3Dmark2001 probleme avec mon score.
3Dmark2001 probleme avec mon score. - Bench - Hardware
Marsh Posté le 19-02-2004 à 10:09:31
Radeon 9800 xt (catalyst 4.2)
 AMD Athlon Xp barton 2500@3200
 2*256 ram PC3200 (2.5 2 2 11)
 ABit NF7-S (Bios 22)
 Seulement les 7 premiers test ont ete fait car seuls ces tests sont utilises pour calculer le score.
 Le score est casiment le meme quand je fais la complete (les 21 tests).
 Et je ne fais que 14000 a 3Dmark2001
 Alors que je fais 6117 au 2003.
 Ou Se situe le probleme a votre avis ?
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 330
DISPLAY
Platform RADEON 9800 XT
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score 14014
Game 1 - Car Chase - Low Detail 188.0 fps
Game 1 - Car Chase - High Detail 71.0 fps
Game 2 - Dragothic - Low Detail 231.4 fps
Game 2 - Dragothic - High Detail 124.7 fps
Game 3 - Lobby - Low Detail 192.9 fps
Game 3 - Lobby - High Detail 85.3 fps
Game 4 - Nature 113.6 fps
Fill Rate (Single-Texturing) N/A
Fill Rate (Multi-Texturing) N/A
High Polygon Count (1 Light) N/A
High Polygon Count (8 Lights) N/A
Environment Bump Mapping N/A
DOT3 Bump Mapping N/A
Vertex Shader N/A
Pixel Shader N/A
Advanced Pixel Shader N/A
Point Sprites N/A
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family Athlon(tm)
Internal Clock 2.21 GHz
Internal Clock Maximum 3 GHz
External Clock 200 MHz
Socket Designation Socket A
Type <unknown>
Upgrade ZIF Socket
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version AMD Athlon(tm) XP
CPUID 0x000006a0
CACHES
Level 1
Capacity 128 KB
Type Internal
Type Details Synchronous
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 512 KB
Type External
DIRECTX INFO
DirectX Version 9.0
DIRECTDRAW INFO
DirectDraw Version  5.3.0000000.900
DISPLAY DEVICES
Description Pilote d'affichage principal
Manufacturer ATI Technologies Inc.
Name RADEON 9800 XT
Total Local Video Memory 256 MB
Total Local Texture Memory 256 MB
Total AGP Memory 0  bytes
Display Driver ati2dvag.dll
Display Driver Version 6.14.10.6422
Driver WHQL Certified Yes
Max Texture Width  2048
Max Texture Height 2048
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 8
Vertex Shader Version 1.1
Pixel Shader Version 1.4
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
Vendor ID 0x1002
Device ID 0x4e4a
Sub-System ID 0x00021681
Revision 0x00
DISPLAY MODES
Resolution 320x200x16-bit RGB [565] @ 60 Hz
Resolution 320x200x16-bit RGB [565] @ 75 Hz
Resolution 320x200x32-bit RGB [888] @ 60 Hz
Resolution 320x200x32-bit RGB [888] @ 75 Hz
Resolution 320x240x16-bit RGB [565] @ 60 Hz
Resolution 320x240x16-bit RGB [565] @ 75 Hz
Resolution 320x240x32-bit RGB [888] @ 60 Hz
Resolution 320x240x32-bit RGB [888] @ 75 Hz
Resolution 400x300x16-bit RGB [565] @ 60 Hz
Resolution 400x300x16-bit RGB [565] @ 75 Hz
Resolution 400x300x32-bit RGB [888] @ 60 Hz
Resolution 400x300x32-bit RGB [888] @ 75 Hz
Resolution 512x384x16-bit RGB [565] @ 60 Hz
Resolution 512x384x16-bit RGB [565] @ 75 Hz
Resolution 512x384x32-bit RGB [888] @ 60 Hz
Resolution 512x384x32-bit RGB [888] @ 75 Hz
Resolution 640x400x16-bit RGB [565] @ 60 Hz
Resolution 640x400x16-bit RGB [565] @ 75 Hz
Resolution 640x400x32-bit RGB [888] @ 60 Hz
Resolution 640x400x32-bit RGB [888] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 60 Hz
Resolution 640x480x16-bit RGB [565] @ 72 Hz
Resolution 640x480x16-bit RGB [565] @ 75 Hz
Resolution 640x480x16-bit RGB [565] @ 85 Hz
Resolution 640x480x32-bit RGB [888] @ 60 Hz
Resolution 640x480x32-bit RGB [888] @ 72 Hz
