Qui sait à quoi servent les "asus enhenced driver" - Carte graphique - Hardware
Marsh Posté le 21-12-2004 à 18:36:55
Si tu ne les mets pas tu ne pourras pas utiliser la fonction hyperdrive de Smartdoctor.
In 3D mode, ASUS SmartDoctor automatically sets the GPU clock to the highest possible value for your graphics card when you are playing 3D games. This feature increases the core speed of your graphics card  for better 3D performance. SmartDoctor will restore the GPU clock to its default value when you return from 3D games.
NOTE: 3D mode is only available when the ASUS enhanced driver is installed.
Marsh Posté le 21-12-2004 à 18:33:26
Tous est dans le titre
