Erreur sous 3D mark2001 en Loop. - Bench - Hardware
Marsh Posté le 17-04-2006 à 22:48:32
Application info
Name          3DMark2001 SE
Build         330
Error log
Display window lost focus.
System info available: yes
Project available:     yes
Result file
3DMARK2001 PROJECT FILE
PROJECT
Name	My Benchmark
Description
Registration Name
Registration Key
3DMark Version	330
DISPLAY
Platform	NVIDIA GeForce 7800 GTX
CPU Optimization	D3D Pure Hardware T&L
Width	1024
Height	768
Depth	32 bit
Z-Buffering	24 bit
Texture Format	Compressed
Buffering	Double
Refresh Rate	60 Hz
FSAA Mode	None
OPTIONS
Show Title Screens	Yes
Continuous Benchmark	Yes
Benchmark Run Count	1
Demo Sounds Enabled	Yes
Continuous Demo	No
Game Sound Effects Enabled	Yes
Game Music Enabled	Yes
Game Detail Level	Low
RESULTS
3DMark Score	N/A
Game 1 - Car Chase - Low Detail	399.1 fps
Game 1 - Car Chase - High Detail	132.2 fps
Game 2 - Dragothic - Low Detail	611.8 fps
Game 2 - Dragothic - High Detail	290.4 fps
Game 3 - Lobby - Low Detail	358.5 fps
Game 3 - Lobby - High Detail	166.6 fps
Game 4 - Nature	243.8 fps
Fill Rate (Single-Texturing)	4600.3 MTexels/s
Fill Rate (Multi-Texturing)	10041.2 MTexels/s
High Polygon Count (1 Light)	206.9 MTriangles/s
High Polygon Count (8 Lights)	53.6 MTriangles/s
Environment Bump Mapping	695.6 fps
DOT3 Bump Mapping	N/A
Vertex Shader	404.1 fps
Pixel Shader	539.8 fps
Advanced Pixel Shader	836.3 fps
Point Sprites	75.1 MSprites/s
SYSTEM INFO
System Info Version	2.2
Installation ID	0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer	AMD
Family	<unknown>
Internal Clock	2.90 GHz
Internal Clock Maximum	3 GHz
External Clock	194 MHz
Socket Designation	Socket 939
Type	<unknown>
Upgrade	<unknown>
Capabilities	MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2
Version	AMD Opteron(tm) Processor 146
CPUID	0x00020f71
CACHES
Level	1
Capacity	128 KB
Type	Internal
Type Details	Synchronous
Error Correction Type	<unknown>
Associativity	<unknown>
Level	1
Capacity	128 KB
Type	Internal
Level	2
Capacity	1 MB
Type	Internal
Level	2
Capacity	1 MB
Type	Internal
Manufacturer	AMD
Family	<unknown>
Type	<unknown>
Upgrade	<unknown>
CPUID	0x00020f71
CACHES
Level	1
Capacity	128 KB
Type	Internal
Level	1
Capacity	128 KB
Type	Internal
Level	2
Capacity	1 MB
Type	Internal
Level	2
Capacity	1 MB
Type	Internal
DIRECTX INFO
DirectX Version	9.0
DIRECTDRAW INFO
DirectDraw Version  5.03.2600.2180
DISPLAY DEVICES
Description	Pilote d'affichage principal
Manufacturer	NVIDIA
Name	NVIDIA GeForce 7800 GTX
Total Local Video Memory	256 MB
Total Local Texture Memory	256 MB
