.513913] sr 1:0:0:0: Attached scsi CD-ROM sr0
[   29.524047]  sda1 sda2 <<5>sd 0:0:0:0: Attached scsi generic sg0 type 0
[   29.525217] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   29.528050]  sda5 sda6 sda7 sda8 >
[   29.555306] sd 0:0:0:0: [sda] Attached SCSI disk
[   31.158155] Attempting manual resume
[   31.158225] swsusp: Resume From Partition 8:5
[   31.158229] PM: Checking swsusp image.
[   31.158579] PM: Resume from disk failed.
[   31.204474] kjournald starting.  Commit interval 5 seconds
[   31.204583] EXT3-fs: mounted filesystem with ordered data mode.
[   42.803367] via686a 0000:00:07.4: Forcing ISA address 0x6000
[   42.803455] via686a 0000:00:07.4: Enabling sensors
[   51.462553] Adding 1951856k swap on /dev/sda5.  Priority:-1 extents:1 across:1951856k
[   51.814326] EXT3 FS on sda7, internal journal
[   52.035910] device-mapper: uevent: version 1.0.3
[   52.035983] device-mapper: ioctl: 4.12.0-ioctl (2007-10-02) initialised: dm-devel@redhat.com
[   83.046903] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   83.046986] ata1.00: BMDMA stat 0x25
[   83.047057] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   83.047061]          res 51/40:80:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   83.047142] ata1.00: status: { DRDY ERR }
[   83.047204] ata1.00: error: { UNC }
[   83.069070] ata1.00: configured for UDMA/66
[   83.069095] ata1: EH complete
[   85.018323] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   85.018407] ata1.00: BMDMA stat 0x25
[   85.018478] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   85.018482]          res 51/40:00:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   85.018563] ata1.00: status: { DRDY ERR }
[   85.018624] ata1.00: error: { UNC }
[   85.040160] ata1.00: configured for UDMA/66
[   85.040193] ata1: EH complete
[   86.928796] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   86.928881] ata1.00: BMDMA stat 0x25
[   86.928952] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   86.928955]          res 51/40:80:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   86.929919] ata1.00: status: { DRDY ERR }
[   86.929980] ata1.00: error: { UNC }
[   86.955230] ata1.00: configured for UDMA/66
[   86.955276] ata1: EH complete
[   88.854516] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   88.854600] ata1.00: BMDMA stat 0x25
[   88.854672] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   88.854675]          res 51/40:80:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   88.854756] ata1.00: status: { DRDY ERR }
[   88.854818] ata1.00: error: { UNC }
[   88.878308] ata1.00: configured for UDMA/66
[   88.878341] ata1: EH complete
[   90.729415] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   90.729500] ata1.00: BMDMA stat 0x25
[   90.729572] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   90.729575]          res 51/40:80:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   90.729656] ata1.00: status: { DRDY ERR }
[   90.729718] ata1.00: error: { UNC }
[   90.753412] ata1.00: configured for UDMA/66
[   90.753445] ata1: EH complete
[   92.608423] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   92.608509] ata1.00: BMDMA stat 0x25
[   92.608581] ata1.00: cmd c8/00:80:d1:92:f6/00:00:00:00:00/e8 tag 0 dma 65536 in
[   92.608584]          res 51/40:80:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   92.608665] ata1.00: status: { DRDY ERR }
[   92.608726] ata1.00: error: { UNC }
[   92.632517] ata1.00: configured for UDMA/66
[   92.632575] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
[   92.632585] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
[   92.632595] Descriptor sense data with sense descriptors (in hex):
[   92.632599]         72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[   92.632610]         08 f6 93 02
[   92.632616] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
[   92.632628] end_request: I/O error, dev sda, sector 150377218
[   92.632636] Buffer I/O error on device sda8, logical block 16351248
[   92.632706] Buffer I/O error on device sda8, logical block 16351249
[   92.632774] Buffer I/O error on device sda8, logical block 16351250
[   92.632843] Buffer I/O error on device sda8, logical block 16351251
[   92.632911] Buffer I/O error on device sda8, logical block 16351252
[   92.632979] Buffer I/O error on device sda8, logical block 16351253
[   92.633047] Buffer I/O error on device sda8, logical block 16351254
[   92.633115] Buffer I/O error on device sda8, logical block 16351255
[   92.633183] Buffer I/O error on device sda8, logical block 16351256
[   92.633250] Buffer I/O error on device sda8, logical block 16351257
[   92.633349] ata1: EH complete
[   94.437584] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   94.437668] ata1.00: BMDMA stat 0x25
[   94.437740] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[   94.437744]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   94.437824] ata1.00: status: { DRDY ERR }
[   94.437886] ata1.00: error: { UNC }
[   94.459645] ata1.00: configured for UDMA/66
[   94.459679] ata1: EH complete
[   96.304168] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   96.304253] ata1.00: BMDMA stat 0x25
[   96.304325] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[   96.304328]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   96.304409] ata1.00: status: { DRDY ERR }
[   96.304470] ata1.00: error: { UNC }
[   96.326731] ata1.00: configured for UDMA/66
[   96.326764] ata1: EH complete
[   98.174899] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   98.174983] ata1.00: BMDMA stat 0x25
[   98.175054] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[   98.175058]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[   98.175139] ata1.00: status: { DRDY ERR }
[   98.175200] ata1.00: error: { UNC }
[   98.197855] ata1.00: configured for UDMA/66
[   98.197888] ata1: EH complete
[   99.999914] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[   99.999999] ata1.00: BMDMA stat 0x25