Resolution 640x480x32-bit RGB [888] @ 75 Hz
Resolution 640x480x32-bit RGB [888] @ 85 Hz
Resolution 800x600x16-bit RGB [565] @ 56 Hz
Resolution 800x600x16-bit RGB [565] @ 60 Hz
Resolution 800x600x16-bit RGB [565] @ 70 Hz
Resolution 800x600x16-bit RGB [565] @ 72 Hz
Resolution 800x600x16-bit RGB [565] @ 75 Hz
Resolution 800x600x16-bit RGB [565] @ 85 Hz
Resolution 800x600x32-bit RGB [888] @ 56 Hz
Resolution 800x600x32-bit RGB [888] @ 60 Hz
Resolution 800x600x32-bit RGB [888] @ 70 Hz
Resolution 800x600x32-bit RGB [888] @ 72 Hz
Resolution 800x600x32-bit RGB [888] @ 75 Hz
Resolution 800x600x32-bit RGB [888] @ 85 Hz
Resolution 1024x768x16-bit RGB [565] @ 60 Hz
Resolution 1024x768x16-bit RGB [565] @ 70 Hz
Resolution 1024x768x16-bit RGB [565] @ 72 Hz
Resolution 1024x768x16-bit RGB [565] @ 75 Hz
Resolution 1024x768x16-bit RGB [565] @ 85 Hz
Resolution 1024x768x32-bit RGB [888] @ 60 Hz
Resolution 1024x768x32-bit RGB [888] @ 70 Hz
Resolution 1024x768x32-bit RGB [888] @ 72 Hz
Resolution 1024x768x32-bit RGB [888] @ 75 Hz
Resolution 1024x768x32-bit RGB [888] @ 85 Hz
Resolution 1152x864x16-bit RGB [565] @ 60 Hz
Resolution 1152x864x16-bit RGB [565] @ 70 Hz
Resolution 1152x864x16-bit RGB [565] @ 75 Hz
Resolution 1152x864x32-bit RGB [888] @ 60 Hz
Resolution 1152x864x32-bit RGB [888] @ 70 Hz
Resolution 1152x864x32-bit RGB [888] @ 75 Hz
Resolution 1280x768x16-bit RGB [565] @ 56 Hz
Resolution 1280x768x16-bit RGB [565] @ 60 Hz
Resolution 1280x768x16-bit RGB [565] @ 75 Hz
Resolution 1280x768x16-bit RGB [565] @ 85 Hz
Resolution 1280x768x32-bit RGB [888] @ 56 Hz
Resolution 1280x768x32-bit RGB [888] @ 60 Hz
Resolution 1280x768x32-bit RGB [888] @ 75 Hz
Resolution 1280x768x32-bit RGB [888] @ 85 Hz
Resolution 1280x960x16-bit RGB [565] @ 60 Hz
Resolution 1280x960x16-bit RGB [565] @ 70 Hz
Resolution 1280x960x16-bit RGB [565] @ 72 Hz
Resolution 1280x960x16-bit RGB [565] @ 75 Hz
Resolution 1280x960x32-bit RGB [888] @ 60 Hz
Resolution 1280x960x32-bit RGB [888] @ 70 Hz
Resolution 1280x960x32-bit RGB [888] @ 72 Hz
Resolution 1280x960x32-bit RGB [888] @ 75 Hz
Resolution 1280x1024x16-bit RGB [565] @ 60 Hz
Resolution 1280x1024x32-bit RGB [888] @ 60 Hz
TEXTURE FORMATS
Pixel Format 32-bit ARGB [8888]
Pixel Format 32-bit RGB [888]
Pixel Format 16-bit RGB [565]
Pixel Format 16-bit RGB [555]
Pixel Format 16-bit ARGB [1555]
Pixel Format 16-bit ARGB [4444]
Pixel Format 8-bit A [8]
Pixel Format 8-bit YUV [800]
Pixel Format 16-bit AYUV [8800]
Pixel Format FourCC [UYVY]
Pixel Format FourCC [YUY2]
Pixel Format FourCC [DXT1]
Pixel Format FourCC [DXT2]
Pixel Format FourCC [DXT3]
Pixel Format FourCC [DXT4]
Pixel Format FourCC [DXT5]
3D Capabilities Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Rendering to a Window, N Patches, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures
DIRECTSHOW INFO
DirectShow Version 6.05.01.0900
REGISTERED DIRECTSHOW FILTERS
Filter .RAM file Parser
Filter AC3 Parser Filter
Filter ACELP.net Sipro Lab Audio Decoder
Filter ACM Wrapper
Filter ASF ACM Handler
Filter ASF DIB Handler
Filter ASF DJPEG Handler
Filter ASF ICM Handler
Filter ASF JPEG Handler
Filter ASF URL Handler
Filter ASF embedded stuff Handler
Filter ASX file Parser
Filter ASX v.2 file Parser
Filter AVI Decompressor
Filter AVI Draw
Filter AVI Splitter
Filter AVI/WAV File Source
Filter BDA MPEG2 Transport Information Filter
Filter Color Space Converter
Filter DV Muxer
Filter DV Splitter
Filter DV Video Decoder
Filter Default DirectSound Device
Filter Default MidiOut Device
Filter File Source (Async.)