Total AGP Memory	248 MB
Display Driver	nv4_disp.dll
Display Driver Version	6.14.10.8198
Driver WHQL Certified	Yes
Max Texture Width  4096
Max Texture Height	4096
Max User Clipping Planes	6
Max Active Hardware Lights	8
Max Texture Blending Stages	8
Textures In Single Pass	8
Vertex Shader Version	1.1
Pixel Shader Version	1.4
Max Vertex Blend Matrices	0
Max Texture Coordinates	8
Vendor ID	0x10de
Device ID	0x0091
Sub-System ID	0x02c210de
Revision	0xa1
DISPLAY MODES
Resolution	640x480x16-bit RGB [565] @ 60 Hz
Resolution	640x480x32-bit RGB [888] @ 60 Hz
Resolution	320x200x16-bit RGB [565] @ 60 Hz
Resolution	320x240x16-bit RGB [565] @ 60 Hz
Resolution	400x300x16-bit RGB [565] @ 60 Hz
Resolution	480x360x16-bit RGB [565] @ 60 Hz
Resolution	512x384x16-bit RGB [565] @ 60 Hz
Resolution	640x400x16-bit RGB [565] @ 60 Hz
Resolution	640x400x16-bit RGB [565] @ 70 Hz
Resolution	640x480x16-bit RGB [565] @ 72 Hz
Resolution	640x480x16-bit RGB [565] @ 75 Hz
Resolution	800x600x16-bit RGB [565] @ 60 Hz
Resolution	800x600x16-bit RGB [565] @ 72 Hz
Resolution	800x600x16-bit RGB [565] @ 75 Hz
Resolution	1024x768x16-bit RGB [565] @ 60 Hz
Resolution	1024x768x16-bit RGB [565] @ 70 Hz
Resolution	1024x768x16-bit RGB [565] @ 72 Hz
Resolution	1024x768x16-bit RGB [565] @ 75 Hz
Resolution	1152x864x16-bit RGB [565] @ 75 Hz
Resolution	1280x960x16-bit RGB [565] @ 60 Hz
Resolution	1280x1024x16-bit RGB [565] @ 60 Hz
Resolution	1280x1024x16-bit RGB [565] @ 75 Hz
Resolution	1600x900x16-bit RGB [565] @ 60 Hz
Resolution	320x200x32-bit RGB [888] @ 60 Hz
Resolution	320x240x32-bit RGB [888] @ 60 Hz
Resolution	400x300x32-bit RGB [888] @ 60 Hz
Resolution	480x360x32-bit RGB [888] @ 60 Hz
Resolution	512x384x32-bit RGB [888] @ 60 Hz
Resolution	640x400x32-bit RGB [888] @ 60 Hz
Resolution	640x400x32-bit RGB [888] @ 70 Hz
Resolution	640x480x32-bit RGB [888] @ 72 Hz
Resolution	640x480x32-bit RGB [888] @ 75 Hz
Resolution	800x600x32-bit RGB [888] @ 60 Hz
Resolution	800x600x32-bit RGB [888] @ 72 Hz
Resolution	800x600x32-bit RGB [888] @ 75 Hz
Resolution	1024x768x32-bit RGB [888] @ 60 Hz
Resolution	1024x768x32-bit RGB [888] @ 70 Hz
Resolution	1024x768x32-bit RGB [888] @ 72 Hz
Resolution	1024x768x32-bit RGB [888] @ 75 Hz
Resolution	1152x864x32-bit RGB [888] @ 75 Hz
Resolution	1280x960x32-bit RGB [888] @ 60 Hz
Resolution	1280x1024x32-bit RGB [888] @ 60 Hz
Resolution	1280x1024x32-bit RGB [888] @ 75 Hz
Resolution	1600x900x32-bit RGB [888] @ 60 Hz
Resolution	800x600x16-bit RGB [565] @ 56 Hz
Resolution	1440x900x16-bit RGB [565] @ 75 Hz
Resolution	1680x1050x16-bit RGB [565] @ 60 Hz