[  100.000071] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  100.000074]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  100.000155] ata1.00: status: { DRDY ERR }
[  100.000216] ata1.00: error: { UNC }
[  100.024966] ata1.00: configured for UDMA/66
[  100.024999] ata1: EH complete
[  101.924695] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  101.924781] ata1.00: BMDMA stat 0x25
[  101.924853] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  101.924856]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  101.924938] ata1.00: status: { DRDY ERR }
[  101.925000] ata1.00: error: { UNC }
[  101.948063] ata1.00: configured for UDMA/66
[  101.948095] ata1: EH complete
[  103.799569] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  103.799653] ata1.00: BMDMA stat 0x25
[  103.799724] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  103.799728]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  103.799809] ata1.00: status: { DRDY ERR }
[  103.799870] ata1.00: error: { UNC }
[  103.823194] ata1.00: configured for UDMA/66
[  103.823232] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
[  103.823241] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
[  103.823251] Descriptor sense data with sense descriptors (in hex):
[  103.823255]         72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[  103.823267]         08 f6 93 02
[  103.823272] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
[  103.823285] end_request: I/O error, dev sda, sector 150377218
[  103.823295] Buffer I/O error on device sda8, logical block 16351248
[  103.823399] ata1: EH complete
[  103.823798] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
[  105.628749] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  105.628834] ata1.00: BMDMA stat 0x25
[  105.628907] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  105.628910]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  105.628992] ata1.00: status: { DRDY ERR }
[  105.629053] ata1.00: error: { UNC }
[  105.654299] ata1.00: configured for UDMA/66
[  105.654332] ata1: EH complete
[  107.507757] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  107.507842] ata1.00: BMDMA stat 0x25
[  107.507913] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  107.507917]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  107.507998] ata1.00: status: { DRDY ERR }
[  107.508059] ata1.00: error: { UNC }
[  107.533404] ata1.00: configured for UDMA/66
[  107.533437] ata1: EH complete
[  109.428475] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  109.428560] ata1.00: BMDMA stat 0x25
[  109.428631] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  109.428635]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  109.428716] ata1.00: status: { DRDY ERR }
[  109.428777] ata1.00: error: { UNC }
[  109.452468] ata1.00: configured for UDMA/66
[  109.452502] ata1: EH complete
[  111.249277] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  111.249361] ata1.00: BMDMA stat 0x25
[  111.249433] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  111.249437]          res 51/40:00:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  111.249518] ata1.00: status: { DRDY ERR }
[  111.249579] ata1.00: error: { UNC }
[  111.271609] ata1.00: configured for UDMA/66
[  111.271641] ata1: EH complete
[  113.070238] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  113.070323] ata1.00: BMDMA stat 0x25
[  113.070394] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  113.070397]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  113.070478] ata1.00: status: { DRDY ERR }
[  113.070539] ata1.00: error: { UNC }
[  113.094743] ata1.00: configured for UDMA/66
[  113.094776] ata1: EH complete
[  114.990807] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[  114.990892] ata1.00: BMDMA stat 0x25
[  114.990963] ata1.00: cmd c8/00:08:01:93:f6/00:00:00:00:00/e8 tag 0 dma 4096 in
[  114.990967]          res 51/40:08:02:93:f6/00:00:00:00:00/e8 Emask 0x9 (media error)
[  114.991048] ata1.00: status: { DRDY ERR }
[  114.991109] ata1.00: error: { UNC }
[  115.013830] ata1.00: configured for UDMA/66
[  115.013867] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE,SUGGEST_OK
[  115.013875] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
[  115.013886] Descriptor sense data with sense descriptors (in hex):
[  115.013890]         72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[  115.013901]         08 f6 93 02
[  115.013906] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
[  115.013918] end_request: I/O error, dev sda, sector 150377218
[  115.013929] Buffer I/O error on device sda8, logical block 16351248
[  115.014035] ata1: EH complete
[  115.015356] sd 0:0:0:0: [sda] Write Protect is off
[  115.015363] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  115.034947] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  115.035101] sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
[  115.035125] sd 0:0:0:0: [sda] Write Protect is off
[  115.035130] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[  115.035166] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  121.392975] kjournald starting.  Commit interval 5 seconds
[  121.393438] EXT3 FS on sda6, internal journal
[  121.393449] EXT3-fs: mounted filesystem with ordered data mode.
Cependant, je pense que le problème ne vient pas du disque (Western Digital PATA c'est à mon humble avis de la très bonne qualité) mais bien de la carte-mère, c'est un modèle réputé pour "mal vieillir". D'ailleurs j'ai déjà posté au sujet de la carte mère et de l'Athlon: j'avais des erreurs bizarres du genre kernel panic lors d'un redémarrage à chaud, et je suspectais que l'Athlon était overclocké.
En fait quelques jours avant je n'avais pas du tout ces erreurs. Je pense que la machine a fait un kernel panic juste au moment où le système était en train d'écrire sur le filesystem /dev/sda8.
D'ailleurs, remarquez que toutes ces erreurs ne se produisent que lors du montage du filesystem /dev/sda8, pas lors du montage de /dev/sda6 ni /dev/sda7.
Merci,