Filter File Source (Netshow URL)
Filter File Source (URL)
Filter File stream renderer
Filter Internal Script Command Renderer
Filter Line 21 Decoder
Filter Line 21 Decoder 2
Filter Lyric Parser
Filter MIDI Parser
Filter MJPEG Decompressor
Filter MPEG Audio Decoder
Filter MPEG Layer-3 Decoder
Filter MPEG Video Decoder
Filter MPEG-2 Demultiplexer
Filter MPEG-2 Sections and Tables
Filter MPEG-2 Splitter
Filter MPEG-I Stream Splitter
Filter Microsoft MPEG-4 Video Decompressor
Filter Microsoft Screen Video Decompressor
Filter Multi-file Parser
Filter NSC file Parser
Filter Overlay Mixer2
Filter QT Decompressor
Filter QuickTime Movie Parser
Filter SAMI (CC) Parser
Filter VBI Surface Allocator
Filter VGA 16 Color Ditherer
Filter Video Port Manager
Filter Video Renderer
Filter WM ASF Reader
Filter WM ASF Writer
Filter WMP CD Filter
Filter WST Decoder
Filter Wave Parser
Filter Windows Media Audio Decoder
Filter Windows Media Multiplexer
Filter Windows Media Pad VU Data Grabber
Filter Windows Media Update Filter
Filter Windows Media Video Decoder
Filter Windows Media source filter
Filter XML Playlist
MEMORY INFO
Total Physical Memory 512 MB
Free Physical Memory 388.50 MB
Total Pagefile Memory 1.22 GB
Free Pagefile Memory 1.14 GB
MEMORY ARRAYS
Max Module Capacity 1.50 GB
Location System Board
Use System
Supported Error D&C None
Supported Speeds <unknown>
Supported Types <unknown>
Supported Voltages <unknown>
MEMORY SLOTS
Installed & Enabled Size 256 MB
Form Factor DIMM
Frequency 0 Hz
Slot A0 [Bank0/1]
Manufacturer
Type <unknown>
Type Details <unknown>
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
Form Factor DIMM
Frequency 0 Hz
Slot A1 [Bank2/3]
Manufacturer
Type <unknown>
Enabled Size 256 MB
Total Bit Width 0
Data Bit Width 0
Installed & Enabled Size 0  bytes
Form Factor DIMM
Frequency 0 Hz
Slot A2 [Bank4/5]
Manufacturer
Type <unknown>
Total Bit Width 0
Data Bit Width 0
MOTHERBOARD INFO
Manufacturer http://www.abit.com.tw/
Model NF7-S/NF7 (nVidia-nForce2)
Version 2.X
BIOS Vendor Phoenix Technologies, LTD
BIOS Version 6.00 PG
BIOS Release Date 12/24/2020
BIOS Properties Plug and Play, Flash, AGP
CARD SLOTS
Number 1
Designation PCI0
Type PCI
Characteristics 5.0V, 3.3V, PME Signal
Data Bus Width 32
Details Available, Long
Device Class <unknown>
Device Name
Device Manufacturer
Device Driver Date
Device Vendor ID 0x0000
Device ID 0x0000
Device Sub-System ID 0x00000000
Device Revision 0x00
IRQ 0
Number 2
Designation PCI1
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 3
Designation PCI2
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 4
Designation PCI3
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 5
Designation PCI4
Type PCI
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
Number 0
Designation AGP
Type AGP
Data Bus Width 32
Device Name
Device Manufacturer
Device Driver Date
Device ID 0x0000
IRQ 0
SYSTEM DEVICES
Description Pont ISA standard PCI
Manufacturer (Périphériques système standard)
Vendor ID 0x10de
Device ID 0x0060
Subsystem ID 0x00000000
Revision 0xa4
Description NVIDIA nForce PCI System Management
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x0064
Subsystem ID 0x1c00147b
Revision 0xa2
Description Pont PCI vers PCI standard PCI
Vendor ID 0x10de
Device ID 0x006c
Revision 0xa3
Description Pont CPU hôte standard PCI
Vendor ID 0x10de
Device ID 0x01e0
Revision 0xc1
Description NVIDIA nForce2 AGP Host to PCI Bridge
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01e8
Revision 0xc1
Description NVIDIA nForce2 Ultra 400 Memory Controller