Resolution	800x600x32-bit RGB [888] @ 56 Hz
Resolution	1440x900x32-bit RGB [888] @ 75 Hz
Resolution	1680x1050x32-bit RGB [888] @ 60 Hz
TEXTURE FORMATS
Pixel Format	32-bit ARGB [8888]
Pixel Format	32-bit RGB [888]
Pixel Format	16-bit RGB [565]
Pixel Format	16-bit RGB [555]
Pixel Format	16-bit ARGB [1555]
Pixel Format	16-bit ARGB [4444]
Pixel Format	8-bit A [8]
Pixel Format	8-bit YUV [800]
Pixel Format	16-bit AYUV [8800]
Pixel Format	FourCC [DXT1]
Pixel Format	FourCC [DXT2]
Pixel Format	FourCC [DXT3]
Pixel Format	FourCC [DXT4]
Pixel Format	FourCC [DXT5]
3D Capabilities	AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version	6.05.2600.2180
REGISTERED DIRECTSHOW FILTERS
Filter	.RAM file Parser
Filter	AC3 Parser Filter
Filter	AC3Filter
Filter	ACELP.net Sipro Lab Audio Decoder
Filter	ACM Wrapper
Filter	ASF ACM Handler
Filter	ASF DIB Handler
Filter	ASF DJPEG Handler
Filter	ASF ICM Handler
Filter	ASF JPEG Handler
Filter	ASF URL Handler
Filter	ASF embedded stuff Handler
Filter	ASX file Parser
Filter	ASX v.2 file Parser
Filter	AVI Decompressor
Filter	AVI Draw
Filter	AVI Splitter
Filter	AVI/WAV File Source
Filter	Color Space Converter
Filter	CoreAVC Video Decoder
Filter	CoreVorbis Audio Decoder
Filter	CyberLink Audio Decoder
Filter	CyberLink MPEG Splitter
Filter	CyberLink Video/SP Decoder
Filter	DV Muxer
Filter	DV Splitter
Filter	DV Video Decoder
Filter	Decrypt/Tag
Filter	Default DirectSound Device
Filter	Default MidiOut Device
Filter	DirectVobSub (auto-loading version)
Filter	FLAC Decode Filter
Filter	File Source (Async.)
Filter	File Source (Monkey Audio)
Filter	File Source (Netshow URL)
Filter	File Source (URL)
Filter	File stream renderer
Filter	Haali Media Splitter
Filter	Haali Media Splitter (AR)
Filter	IVF source filter
Filter	Indeo® audio software
Filter	Indeo® video 4.4 Decompression Filter
Filter	Indeo® video 5.10 Decompression Filter
Filter	Internal Script Command Renderer
Filter	Line 21 Decoder
Filter	Line 21 Decoder 2
Filter	Lyric Parser
Filter	MIDI Parser
Filter	MJPEG Decompressor
Filter	MPEG Audio Decoder
Filter	MPEG Layer-3 Decoder
Filter	MPEG Video Decoder
Filter	MPEG-2 Demultiplexer
Filter	MPEG-2 Sections and Tables
Filter	MPEG-2 Splitter
Filter	MPEG-I Stream Splitter
Filter	Microsoft MPEG-4 Video Decompressor
Filter	Microsoft Screen Video Decompressor
Filter	Multi-file Parser
Filter	NSC file Parser
Filter	NVVPE
Filter	Native FLAC Source Filter
Filter	Nero DVD Decoder
Filter	Nero DVD Navigator
Filter	Nero Digital Audio Decoder
Filter	Nero Digital Parser
Filter	Nero ES Video Reader
Filter	Nero File Source (Async.)