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01eb
Subsystem ID 0x0c1710de
Revision 0xc1
Description NVIDIA nForce2 Memory Controller
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ec
Revision 0xc1
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ed
Revision 0xc1
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ee
Revision 0xc1
Manufacturer NVIDIA
Vendor ID 0x10de
Device ID 0x01ef
Revision 0xc1
Revision 3.0
Rate 4x, 8x (8x enabled)
Aperture Size 0  bytes
Sideband Addressing supported (disabled)
Fast Write supported (enabled)
MONITOR INFO
MONITORS
Name Écran Plug-and-Play
Manufacturer (Types d'écrans standard)
Max Width 0
Max Height 0
POWER SUPPLY INFO
BATTERIES
OPERATING SYSTEM INFO
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 1
Locale FR
Desktop Width 1024
Desktop Height 768
Desktop BPP 32
HARD DISK INFO
HARD DISKS
Name ST3120026A
Manufacturer (Lecteurs de disque standard)
Capacity 111.79 GB
Model ST3120026A
Interface Type IDE
Message édité par vampyrx le 19-02-2004 à 11:39:29
Marsh Posté le 19-02-2004 à 10:17:41
franchement, les jeux ca rame pas :??:
donc tu t'en fout un peu du score non?
Marsh Posté le 19-02-2004 à 10:18:33
moi ca me parait correcte comme score.
Par contre évite de mettre tous le sytem infos de 3Dmark, paceque je doute que beaucoup de monde le regarde et te réponde après :)
Vmod vgpu fx5900xt
Marsh Posté le 19-02-2004 à 10:25:41
Ben non le score est pas correct du tout a mon avis...
Avec ma 9800 pro j'arrivais a 17000.
Donc je ne comprends pas pourquoi...
J'ai mis le fichier afin que quelqu'un compare avec le sien pour savoir ou est mon probleme...
Marsh Posté le 19-02-2004 à 10:26:16
De plus les jeux, j'en sais rien, j'ai pas encore tester...je tente d'optimiser mon systeme correctement pour le moment.
Marsh Posté le 19-02-2004 à 10:42:11
je repondrais une prochaine fois mes yeux sont trop fatigués la apres otant de lecture.....
Marsh Posté le 19-02-2004 à 10:54:05
Ben si tu as l'occasion de m'aider dans un futur proche, je te remercie d'avance :)
Marsh Posté le 19-02-2004 à 11:23:11
Ouinnn...
Marsh Posté le 19-02-2004 à 15:14:38
Personne ne veut m'aider ouinnn
Marsh Posté le 19-02-2004 à 16:04:29
:fou:  :fou:  :fou:  :fou:  :fou:  :fou:  :fou:
putain mais t'as pas de probleme...plus de 6000 points a 3dmarks 2k3 est une belle performance alors qu'est ce que tu en as a branler de faire "que" 14000 au 2001???
c de la branlette les benchmark....
regarde moi je fais presque 8000 points au 2003 alors que le 2001 plante avant meme d'arriver au bout....bin je m'en bas les couilles parce que dans les jeux je déchire tout!!! en 1600 par 1200 avec tout a donf.....
alors laisse tomber les bench et amuse toi!
 :fou:  :fou:
Message édité par Sylbuzz le 19-02-2004 à 16:16:35
Marsh Posté le 19-02-2004 à 16:07:32
:heink: c dingue ça....  :fou:
tu pleure alors que tu n'as meme pas encore essayer de jouer...
pffff mais quel boulet.... sans deconner vous allez pouvoir ouvrir une institution bientot....
Message édité par Sylbuzz le 19-02-2004 à 16:09:47
Marsh Posté le 19-02-2004 à 16:14:38
c clair, en plus moi a 3Dmark 2000, je fait 6000, c pour dire, eh bah c easy, je l'ai viré, et je rame pas dans les jeux en 1280x960
Marsh Posté le 19-02-2004 à 17:09:22
Euh on est d'accord, si avec ma config je fais 14000 a 3Dmark2001...C'est qu'il y a un probleme quelque part ?
 Donc si il y a un probleme, j'aimerai le resoudre.
 Si il n'y a pas de probleme et que c'est du a un bug...alors j'aimerai savoir lequel.
 Pourquoi etre aussi aigri ?
Marsh Posté le 19-02-2004 à 17:19:46
derriere le clavier, juste sur le siege...
Réalisation amplis classe D / T      Topic .Net - C# @ Prog
Marsh Posté le 19-02-2004 à 17:38:32
mort de rire :D
Marsh Posté le 19-02-2004 à 17:52:08
LOL
Marsh Posté le 19-02-2004 à 17:57:25
Je vois que certain ont de l'humour...
Moi j'ai pas envie de rire quand je paye une carte dans les 400 euros et que j'arrive pas a obtenir un score convenable la ou des personnes avec la meme carte font bcp mieux.
Message édité par vampyrx le 19-02-2004 à 17:57:58
Marsh Posté le 19-02-2004 à 18:11:59
nan rien, jprefere fermer ma gueule [:mlc]
Marsh Posté le 19-02-2004 à 21:25:03
C'est bon je fais 17800...
Et je suis desole mais 14000 pour 400 euros...ben c'est pas convenable pour moi :)
Aigri :)
Marsh Posté le 20-02-2004 à 10:23:15
et t'as fait koi pour ke ca marche?
Marsh Posté le 20-02-2004 à 11:46:35
J'ai touché a plusieurs parametres en meme temps donc je ne sais pas identifié lequel exactement...mais bon le probleme venait soit de l'AGP : que j'ai reglé sur 8X (il etait en auto et je crois qu'il prenait du 4x au lieu du 8X meme si je sais que normallement ca ne change rien, la ca a changé quelque chose je pense.), j'ai enabled le Fast write, j'ai modifie l'AA qui etait en 4x je l'ai mis a 2X.
J'ai augmenté un peu le voltage de la carte de 1.5 a 1.6. Et c'est tout, tout le reste c'est du defaut pour les pilotes.
Donc je sais pas si je suis un sorcier, mais ca fonctionne au moins maintenant...17800 au 2001 et 6300 au 2003 (comme quoi il fallait bien que je trouvela solution a mon probleme car j'ai gagné en vitesse...).
Comme quoi etre Aigri c'est pas tjrs tres utile :)
Message édité par vampyrx le 20-02-2004 à 11:47:38
Marsh Posté le 20-02-2004 à 11:50:29
voltage tu peux le remettre a 1.5 et le probleme venait que tu avait activer l'aa, desactive le completement et tu fera encore plus
Marsh Posté le 20-02-2004 à 11:55:51
bah oui, si tu active l'AA c normal que ce soit plus lent ;)
Marsh Posté le 20-02-2004 à 11:58:15
Ben la je l'ai laissé a 2X...4X c'etait trop je pense.
Marsh Posté le 20-02-2004 à 12:03:10
Et pour le voltage, OK je vaisle remettre a 1.5.
Marsh Posté le 20-02-2004 à 12:05:49
pour l'AA, tu peux le mettre a 2X meme a 4X, c comme tu le sents, mais vient pas te plaindre apres pour ton score.
Par contre tu vas gagné en qualité ;) c mieux :D
pour le voltage, 1.5 c largement suffisant
Marsh Posté le 20-02-2004 à 19:04:03
Oki doki kiki :)
Marsh Posté le 20-02-2004 à 19:33:40
c moi qui ait la plus grosse :o
Marsh Posté le 21-02-2004 à 00:31:00
:heink: moi, je suis d'accord avec toi vampyrx, ils sont aigris ts ces gens, et t'as vu des que ça va mieu, ils sont là " alors commen t'as fait " :kaola: ha ha
 :D  :D  :D  :D  :D
Marsh Posté le 21-02-2004 à 13:51:58
J'avais annoncé la couleur dans le titre du post...totalrecall avait le droit de ne pas lire, si il etait pas content, mais grace a lui, ca faisait des up :)
Marsh Posté le 21-02-2004 à 13:53:34
Petite question supplémentaire : Pour dans UT2004 quand je joue et que je meurs j'ai la phrase : You have forcibly remove from the game ? Ca veutdire que je me suis fait Kick ?
UT2004 tourne a fond sans probleme, j'adore :)
Marsh Posté le 21-02-2004 à 20:03:49
Chez moi aussi, et pourtant ma config date de Mars 2002 ;)
Enfin j'ai pas testé le 1600*1200 je réservé ça pr mon retour de vacances
C'est mon p90F qui va être content :D :D :D
Marsh Posté le 22-02-2004 à 13:34:44
Laje viens de DL la demo de farcry, on va voir ce que ca donne :)