Filter	Nero File Source / Splitter
Filter	Nero QuickTime(tm) Audio Decoder
Filter	Nero QuickTime(tm) Video Decoder
Filter	Nero Splitter
Filter	Nero Vcd Navigator
Filter	Nero Video Decoder
Filter	Overlay Mixer2
Filter	QT Decompressor
Filter	QuickTime Movie Parser
Filter	RadLight MPC DirectShow Filter
Filter	RealAudio Decoder
Filter	RealMedia Source
Filter	RealMedia Splitter
Filter	RealVideo Decoder
Filter	SAMI (CC) Parser
Filter	ShoutcastSource
Filter	VBI Surface Allocator
Filter	VGA 16 Color Ditherer
Filter	VP6 Decompressor
Filter	VP7 Decompressor
Filter	Video Port Manager
Filter	Video Renderer
Filter	Voxware MetaSound Audio Decoder
Filter	WM ASF Reader
Filter	WM ASF Writer
Filter	WST Decoder
Filter	WavPack Audio Decoder
Filter	WavPack Audio Splitter
Filter	Wave Parser
Filter	Windows Media Audio Decoder
Filter	Windows Media Multiplexer
Filter	Windows Media Pad VU Data Grabber
Filter	Windows Media Update Filter
Filter	Windows Media Video Decoder
Filter	Windows Media source filter
Filter	XML Playlist
Filter	ffdshow Audio Decoder
Filter	ffdshow MPEG-4 Video Decoder
MEMORY INFO
Total Physical Memory	1022 MB
Free Physical Memory	668.94 MB
Total Pagefile Memory	2.40 GB
Free Pagefile Memory	2.16 GB
MEMORY ARRAYS
Max Module Capacity	16 GB
Location	System Board
Use	System
Supported Error D&C	None
Supported Speeds	<unknown>
Supported Types	<unknown>
Supported Voltages	<unknown>
MEMORY SLOTS
Installed & Enabled Size	0  bytes
Form Factor	DIMM
Frequency	0 Hz
Slot	A0 [Bank0/1]
Manufacturer
Type	<unknown>
Type Details	<unknown>
Total Bit Width	64
Data Bit Width	64
Form Factor	DIMM
Frequency	0 Hz
Slot	A1 [Bank2/3]
Manufacturer
Type	<unknown>
Total Bit Width	64
Data Bit Width	64
Installed & Enabled Size	512 MB
Form Factor	DIMM
Frequency	0 Hz
Slot	A2 [Bank4/5]
Manufacturer
Type	<unknown>
Enabled Size	512 MB
Total Bit Width	64
Data Bit Width	64
Form Factor	DIMM
Frequency	0 Hz
Slot	A3 [Bank6/7]
Manufacturer
Type	<unknown>
Enabled Size	512 MB
Total Bit Width	64
Data Bit Width	64
MOTHERBOARD INFO
Manufacturer	DFI Corp,LTD
Model	LP UT NF4 Expert
Version	1.0
BIOS Vendor	Phoenix Technologies, LTD
BIOS Version	6.00 PG
BIOS Release Date	03/29/2006
BIOS Properties	Plug and Play, Flash
CARD SLOTS
Number	1
Designation	PCI0
Type	PCI
Characteristics	5.0V, PME Signal
Data Bus Width	32
Details	Available, Long
Device Class	<unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID	0x0000
Device ID	0x0000
Device Sub-System ID	0x00000000
Device Revision	0x00
IRQ	0
Number	2
Designation	PCI1
Type	PCI
Data Bus Width	32
Device Name
Device Manufacturer
Device Driver Date
Device ID	0x0000
IRQ	0
Number	3
Designation	PCI2
Type	PCI
Data Bus Width	32
Device Name
Device Manufacturer
Device Driver Date
Device ID	0x0000
IRQ	0
Number	4
Designation	PCI3
Type	PCI
Data Bus Width	32
Device Name
Device Manufacturer
Device Driver Date
Device ID	0x0000
IRQ	0
Number	5
Designation	PCI4
Type	PCI
Data Bus Width	32
Device Name
Device Manufacturer
Device Driver Date
Device ID	0x0000
IRQ	0
SYSTEM DEVICES
Description	Pont CPU hôte standard PCI
Manufacturer	(Périphériques système standard)
Vendor ID	0x1022
Device ID	0x1100
Subsystem ID	0x00000000
Revision	0x00
Vendor ID	0x1022
Device ID	0x1101
Revision	0x00
Vendor ID	0x1022
Device ID	0x1102
Revision	0x00
Vendor ID	0x1022
Device ID	0x1103
Revision	0x00
Description	Pont ISA standard PCI
Vendor ID	0x10de
Device ID	0x0050
Revision	0xa3
Description	NVIDIA nForce PCI System Management
Manufacturer	NVIDIA
Vendor ID	0x10de
Device ID	0x0052
Subsystem ID	0xcb8410de
Revision	0xa2
Description	Pont PCI vers PCI standard PCI
Vendor ID	0x10de
Device ID	0x005c
Revision	0xa2
Vendor ID	0x10de
Device ID	0x005d
Revision	0xa3
Vendor ID	0x10de
Device ID	0x005d
Revision	0xa3
Vendor ID	0x10de
Device ID	0x005d
Revision	0xa3
Vendor ID	0x10de
Device ID	0x005d
Revision	0xa3
Description	nForce4 HyperTransport Bridge
Manufacturer	NVIDIA
Vendor ID	0x10de
Device ID	0x005e
Revision	0xa3
Revision	N/A
Rate	<unknown>
Aperture Size	0  bytes
Sideband Addressing	<unknown>
Fast Write	<unknown>
MONITOR INFO
MONITORS
Name	Écran par défaut
Manufacturer	(Types d'écrans standard)
Max Width	0
Max Height	0
Max Width	0
Max Height	0
Max Width	0
Max Height	0
Max Width	0
Max Height	0
Name	Belinea 10 20 35 W / Art. No. 112005
Manufacturer	MAXDATA Systeme GmbH
Max Width	0
Max Height	0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System	Microsoft Windows XP
Version	5.1.2600
Service Pack	Service Pack 2
Locale	FR
Desktop Width	1680
Desktop Height	1050
Desktop BPP	32
HARD DISK INFO
HARD DISKS
Name	HDS722580VLSA80
Manufacturer	(Lecteurs de disque standard)
Capacity	76.69 GB
Model	HDS722580VLSA80
Interface Type	IDE
Name	HDT722516DLA380
Capacity	153.38 GB
Model	HDT722516DLA380
Interface Type	IDE
Name	HDT722525DLA380
Capacity	232.88 GB
Model	HDT722525DLA380
Interface Type	IDE
Marsh Posté le 17-04-2006 à 22:51:40
donc, à part :
Application info
Name          3DMark2001 SE
Build         330
Error log
y'a rien de spécifié donc je comprends pas pourquoi çà plante.
"Display window lost focus.".....çà veut dire quoi ?
je viens de le refaire, et çà a planté au bout de 7 loop ce coup-ci.
j'comprends pas.
Marsh Posté le 17-04-2006 à 23:05:23
demande lui, peut être qu'il a trouvé la solution entre temps :
http://forum.hardware.fr/hardwaref [...] 0418-1.htm
Marsh Posté le 17-04-2006 à 23:08:02
ou alors ici :
http://66.249.93.104/search?q=cach [...] =clnk&cd=3
ils disent :
"Q:	Sometimes while benchmarking I get a message saying "Display Window lost focus", and the benchmark run stops. What's causing this?
A:	The "Display Window lost focus" message means that some other application running in the background takes the primary focus, which means that the benchmark run may be affected and thus quits. To "fix" this problem, please close any open applications, background programs and automated tasks such as antivirus utilities, email software, online chat applications etc."
donc ferme toutes les appli. de fonds....
Marsh Posté le 17-04-2006 à 23:23:30
ah beh d'accord.
effectivement, j'ai l'antivirus, le firewall, et tout le touin-touin qui tourne derrière.
vais essayer comme çà.
merci.
Marsh Posté le 18-04-2006 à 02:07:57
Euréka !
tu m'a réglé mon problème malik67.
un grand merci.
il fallait effectivement couper les programmes fonctionnant dans le fond.
mais pour les antivirus et autres firewall, il ne fallait pas seulement les désactiver, mais carrément aller dans le gestionnaire de tâche et couper leur processus qui continue à fonctionner malgré la désactivation et la fermeture.
donc, c'est bon, j'ai fait mes 10 loops ( 170 passes ) sans erreur donc c'est bon.
un grand, grand merci à toi.
Pink.
Marsh Posté le 17-04-2006 à 16:52:13
salut, pour tester mon o/c Processeur, j'utilise tout les benchs habituel ( OCCT, sp2004, Superpi32M ), mais j'utilise aussi 3Dmark2001 en loop.
et là, j'ai un problème car j'obtiens toujours la même erreur au bout de 6 loop à peu près.
voilà le screen :
quelqu'un a une idée de la cause possible de cette erreur ?
merci.
Pink.
nb : ma carte graphique n'est pas overclockée et tourne donc au fréquence d'origine.
Le plus dur c'est pas l’Atterrissage, c'est la Chute. «Dieu se rit des hommes qui déplorent les effets dont ils chérissent les causes» FAFO.
